path: root/c/src/exec/libfs/src/imfs/imfs_init.c (follow)
* Moved the rmnod callback from the operations table to the handler table.Jennifer Averett1999-10-291-1/+0
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-98/+8
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* Split null handlers table to own file and renamed.Joel Sherrill1999-10-121-1/+1
| | | | Renamed IMFS handler tables to include IMFS prefix.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+158
