path: root/c/src/exec/itron/Makefile.am (follow)
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-011-1/+1
| | | | | | | | | | | | | | | * Added macro support to ITRON API. This is known to compile. * Makefile.am: Added macros directory. * configure.in: Removed error check for enabling macros. * macros/.cvsignore, macros/Makefile.am, macros/rtems/.cvsignore, macros/rtems/Makefile.am, macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-1/+1
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-1/+1
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-1/+1
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+11
for RTEMS.
