path: root/c/src/exec/libcsupport/src/fdatasync.c (follow)
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-1/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/libio_.h: Remove set_errno_and_return_minus_one. * libc/cfsetispeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/cfsetospeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chroot.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/closedir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fdatasync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fpathconf.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fstat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fsync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ftruncate.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/getdents.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ioctl.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/lseek.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/open.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/read.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/rmdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/tcsetattr.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/telldir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname_r.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/utime.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/write.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one.
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-2/+2
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* Patch from Eric Norum <eric@skatter.usask.ca> to eliminate externalJoel Sherrill1999-03-011-8/+0
| | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine.
* More general fix based on bug report and patch from Ian Lance TaylorJoel Sherrill1999-01-201-0/+1
| | | | | | | | | | <ian@airs.com> to fix this problem: There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It does not check whether the file descriptor it is passed is open. This can cause it to make a null dereference if it is passed a file descriptor which is in the valid range but which was not opened, or which was already closed.
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-101-5/+5
| | | | all conflicts.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+45
