path: root/c/src/exec/libcsupport/src/link.c (follow)
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-4/+4
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* 2000-08-11 Chris Johns <ccj@acm.org>Joel Sherrill2000-08-111-0/+8
| | | | | | | | | | | | | | | * libc/chmod.c: Return ENOTSUP if filesystem does not have handler. * libc/eval.c: Ditto. * libc/fcntl.c: Ditto. * libc/fsync.c: Ditto. * libc/ioctl.c: Ditto. * libc/ioman.c: Ditto. * libc/link.c: Ditto. * libc/memfile.c: Ditto. * libc/mknod.c: Ditto. * libc/symlink.c: Ditto. * libc/libio.h(rtems_filesystem_dev_major_t): New macro. * libc/libio.h(rtems_filesystem_dev_minor_t): New macro.
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-121-20/+7
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Added call to freenod to let each filesystem free its own internalJoel Sherrill1999-10-121-5/+32
| | | | node used to manage file access.
* Added reentrant versions.Joel Sherrill1999-04-151-0/+21
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+60
