2002-07-22 | Remove, moved to cpukit. | Ralf Corsepius | 1 | -62/+0 | |
2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | |||||
1999-11-17 | + Updated copyright information. | Jennifer Averett | 1 | -0/+3 | |
1999-11-16 | Added check to return passed if task is not suspended. | Jennifer Averett | 1 | -0/+3 | |
1999-11-15 | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1 | -3/+3 | |
to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | |||||
1999-11-12 | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1 | -12/+8 | |
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | |||||
1999-11-10 | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1 | -1/+26 | |
Working Group. Included are tests. | |||||
1999-11-09 | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1 | -0/+31 | |
for RTEMS. |
