that the per task reentrancy structure was not being processed properly
during exit().
joel@oarcorp.com wrote:
> This is always an ugly place to poke around. :(
> The code in newlib/libc/stdlib/exit.c walks the atexit chain for the
> reentrancy structure for JUST the current task. The code in libc_wrapup()
> does it for both the current task and the global reentrancy structure
> (which tends to be where driver atexit()'s were registered.
> So I think the _wrapup_reent(0) in libc_wrapup() should be commented out.
> If you concur, then I will make the change and improve the comment on this
> line of code to explain things:
> libc_wrapup(); /* Why? XXX */
> --joel
That does the job. cdtest.exe works correctly now.
<e.norum@sk.sympatico.ca> and concerns from Thomas Doerfler
<td@imd.m.ISAR.de> when he submitted the patch:
Since enabling XON/XOFF has such a major performance hit on `smart' output
devices I think it should be *off* by default. I think some thought should
be given to adding hooks for hardware that can support XON/XOFF without
software intervention, or for hardware like the 68360 SCC's that can use
large buffers, but still handle special characters immediately.
The patch you sent is a very good start, though. I just think that the
software flow control should be off -- to match the way the serial I/O
support has worked up until now.
Some lines for "documentation":
One thing should be noted: when XON/XOFF is enabled, the serial
device will always work with one-character buffers, so the interrupt
load for the CPU might get higer, especially on devices like MC68360
and MPC860, where the serial channels are capable of using big
buffers. But, once again, this only happens when XON/XOFF is actually
selected.
Please note that the flag IXON is set by default, so outgoing
XON/XOFF flow control is enabled by default.
XON/XOFF is controlled using the "standard" fields IXON/IXOFF in the
termios structure. The termios flag IXANY is not (yet) supported.
Hardware handshake for the incoming data stream is controlled using
the standard flag CRTSCTS. If this flag is set, whenever the receive
buffer is almost full, the driver function "device.stopRemoteTx()" is
called, when the receive buffer has more space available,
"device.startRemoteTx()" is called again. If the driver does not
provide these interface functions (entries in device structure are
NULL pointers), then these calls are suppressed.
Changes of the flow control options during operation should work at
any time, but this has not been extensively tested.
No changes to the device driver interface are needed.
One critical point when using this patch might be, that any BSP using
this version of termios will now have outgoing flow control enabled
by default, so the behaviour of these BSPs will change here. The
option IXON has already been set in older termios by default, but it
did not work until this patch. Maybe this option should be switched
off by default, what do you think?
indicates an internal error.
There seems to be an ugly dependency between posix-headers and
libcsupport.
Configuring rtems with
../rtems-rc-19990324-0/configure \
--target=i386-rtems \
--prefix=<somewhere> \
--disable-posix
"make RTEMS_BSP=pc386" results into:
/opt/rtems/bin/i386-rtems-gcc --pipe
-B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems
-I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall
-ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c
In file included from
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16:
/opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or
directory
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning:
`struct utimbuf' declared inside parameter list
its scope is only this definition or declaration,
which is probably not what you want.
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function
`utime':
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34:
dereferencing pointer to incomplete type
make[4]: *** [o-pc386/utime.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c'
make: *** [all] Error 1
Apparently sys/utime.h is one of the posix headers and therefore gets
not installed (I suppose this is correct).
IMO, this probably indicates that sys/utime.h has to be moved to another
include subdirectory and should not be part of the posix-package.
[AFAIK, sys/*.h are system dependent headers, so why should it be a
posix-header? - Hmm]
2 lines of code that did not get included when Joel tried to manually
add a rejected patch.
fcntl support and an external fcntl handler for sockets.
would work. At the same time, the initial implementation of F_SETFL
was added. A support routine was added to convert internal libio
flags back to the POSIX style. Eventually the internal representation
should be eliminated in the interest of simplicity and code reduction.
This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory
too fast. Perhaps in the future, the places in IMFS that put a maximum
length name string on the stack and the jnode structure does not include
a maximu length name string can be fixed so this is not a problem.
that added ifdef on the pc386.
that performed the sequence open/write/close/open/read/close on a file.
It did not get the correct result since the file descriptor was reused.
to avoid dereferencing NULLs.
rtems_bsdnet_makeFdForSocket().
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
with the --disable-posix option, stubs for some routines (_getpid_r and
_kill_r) that are normally defined with POSIX were added.
all conflicts.
Date: Sat, 5 Dec 98 13:20:51 -0600
What do you think of this patch? It implements your `tap'
suggestion in a way that adds support for all ethernet devices with
no driver modifications. I also added a return value from the tap
function. If the return value is zero, the packet will be passed up
the chain as usual. If the return value is non-zero the mbuf holding
the packet will be freed and the packet will be dropped.
If you like it, please submit it to Joel.
I guess there needs to be an addition to the network documentation
describing the additional ioctl's -- and a big warning that the tap
function is called from a context that holds the network semaphore.
Here is Eric's patch. I've tested it a bit, and made a couple of
trivial changes. This is certainly better than mine: it should work
for all Ethernet drivers.
The only concern I have about this patch is that the tap function may
want to fiddle with the mbuf, calling functions like m_pullup and the
like. If those force the networking code to rearrange the mbuf
structure, then the caller's call to m_freem may crash. I don't know
if this is a realistic concern--I don't know enough about the mbuf
layer.
PROBLEMS
can/will be fixed.
with libchip.
The reentrant versions of the malloc functions in
c/src/lib/libc/malloc.c
do not match the definitions in newlib. These will be used if you use
newlib routines such as fdopen. I believe this patch to malloc.c is
needed to provide the correct versions.
RTEMS workspace is to be zeroed out.
1. Finally fixes raw interrupts for pc386
2. Makes some minor cleanup in console and startup
3. Makes rtems_termios_dequeue_characters() to return count of
outstanding chars - it allows to simplify console isrs a little
bit.
4. pc386 uart modified to be friendlier to termios parameter changes,
to have minor performance improvement and to take advantage of
of above termios modification.
I fixed the problems noted by Victor Vengerov.
1) Fix typo in cfsetispeed().
2) In rtems_termios_open, ensure that args->iop->data1 is set before calling
device-specific open routine.
I have reworked the ethernet driver for the BSP pc386 and
here is the patch to apply.
I think I figured out why rtems_panic was locking up instead of
shutting down the executive and returning to the code that called
boot_card().
Later on there is code to print some messages on the standard error
stream, a recursive call back to rtems_verror (through rtems_error)
and finally a call to _exit().
I think that the _Thread_Disable_dispatch() is preventing the final
context switch back to the boot_card() code. Does this sound right
to you?
"Thomas Doerfler" <td@imd.m.isar.de> wrote:
> While implementing/testing the console/termios support for
> PPC403 in RTEMS-4.0.0-beta3, I am stuck at a certain location in
> termios.c:
> During "rtems_termios_initialize", the main control data structure
> "*tty" is allocated using malloc(). (Note, that malloc does not
> clear the allocated memory and my BSP does not clear memory during
> startup). Furtheron, a lot of fields of that structure are
> initialized, but the field "rawOutBufState" is not, and therefore
> keeps an arbitrary contents.
> When "osend()" is called the first time(with the serial device
> driver working in interrupt mode), termios gets stuck and will not
> call the device drivers output function.
> My questions now are:
> - anybody already experienced this bug?
> - is it a bug at all or did I do anything fundamentally wrong?
> - is there already a common bugfix for that?
> I don't like poking around in other people code, as long as I am
> not absolutely sure, what I do...
Yes, there's a bug there.
I thought that Joel had patched this already, but here's a patch to
fix this. This patch also addresses a concern that many others have
raised regarding enabling and disabling of transmitter interrupts.
First, here's the example I've been using of a simple UART-style
interrupt-driven driver:
void
device_write_routine (int minor, char *buf, int count)
UART->control_register &= ~UART_TRANSMITTER_READY;
UART->output_register = *buf;
UART->control_register |= UART_TRANSMIT_INTERRUPT_ENABLE;
void
device_transmit_interrupt_routine (int vector)
UART->control_register &= ~UART_TRANSMIT_INTERRUPT_ENABLE;
rtems_termios_dequeue_characters (device_ttyp, 1);
Several people have expressed their concern about the disable/enable
of transmitter interrupts for every character. On some machines
this disable/enable is an expensive operation. With the attached
patch applied you can write the two routines as:
void
code_to_clear_transmitter_ready_status ();
if (device_ttyp->rawOutBufState == rob_idle)
code_to_enable_transmitter_interrupts ();
code_to_send_one_character_to_transmitter (*buf);
void
code_to_disable_transmitter_interrupts ();
