* wrapup/Makefile.am: Add install-hook.
Remove SIZE_RTEMS.
* include/rtems/fs.h: New, extracted from libio_.h.
* include/rtems/userenv.h: New. extracted from libio_.h.
* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
* libc/libio.c: Initialize more fields to NULL/0 during initialiation.
* include/rtems/libio_.h: Fix freenode macro so it works for sockets
which do not have the full set of filesystem operations and are
initialized via something other than open().
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX
is defined on GNU/Linux (RedHat 6.2 distribution).
* libc/unixlibc.c: Added stubs for rtems_io_register_name() and
rtems_io_lookup_name() so UNIX port would compile the IO manager
sptest that registers /dev/null.
* include/rtems/libio_.h: Added login name, uid, gid, euid, and egid
so they can be part of the private environment.
* include/rtems/libio_.h, libc/chroot.c, libc/privateenv.c:
Private environment and chroot() enhancements and fixes. Comments:
+ privateenv has been modified to let at chroot() to be more
POSIX like Sergei Organov recommended.
+ A task owner lets that rtems_set_private_env() will be
called twice or more times.
+ chroot() can be called without a previous
rtems_set_private_env(); (transpanrently)
+ The second call of rtems_set_private_env() makes a internal
chroot("/") into global imfs_root.
+ chroot() runs like chdir() without a previous chdir("/") with
the global root.
+ The current directory can be in a wrong place like Linux and
many other Unices.
* Alternate email is correo@fernando-ruiz.com
* libc/privateenv.c: New file.
* include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c,
libc/unmount.c: Moved default umask, current working directory,
root, and links followed count into a structure "user environment"
that can then be treated as a unit. This enable giving unique
copies of these to individual threads or collection of threads.
libc/utime.c, libc/write.c:
<rtems/XXX.h>.
Renamed IMFS handler tables to include IMFS prefix.
places to make sure memory allocated for filesystem specifif nodes
gets freed.
would work. At the same time, the initial implementation of F_SETFL
was added. A support routine was added to convert internal libio
flags back to the POSIX style. Eventually the internal representation
should be eliminated in the interest of simplicity and code reduction.
This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
all conflicts.
PROBLEMS
can/will be fixed.
