path: root/c/src/exec/libcsupport/src/mount.c (unfollow)
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
2000-11-202000-11-20 Dmitry Kargapolov <dk@gentex.ru>Joel Sherrill1-3/+9
* libc/mount.c: Make sure there is space allocated for a device name in the mount table entry.
2000-11-172000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett1-20/+18
* libc/mount.c (search_mt_for_mount_point): Deleted routine. * libc/mount.c (Is_node_fs_root): Replacement for above that accounts for the imaginary root node being returned by the filesystem evaluation routine. * libc/unmount.c (unmount): Account for imaginary root node being returned and improved variable names to clarify code. * libc/unmount.c (file_systems_below_this_mountpoint): Body of routine replaced to account for imaginary root node being returned.
2000-11-012000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
2000-10-252000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-21/+1
* libc/ioman.c: Moved to libfs. * libc/Makefile.am: Removed ioman.c as part of moving it to libfs. * libc/base_fs.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. * libc/libio.h: Removed prototype of IMFS_ops since it should not be in this file. * libc/mount.c: Removed IMFS specific configuration information. * libc/unmount.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific.
2000-09-282000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-5/+5
* libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
1999-11-29Fixed spacing.Joel Sherrill1-1/+1
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-10-25Added code to correctly free any allocated space during the evaluationJennifer Averett1-72/+73
process.
1999-10-12Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1-4/+2
places to make sure memory allocated for filesystem specifif nodes gets freed.
1999-10-12Added call to freenod to let each filesystem free its own internalJoel Sherrill1-14/+21
node used to manage file access.
1999-06-15After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface toJoel Sherrill1-35/+3
mount() was changed to avoid the use of a string as the options.
1999-06-14RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to RTEMS_FILESYSTEM_READ_WRITEJoel Sherrill1-1/+1
for simplicity.
1999-06-09Switched to using strcasecmp() since it is more portable.Joel Sherrill1-2/+2
D. V. Henkel-Wallace <gumby@zembu.com> spotted this one.
1999-05-27Removed usage of printf.Joel Sherrill1-1/+1
1999-02-24Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill1-1/+5
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
1999-02-05Corrected spacing and added some new error checks that were neededJoel Sherrill1-13/+23
to avoid dereferencing NULLs.
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-0/+299
