* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 1 | -13/+12 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 1 | -45/+34 |
| | | | | Working Group. Included are tests. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 1 | -0/+127 |
for RTEMS. |
