* configure.in: Remove.
* include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations
should NOT use _Thread_Executing for return status since it is
permissible to invoke message send operations from an ISR. This was
reported by Suvrat Gupta <suvrat@utstar.com>.
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* include/Makefile.am, include/itronsys/Makefile.am,
include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am,
* Added macro support to ITRON API. This is known to compile.
* Makefile.am: Added macros directory.
* configure.in: Removed error check for enabling macros.
* macros/.cvsignore, macros/Makefile.am,
macros/rtems/.cvsignore, macros/rtems/Makefile.am,
macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am,
macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl,
macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl,
macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl,
macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl,
macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl,
macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* src/Makefile.am: Include compile.am.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is another small step toward multilibs:
* Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/
* Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in
RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme
functional.
* --enable-multilibs is still non-functional
* This patch should not have any influence on the old building
scheme (--disable-multilib should silently fall back to the old
building scheme).
* running ./bootstrap is required after applying the patch
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
were done by Joel.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
by Joel and Jennifer based on experience merging the other managers
and cleaning them up. No test code is available at this point.
_ITRON_Message_buffer_Translate_core_message_buffer_return_code.
to ITRON_Task_Get.
+ Modified to consistantly call _ITRON_return_errorno with E_OK.
+ Optimized the code to not disable dispatch prior to checking input values.
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) instead
of enabling dispatching and returning E_OK.
+ Removed error path that should never happen.
+ Changed validation of the_thread to validation of location.
+ Set correct error code when dormant state.
+ Fixed comment.
numerous other uses of the same variable.
