path: root/c/src/exec/libblock (follow)
* Remove, moved to cpukit.Ralf Corsepius2002-07-2217-3663/+0
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-052-1/+5
| | | | * configure.ac: RTEMS_TOP(../..).
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-012-2/+21
| | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * src/bdbuf.c: Modified as part of above.
* 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-012-2/+4
| | | | * configure.ac: Remove RTEMS_PROJECT_ROOT.
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-272-1/+7
| | | | | * configure.ac: Use AC_CONFIG_AUX_DIR(../..). Add AC_PROG_RANLIB.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-6/+5
| | | | * src/Makefile.am: Don't preinstall libblock.a.
* 2002-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-184-24/+25
| | | | | | * Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-174-8/+15
| | | | | | | * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-285-13/+19
| | | | | | | | Move from c/src/libblock to c/src/exec/libblock * configure.ac: Reflect move. * Makefile.am: Ditto. * include/Makefile.am: Ditto. * src/Makefile.am: Ditto.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-083-0/+8
| | | | | * src/ramdisk.c: include <string.h>. * src/blkdev.c: include <string.h>.
* 2002-04-03 Alexander Kukuta <kam@oktet.ru>Joel Sherrill2002-04-032-2/+7
| | | | | * include/rtems/bdbuf.h: Address PR168 by changing bdbuf_buffer.avl.bal and bdbuf_buffer.avl.cache to signed char instead of char.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-03-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-211-5/+0
| | | | * ChangeLog: Undo incorrect addition of entry.
* 2002-03-21 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-211-0/+5
| | | | | * net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple PPPD connections.
* 2002-03-21 Alexander Kukuta <kam@oktet.ru>Joel Sherrill2002-03-213-610/+389
| | | | | | | * src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch to avoid using GPLed sources in RTEMS core. * src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree" implementation which was used for debugging only.
* 2002-02-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-2818-0/+3821
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am, include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h, include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore, src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c, src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
