After weeks of trying to figure why my RTEMS/KASQ server crashes now
and then I found a nasty bug I introduced in adding multiple-driver
support to libio. The bug only affects `add-on' driver classes (like
the networking code). Old-style file descriptors were not affected.
The bug cleared 32 bytes of memory (unspecified location) whenever a
`close' of a socket was performed! I was clearing an IOP I hadn't
allocated -- and the pointer wasn't initiallized, either!
error number mapping.
down.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
and gcc 2.8.x -specs options.
should simplify the build process.
statuses being returned to gnat runtime in order for it to raise
use_errors. This was needed to identify the places in gnat's runtime
which needed to be addressed.
malloc for per-thread reentrancy structure allocation.
miscellaneous corrections in casting.
mode have stubs.
This implementation of sleep is now only used when the POSIX API is not
configured.
applications which use only the rtems api (i.e. not the posix api) will
link.
of the POSIX API necessary to support the GNAT runtime to initially compile.
We now have verified that the specifications for the necessary routines
are correct per the POSIX standards we have.
from the application code, this file required more visibility than
is given by default to application code.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
insures that stdout is line buffered (see setvbuf).
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
newlib C library.
Fixed bug where length did not take into account amount added
for alignment requirements.
