places under the libbsp tree.
Removed times() since the version in the C Library support code is
fine.
was made in the conversion of bcopy() to strncpy().
substantial upgrade of newlibc.c occurred. Now the user extension
data area is used rather than notepads and as many routines as possible
were split into other files further reducing the minimum footprint
of an RTEMS executable.
libio flags and external fcntl.h style flags.
a full mount table at initialization. This is the wrong place
to mount filesystems 2-n since no device drivers are initialized
yet.
initialization.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
rdir=/opt/rtems
cd $idir
find . -type f | while read file
do
if [ ! -f ${file} ] ; then
echo ${file} missing
fi
done
c/src/lib/libmisc to c/src/libmisc.
process.
Renamed IMFS handler tables to include IMFS prefix.
places to make sure memory allocated for filesystem specifif nodes
gets freed.
routine imfs_fcntl.c
node used to manage file access.
to its own top level package.
I'm working on code to mount my host based file system on the base file
system (imfs) and have a suggestion for a change to eval.c in the
c/src/lib/libc directory of the 8/20/1999 snapshot. The current version
does not test the result value returned from the evalpath callback (line 47)
in the case where follow_link is true. Attached is my suggested change.
Without this test the node_type callback may be called after evalpath
failed. node_type could set the type to some value other then
RTEMS_FILESYSTEM_HARD_LINK or RTEMS_FILESYSTEM_SYM_LINK but it seems cleaner
to add the check on result.
a top level more independently configured package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
mount() was changed to avoid the use of a string as the options.
for simplicity.
D. V. Henkel-Wallace <gumby@zembu.com> spotted this one.
size of mininum application.
