path: root/c/src/exec/itron (follow)
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-287-7/+13
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-192-1/+5
| | | | * src/Makefile.am: Add multilib support.
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-072-1/+7
| | | | | | Discovered while fixing PR36 reported by Todor.Todorov@barco.com. * include/rtems/itron/object.h: Corrected _ITRON_Objects_Get() to use _Objects_Get_by_index().
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1612-156/+96
| | | | | | | | | | | | | | * include/itronsys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/itron/Makefile.am: Remove. * inline/rtems/Makefile.am: Remove. * inline/rtems/itron/Makefile.am: Remove. * macros/rtems/Makefile.am: Remove. * macros/rtems/itron/Makefile.am: Remove. * include/Makefile.am: handle subdirs. * inline/Makefile.am: handle subdirs. * macros/Makefile.am: handle subdirs. * configure.ac: Reflect changes above.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-113-8/+16
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-276-5/+13
| | | | | | | | * include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-1/+6
| | | | * src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* 2001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-093-6/+13
| | | | | | | * src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
* 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-072-1/+5
| | | | * configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-056-18/+31
| | | | | | | * include/Makefile.am, include/itronsys/Makefile.am, include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am, macros/rtems/itron/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-2461-0/+243
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-0121-11/+857
| | | | | | | | | | | | | | | * Added macro support to ITRON API. This is known to compile. * Makefile.am: Added macros directory. * configure.in: Removed error check for enabling macros. * macros/.cvsignore, macros/Makefile.am, macros/rtems/.cvsignore, macros/rtems/Makefile.am, macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * src/Makefile.am: Include compile.am.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-2/+6
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-2/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Patch rtems-rc-20000708-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-101-2/+0
| | | | | | | | | | | | | | | | | that is another small step toward multilibs: Changes: * Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/ * Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme functional. Notes: * --enable-multilibs is still non-functional * This patch should not have any influence on the old building scheme (--disable-multilib should silently fall back to the old building scheme). * running ./bootstrap is required after applying the patch
* Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-061-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1213-56/+35
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-139-0/+29
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-082-6/+1
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-3/+0
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* POSIX message queues now include complete functionality includingJoel Sherrill2000-01-134-19/+19
| | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently.
* Added new message priority parameter as returned by core support routine.Joel Sherrill2000-01-051-5/+7
* Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-232-86/+70
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-224-26/+26
* + Updated copyright information.Jennifer Averett1999-11-1799-2/+295
* Updated Mailbox Manager submitted and split into multiple files.Joel Sherrill1999-11-1711-344/+470
* Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modificationsJoel Sherrill1999-11-171-7/+257
| | | | | by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point.
* Added check to return passed if task is not suspended.Jennifer Averett1999-11-162-1/+7
* Added code to catch the error of suspend count exceding the counter value.Jennifer Averett1999-11-161-0/+4
* Comment fixed when adding prototype forJoel Sherrill1999-11-161-2/+11
| | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code.
* Returned third parameter for a NULL name to the objects open call.Jennifer Averett1999-11-151-1/+1
* + Fixed files to consistantly use a case of the location after callsJennifer Averett1999-11-1511-81/+97
| | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values.
* + Modified to use new Thread_Reset routine instead of the restart method.Jennifer Averett1999-11-151-1/+1
* Split ITRON Message Buffer Manager into multiple files.Joel Sherrill1999-11-1512-355/+524
* Split ITRON semaphore manager into multiple files.Joel Sherrill1999-11-159-285/+378
* + Changed validation of the_thread to validation of location.Joel Sherrill1999-11-124-37/+27
| | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK.
* + Changed validation of the_thread to validation of location.Joel Sherrill1999-11-121-11/+11
| | | | + Removed error path that should never happen.
* + Changed validation of the_thread to validation of location.Joel Sherrill1999-11-122-17/+8
* + Moved error checks to before the disable dispatch where possible.Joel Sherrill1999-11-121-5/+5
* Added comment about the E_CTX error condition (Implementation dependent).Joel Sherrill1999-11-121-0/+7
* + Moved error checks to before the dispatch disable where possible.Joel Sherrill1999-11-121-13/+12
* + Modified correct return path to call _ITRON_return_errorno( E_OK ) insteadJoel Sherrill1999-11-121-15/+10
| | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment.
* + Modified correct return path to call _ITRON_return_errorno( E_OK ) insteadJoel Sherrill1999-11-121-5/+2
* Removed unnecessary 3rd parameter.Joel Sherrill1999-11-121-1/+1
* New file.Joel Sherrill1999-11-121-0/+13
