path: root/c/src/exec/libcsupport/src/privateenv.c (follow)
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+2
| | | | | | * libc/Makefile.am: Add MULTISUBDIR support. * libc/fcntl.c: Add #include <stdarg.h>. * libc/privateenv.c: Add #include <stdlib.h>.
* 2001-04-20 Correo Fernando-ruiz <correo@fernando-ruiz.com>Joel Sherrill2001-04-201-7/+49
| | | | | | | | | | | | | | | | | * include/rtems/libio_.h, libc/chroot.c, libc/privateenv.c: Private environment and chroot() enhancements and fixes. Comments: + privateenv has been modified to let at chroot() to be more POSIX like Sergei Organov recommended. + A task owner lets that rtems_set_private_env() will be called twice or more times. + chroot() can be called without a previous rtems_set_private_env(); (transpanrently) + The second call of rtems_set_private_env() makes a internal chroot("/") into global imfs_root. + chroot() runs like chdir() without a previous chdir("/") with the global root. + The current directory can be in a wrong place like Linux and many other Unices.
* 2001-01-25 Fernando Ruiz <fernando.ruiz@ctv.es>Joel Sherrill2001-01-251-0/+37
* Alternate email is correo@fernando-ruiz.com * libc/privateenv.c: New file. * include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c, libc/unmount.c: Moved default umask, current working directory, root, and links followed count into a structure "user environment" that can then be treated as a unit. This enable giving unique copies of these to individual threads or collection of threads.
