path: root/c/src/exec/libfs/src/imfs/imfs_free.c (follow)
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-62/+0
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+99
