path: root/c/src/exec/libcsupport/src/unmount.c (follow)
* Added code to correctly free any allocated space during the evaluationJennifer Averett1999-10-251-0/+1
| | | | process.
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-121-11/+6
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Added call to freenod to let each filesystem free its own internalJoel Sherrill1999-10-121-5/+19
| | | | node used to manage file access.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+214
