* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 57 | -0/+171 |
* | Updated Mailbox Manager submitted and split into multiple files. | Joel Sherrill | 1999-11-17 | 9 | -332/+442 |
* | Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modifications | Joel Sherrill | 1999-11-17 | 1 | -7/+257 |
| | | | | | by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point. | ||||
* | Added check to return passed if task is not suspended. | Jennifer Averett | 1999-11-16 | 2 | -1/+7 |
* | Added code to catch the error of suspend count exceding the counter value. | Jennifer Averett | 1999-11-16 | 1 | -0/+4 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 11 | -81/+97 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 12 | -355/+524 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 9 | -285/+378 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -37/+27 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 1 | -11/+11 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -17/+8 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 1 | -5/+5 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 1 | -0/+7 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 1 | -13/+12 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -15/+10 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -5/+2 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | New file. | Joel Sherrill | 1999-11-12 | 1 | -0/+13 |
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 17 | -91/+330 |
| | | | | Working Group. Included are tests. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 33 | -0/+3075 |
for RTEMS. |
