path: root/c/src/exec/libcsupport/src/no_libc.c (follow)
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-9/+11
| | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory.
* Modifications to make go32 build using new i386-go32-rtems toolsetJoel Sherrill1997-01-291-1/+1
| | | | and gcc 2.8.x -specs options.
* dummy function added to satisfy ANSIJoel Sherrill1996-09-181-0/+10
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+45
