path: root/c/src/exec/libcsupport/src/tcgetprgrp.c (unfollow)
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
2000-06-14*** empty log message ***Joel Sherrill1-2/+0
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-11-16Added.Joel Sherrill1-3/+3
1999-10-01Addition of more functionality by Eric Norum to support GNU readline.Joel Sherrill1-5/+3
1999-06-11Added local prototype of ioctl() to avoid requiring sys/ioctl.h.Joel Sherrill1-1/+3
1999-03-16Use proper include for libio.h.Joel Sherrill1-1/+1
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-7/+14
1998-05-22Added tcdrain(), cfgetospeed(0, cfsetospeed(), cfgetispeed(), andJoel Sherrill1-0/+26
cfsetispeed().
