path: root/c/src/exec/itron/include/Makefile.am (follow)
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+27
for RTEMS.
