-4 = {d = -4, i = {0xc0100000, 0x0}} s=1 e=0x80 m=0x100000 (0x0900000)
-3 = {d = -3, i = {0xc0080000, 0x0}} s=1 e=0x80 m=0x080000 (0x0880000)
-2 = {d = -2, i = {0xc0000000, 0x0}} s=1 e=0x80 m=0x000000 (0x0800000)
-1 = {d = -1, i = {0xbff00000, 0x0}} s=1 e=0x7f m=0x000000 (0x0800000)
0 = {d = 0, i = {0x00000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x3ff00000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x40000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
3 = {d = 3, i = {0x40080000, 0x0}} s=0 e=0 m=0x080000 (0x0880000)
C4X
-4 = {d = -4, i = {0x01800000, 0x0}} s=1 e=1 m=0x800000 (0x1000000)
-3 = {d = -3, i = {0x01c00000, 0x0}} s=1 e=1 m=0xa00000 (0x1400000)
-2 = {d = -2, i = {0x00800000, 0x0}} s=1 e=0 m=0x800000 (0x1000000)
-1 = {d = -1, i = {0xff800000, 0x0}} s=1 e=0xff m=0x000000 (0x1000000)
0 = {d = 0, i = {0x80000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x00000000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x01000000, 0x0}} s=0 e=1 m=0x400000 (0x0800000)
3 = {d = 3, i = {0x01400000, 0x0}} s=0 e=1 m=0x600000 (0x0c00000)
4 = {d = 4, i = {0x02000000, 0x0}} s=0 e=2 m=0xXXXXXX (0x0000000)
0x1010 0000
0101 0000
0010 1002
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
functionality to libc and update TODO.
ttyHead back link is set.
configurations could see it while including <sys/ioctl.h> and
<sys/ioccom.h>.
of all FIO constants and conflict with libnetworking code.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
converted to automake.
places under the libbsp tree.
Removed times() since the version in the C Library support code is
fine.
was made in the conversion of bcopy() to strncpy().
substantial upgrade of newlibc.c occurred. Now the user extension
data area is used rather than notepads and as many routines as possible
were split into other files further reducing the minimum footprint
of an RTEMS executable.
libio flags and external fcntl.h style flags.
a full mount table at initialization. This is the wrong place
to mount filesystems 2-n since no device drivers are initialized
yet.
initialization.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
rdir=/opt/rtems
cd $idir
find . -type f | while read file
do
if [ ! -f ${file} ] ; then
echo ${file} missing
fi
done
c/src/lib/libmisc to c/src/libmisc.
process.
Renamed IMFS handler tables to include IMFS prefix.
places to make sure memory allocated for filesystem specifif nodes
gets freed.
routine imfs_fcntl.c
node used to manage file access.
