path: root/c/src/exec/libfs/src/imfs/imfs.h (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-8/+8
* Increased block size to 128 and added comments based on feedback fromJoel Sherrill2000-02-111-1/+13
| | | | Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
* Moved imfs set handlers prototype to the imfs.h file.Jennifer Averett1999-11-051-0/+4
* Unmount was failing as a side-effect of splitting the rmnod handlerJoel Sherrill1999-11-051-5/+6
| | | | and not handling every case properly.
* The object memfile.o was being included in the miniIMFS even though itJoel Sherrill1999-11-021-4/+31
| | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-1/+15
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* Split null handlers table to own file and renamed.Joel Sherrill1999-10-121-4/+3
| | | | Renamed IMFS handler tables to include IMFS prefix.
* Corrected mistakes in the IMFS file handlers table and added the missingJoel Sherrill1999-10-121-0/+5
| | | | routine imfs_fcntl.c
* Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill1999-02-241-15/+21
| | | | | | | rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
* Added a imfs fdatasync routine that gets called for fdatasync and datasync.Jennifer Averett1998-12-031-0/+4
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+445
