libc/utime.c, libc/write.c:
<rtems/XXX.h>.
* libc/newlibc.c: Removed _A29K specific ifdef.
substantial upgrade of newlibc.c occurred. Now the user extension
data area is used rather than notepads and as many routines as possible
were split into other files further reducing the minimum footprint
of an RTEMS executable.
that the per task reentrancy structure was not being processed properly
during exit().
joel@oarcorp.com wrote:
> This is always an ugly place to poke around. :(
> The code in newlib/libc/stdlib/exit.c walks the atexit chain for the
> reentrancy structure for JUST the current task. The code in libc_wrapup()
> does it for both the current task and the global reentrancy structure
> (which tends to be where driver atexit()'s were registered.
> So I think the _wrapup_reent(0) in libc_wrapup() should be commented out.
> If you concur, then I will make the change and improve the comment on this
> line of code to explain things:
> libc_wrapup(); /* Why? XXX */
> --joel
That does the job. cdtest.exe works correctly now.
that added ifdef on the pc386.
with the --disable-posix option, stubs for some routines (_getpid_r and
_kill_r) that are normally defined with POSIX were added.
PROBLEMS
can/will be fixed.
I have reworked the ethernet driver for the BSP pc386 and
here is the patch to apply.
These were noticed by Eric Norum.
the atexit routines on the global reentrancy structure were not
invoked. But it does not seem like a 100% correct solution.
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt>
of NavIST (http://pandora.ist.utl.pt/).
down.
and gcc 2.8.x -specs options.
should simplify the build process.
malloc for per-thread reentrancy structure allocation.
mode have stubs.
This implementation of sleep is now only used when the POSIX API is not
configured.
applications which use only the rtems api (i.e. not the posix api) will
link.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
insures that stdout is line buffered (see setvbuf).
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
