PROBLEMS
can/will be fixed.
of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction
factor. Plus removed checks for data/time set since POSIX does not permit
this call to fail. GNAT 3.12 depends on this.
Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6.
