path: root/c/src/exec/libcsupport/src/chroot.c (follow)
* 2001-04-20 Correo Fernando-ruiz <correo@fernando-ruiz.com>Joel Sherrill2001-04-201-14/+5
| | | | | | | | | | | | | | | | | * include/rtems/libio_.h, libc/chroot.c, libc/privateenv.c: Private environment and chroot() enhancements and fixes. Comments: + privateenv has been modified to let at chroot() to be more POSIX like Sergei Organov recommended. + A task owner lets that rtems_set_private_env() will be called twice or more times. + chroot() can be called without a previous rtems_set_private_env(); (transpanrently) + The second call of rtems_set_private_env() makes a internal chroot("/") into global imfs_root. + chroot() runs like chdir() without a previous chdir("/") with the global root. + The current directory can be in a wrong place like Linux and many other Unices.
* 2001-01-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-261-2/+2
| | | | | * libc/chroot.c: Fixed naming problems. Names were changed when the code this depends on was merged.
* 2001-01-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-261-0/+59
* cpu.c, rtems/score/cpu.h: Bug report from Peter Mueller <peter.o.mueller@gmx.de> because of not correcting for the ISR vector table now being allocated from the workspace.
