path: root/c/src/exec/libcsupport/src/telldir.c (follow)
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/libio_.h: Remove set_errno_and_return_minus_one. * libc/cfsetispeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/cfsetospeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chroot.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/closedir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fdatasync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fpathconf.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fstat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fsync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ftruncate.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/getdents.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ioctl.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/lseek.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/open.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/read.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/rmdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/tcsetattr.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/telldir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname_r.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/utime.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/write.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one.
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* Check for NULL being passed in.Joel Sherrill1999-11-021-1/+6
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-6/+22
| | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory.
* Changed all of these to stubs.Joel Sherrill1998-10-221-35/+3
* Added rest of opendir family and made it compile.Joel Sherrill1998-10-131-1/+16
* New files.Joel Sherrill1998-10-131-0/+40
