path: root/c/src/exec/libfs/src/imfs/imfs_eval.c (follow)
* Unmount was failing as a side-effect of splitting the rmnod handlerJoel Sherrill1999-11-051-1/+1
| | | | and not handling every case properly.
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-3/+5
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* Split null handlers table to own file and renamed.Joel Sherrill1999-10-121-4/+4
| | | | Renamed IMFS handler tables to include IMFS prefix.
* Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill1999-02-241-2/+2
| | | | | | | rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
* Corrected spacing and added some new error checks that were neededJoel Sherrill1999-02-051-9/+9
| | | | to avoid dereferencing NULLs.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+638
