path: root/c/src/exec/configure.ac (unfollow)
2002-01-162002-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+10
* Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove ITRON_SUBDIRS. * configure.ac: Rework enable_unixlib handling. Add RTEMS_MULTILIBS to cpuopts.h. * include/Makefile.am: Add rtems/fs.h, rtems/userenv.h. Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
2002-01-062002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* Makefile.am: Readded reference to wrapup.
2002-01-042002-01-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+0
* Makefile.am, configure.ac: Remove references to wrapup subdirectory.
2002-01-042001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-24/+28
* configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
2001-10-172001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-18/+2
* configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron. Reflect changes to configuration of rtems, score and sapi subdirs.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-8/+9
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2001-05-072001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
2001-02-122001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* configure.in: AC_DEFINE RTEMS_UNIX if RTEMS_CPU=unix.
2000-12-012000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-8/+0
* configure.in: Removed error check for enabling macros with either POSIX or ITRON API.
2000-07-13Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
2000-07-12Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+2
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_DEBUG a global per-cpu configuration option * Remove RTEMS_DEBUG from targopts.h * Add a global --enable-rtems-debug option disabled by default. * Add RTEMS_DEBUG to cpuopts.h * Remove all references to RTEMS_DEBUG from custom/*.cfg Notes: * RTEMS_DEBUG is set in c/src/exec/configure.in only (RTEMS_CHECK_RTEMS_DEBUG) and should be defined in cpuopts.h only. BSPs should not redefine it, but use the value being provided by cpuopts.h. => With multilibs, users have to choose: Either enable RTEMS_DEBUG for all BSPs and CPU_MODELs of a cpu or not. * Only few BSPs had RTEMS_DEBUG enabled, therefore I set the default to disabled. * This patch influences the per-BSP building scheme. Existing BSPs which set RTEMS_DEBUG in their make-target-options rule might have problems at runtime.
2000-07-10Patch rtems-rc-20000709-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+2
that addresses aspects of the targopts.h multilib related issues. Changes: * Move targopts.h to libbsp/include, because the current targopts.h actually is a per-BSP-header and therefore can not stay below exec/. * Introduce an autoheader generated header file (exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu configuration options only. * Move all autoconf-detectable/configure specified per-cpu option-defines from targopts.h to cpuopts.h. * Add Makefiles to the libbsp/shared directory hierarchy. Notes: * The new per-bsp targopts.h in libbsp includes the per-cpu cpuopts.h. This way, the new targopts.h is kept backward compatible to the old targopts.h and existing BSPs which (carelessly) include targopts.h (i386, ppc) should be kept working when using the multilib-disabled configuration scheme. * cpuopts.h is not yet complete, because the per-BSP make-targopts rules from custom/<BSP>.cfg files can not be applied to files below exec/ when building multilibs. * All files below exec/ should not include targopts.h anymore, but should include cpuopts.h instead. However, eliminating inclusion of targopts.h currently triggers further structural / header file inclusion related issues, because several ports apply BSP or CPU_MODEL specific defines from targopts.h below exec/
2000-07-10Patch rtems-rc-20000708-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+0
that is another small step toward multilibs: Changes: * Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/ * Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme functional. Notes: * --enable-multilibs is still non-functional * This patch should not have any influence on the old building scheme (--disable-multilib should silently fall back to the old building scheme). * running ./bootstrap is required after applying the patch
2000-07-06Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+3
that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
2000-02-08Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+1
that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling)
2000-01-31Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+0
that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
1999-12-03Patch rtems-rc-19991123-rc-3.diff from Ralf CorsepiusJoel Sherrill1-1/+1
<corsepiu@faw.uni-ulm.de>: The patch below provides * automake support for score/cpu/powerpc * The hack to propagate values from *.cfg to automake configuration * A fix for librdbg/powerpc/mcp750/Makefile.am (Was completely corrupted before) * Fixes some files which apparently where missing in rtems-rc-19991123-rc-2.diff * some minor configuration related patches To apply: rm -rf ./c/src/exec/score/cpu/powerpc/wrap patch -p1 < rtems-rc-19991123-rc-3.diff Attention: c/src/exec/score/cpu/[configure.in|aclocal.m4|configure] should be removed after applying the patch. Modifications had been made to the score/cpu/powerpc directory after the snapshot this was based on. In particular, the mpc750 and other_cpu directories had been renamed to new_exception_processing and old_exception_processing. After this patch was applied, modifications were made to account for this.
1999-11-22Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-0/+1
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams.
1999-11-09This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1-1/+12
for RTEMS.
1999-09-07Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1-52/+31
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
1999-08-06Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-10/+3
applied. This modified many Makefiles and custom files and makes many more settings (network, multiprocessing, etc) gnerated by autoconf.
1999-07-30 Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-13/+43
The main topic is replacing the hard-coded values for HAS_MP and HAS_RDBG in custom/*.cfg with per-bsp configuration-time autoconf checks (This is the patch I had mentioned before earlier this week). CHANGES * HAS_MP removed from custom/*.cfg, replaced with configuration time autoconf check * HAS_RDBG removed from custom/*.cfg, replaced with configuration-time autoconf check * NEW: c/src/make/bsp.cfg.in, takes configuration-time checked per-bsp values (i.e. HAS_MP, HAS_RDBG), gets installed as $(prefix)/<bsp>/make/bsp.cfg * NEW: default.cfg includes bsp.cfg - this change is backward compatible. * IMPORT_SRC: apply VPATH instead for ts_386ex/i386ex subdirectory Makefile.ins * HACK: a bug in acpolish mis-handles addtions to makefile variables which are enclosed in gmake conditionals: c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in * Apply inline_dir, HAS_MP and HAS_RDBG for avoiding configuration of unneeded subdirectories in various configure.in files. * Several minor changes in Makefile.ins and configure.ins, wrt. to the order of including *.cfg and defining Makefile variables APPLYING THE PATCH: patch -p1 < rtems-rc-19990709-4.diff ./autogen
1999-07-26This is part of a major patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+102
to move RTEMS more to automake/autoconf and GNU compliance. Finally, here they are: the "big-patch" patches - merged into one big patch (~1.5MB). Sorry for the delay, but testing took much more time than I had expected - esp. reworking the acpolish script triggered many more tiny issues than I had expected (cf. below). At least, now you've got something to spend your weekend with :-. WARNINGS: * I've gone a little (??) further than I had announced before. * Several directories have been moved. * Several files have been added and removed * I have tested it with many BSPs/CPUs and a variety of permutiations of configuration flags, but not with all. * Most parts of the patch are automatically generated, however there are many tiny manual modifications. APPLYING THE PATCH: ./autogen -c mkdir tools mv c/src/exec/score/tools tools/cpu mv c/build-tools tools/build mv c/update-tools tools/update patch -p1 -E < rtems-rc-19990709-0.diff ./autogen If the patch doesn't apply to rtems-cvs, I would suggest that you should try to apply it brute-force and then to run tools/update/rtems-polish.sh -ac -am afterwards. A recursive diff between rtems-19990709 + patch and rtems-cvs + patch then should report only a few dozen significant changes to configuration files which need to be merged manually (IIRC, I did not change any source files). *** Attention: There are files to be removed, moved, copied and added in/to CVS! NEWS/CHANGES: 1. Configuration takes place in 3 stages: 1. per host (toplevel configure script), 2. per target (c/configure), 3. per bsp c/src/configure automatically triggered from ./configure and c/Makefile.am. 2. Building of subdirectory c/ takes place in c/$(target_alias) for cross-targets in c/ for native targets 3. Building of subdirectory c/src takes place in c/${target_alias}/<bsp> for cross-targets, c/<bsp> for native targets 4. c/build-tools moved to tools/build 5. c/src/exec/score/cpu/tools moved to tools/cpu (=cpu-tools split out) 6. c/update-tools moved to tools/update 7. New subdirectory c/src/make, handles files from make/ on a per BSP basis 8. Maintainer mode support: Ie. if configuring with --enable-maintainer-mode disabled (the default), then tracking of many dependencies will be disabled in Makefiles. Esp. many dependencies for auto* generated files will be switched off in Makefiles. Ie. if not using "--enable-maintainer-mode" many auto* generated files will not be updated automatically, i.e. normal users should not be required to have auto* tools anymore (untested). 9. Independent configuration scripts for / (toplevel), tools/build, tools/cpu, tools/update, c/, c/src/, c/src/exec, c/src/lib, c/src/tests, c/src/make 10. Automake support for all directories above and besides c/src 11. "preinstall" now is implemented as depth-first recursive make target 12. host compiled tools (exception bsp-tools) are accessed in location in the build tree instead of inside the build-tree when building RTEMS. 13. RTEMS_ROOT and PROJECT_ROOT now point to directories inside the build-tree - many tiny changes as consequence from this. 14. --with-cross-host support removed (offically announced obsolete by cygnus) 15. Changing the order of building libraries below c/src/lib/ 16. Former toplevel configure script broken into aclocal/*.m4 macros 17. Newlib now detected by configure macros, RTEMS_HAS_NEWLIB removed from *cfg. 18. sptables.h now generated by autoconf 19. Rules for "mkinstalldirs temporary installation tree" moved from c/Makefile to subdirectories. 20. Cpu-tools do not get installed. 21. FIX: Use ACLOCAL_AMFLAGS instead of ACLOCAL = -I ... in Makefile.ams which are in directories with own configure scripts. 22. Hardcoding BSP names into libbsp/.../tools to avoid RTEMS_BSP get overridden from the environment. 22. FIX: Handling of MP_PIECES in various Makefiles 23. FIX: Removing "::" rules from some Makefile.ins 24. FIX: File permission chaos: (-m 444 and -m 555 vs. -m 644 and -m 755) - Now all include files use -m 644. 25. Removed many gnumake-conditionals in Makefile.ins - Partially replaced with automake-conditional, partially replaced with conditionalized Makefile variables (... _yes_V) 26. Massively reworked acpolish: acpolish now parses Makefile.ins and interprets parts of the Makefile.ins. 27. FIX: Some $(wildcard $(srcdir)/*.h) macros removed / replaced with explicit lists of files in Makefile.ins. 28. FIX: Replacing MKLIB with RANLIB in Makefile.ins 29. HACK: Add preinstallation for pc386 specific $(PROJECT_RELEASE)/BootImgs directory ... many more details, I can't recall KNOWN BUGS: 1. make [debug|profile]_install do not do what they are promissing. "make [debug|profile] install" does what "make [debug|profile]_install" has been doing. Proposal: remove [debug|profile]_install 2. Dependencies between temporary installation tree and source tree are not yet handled correctly. 3. Dependencies between temporary installation tree and source tree are handled ineffencently (Using INSTALL_CHANGE instead of make dependencies) 4. RTEMS_ROOT, PROJECT_ROOT, top_builddir, RTEMS_TOPdir now are redundant. 5. The new configure scripts still are in their infancy. They contain redundant checks and might still contain bugs, too. 6. RTEMS autoconf Makefile.ins use a mixture of configuration information gathered in c/$(target_alias)/<bsp>/make and of information collected from their configure scripts. 7. make dist is not fully functional 8. Subdirectory host-/build-/target- configure options (--target, --host, --build) do not conform to Cygnus/GNU conventions. 9. Some RTEMS autoconf Makefile.in's makefile targets are not supported in automake Makefile.ams/ins (e.g. get, clobber). 10. Some automake standard targets are not propagated from toplevel and c/Makefile.am to autoconf subdirectories (eg. make dist). 11. rpcgen generated files are not part of the source-tree (Automake conventions favor supplying generated files inside the source-tree, however there is no support for rpcgen generated files in automake, cf. yacc/lex support in automake). 12. RTEMS_HAS_RDBG handling is flaky. make/*.cfg use RTEMS_HAS_RDBG per CPU, while librdb's sources can only be built per BSP. Raises the more general question whether librdbg located correctly in the source-tree. 13. All make/*cfg files are configured per cpu, currently there is no location to store per-bsp configuration information --> bsp.cfg, per aconfig.h? 14. "make install" without having run "make all" beforehand does not work. 15. handling of --enable-multiprocessing seems to be broken in make/custom/* 16. Makefile.ins still exploit many gmake features. 17. File permisson chaos on libraries (no explict -m for libraries/rels/etc). 18. mcp750 Makefiles are broken (Note: I *do* mean buggy - I am not talking about "not-conforming to conventions", here :-). 19. Dependencies between configure scripts are not handled, eg. aborting "make RTEMS_BSP=<bsp>" can leave the build-tree in an unusable state. 20. "make clean" does not delete <build-tree>/<bsp>. This is intentional for now, because rerunning "make" after "make clean" requires an explicit "make preinstall" afterwards now. This should be done automatically, but doesn't work in this case for now. To work around this problem <build-tree>/<bsp> is kept during "make clean" for now (HACK). TODO: 1. split out host-compiled bsp-tools 2. Use Cygnus/GNU standards for cross-compiling target-subdir (CC=CC_FOR_TARGET .. configure --host=${target_alias} --build=`config.guess'}), to be added to toplevel configure script after splitting out bsp-tools. 3. Exploit per cpu support directory (c/src/<cpu>)- Splitting out per-cpu libraries - Are there any? 4. Further automake support 5. Converting subdirectories into standalone / self-contained subdirectories (Esp. moving their headers to the same common root as their sources, eg. mv lib/include/rtems++ lib/librtems++/include/rtems++) - This is the main obstacle which prevents moving further towards automake. 6. Propagating values from *.cfg into Makefiles instead of propagating them at make time via Makefile-fragments (i.e. try to avoid using *.cfg). 7. Testing on cygwin host (I *do* expect cygwin specific problems). 8. The ARCH in o-$(ARCH)-$(VARIANT) build-subdirectories is not needed anymore. GENERAL ISSUES: 1. Temporary installation tree -- Ian and I seem to disagree basically. Though I think that I understand his argumentation, I do not share it. IMO, his way of using the buildtree is mis-using the build-tree, relying on an inofficial feature of RTEMS's current implementation, which doesn't even work correctly in the current build-tree, though it attempts hard to do so. From my very POV, it unnecessarily complicates the structures of the source- and build-trees. It is not supported by automake (No automatic generation for the necessary rules) and complicates the transition to automake significantly (Generating the rules with an enhanced version of acpolish could be possible). As Ian correctly pointed out, here a management decision is needed - though I don't see the need to draw this decision in short terms. 2. preinstallation generally is a sure means to spoil the structure of the source tree, IMHO (No ranting intended, I am completly serious about this one). eg. through tree dependencies. The worst problem related to this I have found in the meantime is bsp_specs. bsp_specs is part of libbsp, ie. there is *no* way to build *any* part of the source tree *without* having a BSP *preinstalled*. Note: This issue is related to issue 1., but is not identical - The difference is the change of the order make rules have to be triggered. While preinstallation triggers rules spread all over the source tree before a "make all" can be run, a temporary installation tree could also be installed by post "make all" hooks (all-local:, to be run after make all in a directory is completed) if the directories' dependencies would be a tree, 3. Stuctural dependencies between subdirectories. 4. Depth of the source tree (Prevents multilibbing and introduces many unnecessary configure scripts). 5. per cpu vs. per bsp configuration (There are no real per-cpu parts yets :-). 6. automake does not support $makefiles in AC_OUTPUT. Unlike before, we now should try to avoid RTEMS_CHECK_MAKEFILE and to hard-code as much paths to Makefiles as possible. 7. General redesign of the source tree 8. Main installation point - Changing it to ${prefix}/${target_alias}. ? Besides item 8. (which is a must, IMHO), as far as I see most of them can not be solved soon and will remain issues in the mid- to long-term :-. REMARKS: * You (as the maintainer) should always use --enable-maintainer-mode when building RTEMS to ensure that maintainer mode generated files (esp. those in c/src/make) will be updated when make/* files have changed. * Use @RTEMS_BSP@ in Makefile.ins and Makefile.ams below c/src/, $(RTEMS_BSP) or ${RTEMS_BSP} will be overridden from environment variables when using make RTEMS_BSP="....". * c/src/make is a temporary cludge until configuration issues are solved. At the moment it is configured per bsp, but contains per-target/cpu info only. Its main purpose now is to circumvent modifying make/*.cfg files, because I consider make/* to be frozen for backward compatibilty. * This patch should only affect configuration files. At least I do not remember having touched any source files. * To build the bare bsp you now need to mention it in --enable-rtemsbsp. Example: building gensh1 and sh1/bare simultaneously: ../rtems-rc-19990709-1/configure --target=sh-rtems \ --enable-rtemsbsp="bare gensh1" \ --prefix=/tmp/rtems \ --enable-bare-cpu-cflags='-DMHZ=20 -m1 -DCPU_CONSOLE_DEVNAME=\"/dev/null\"' \ --enable-bare-cpu-model=sh7032 \ --enable-maintainer-mode \ --enable-cxx make make install * The next steps in development would be to split out bsp-tools and then to change to Cygnus/GNU canonicalization conventions for building the c/ subdirectory afterwards (i.e. many standard AC_*.m4 macros could be used instead of customized versions) FINAL REMARK: The issues mentioned in the lists above sound much worser than the situation actually is. Most of them are not specific to this patch, but are also valid for the snapshot. I just wrote down what I came across when working on the patch over the last few weeks. I wouldn't be too surprised if you don't like the patch at the current point in development. I am willing to discuss details and problems, I also have no problem if you would post-pone applying this patch to times after 4.1, but rejecting it as a whole for all times would be a false management decision, IMHO. Therefore I would suggest that you, if your time constaints allow it, should at least play a little while with this patch to understand what is going on and before drawing a decision on how to handle this proposal. I know this patch is neither perfect nor complete, but I consider it to be a major breakthrough. Don't be anxious because of the size of the patch, the core of the patch is rather small, the size is mainly the side effect of some systematic cleanups inside the Makefiles (result of acpolish). Feel free to ask if you encounter problems, if you don't understand something or if you meet bugs - I am far from being perfect and am prepared to answer them. Ralf. -- Ralf Corsepius Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW) Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690 mailto:corsepiu@faw.uni-ulm.de FAX: +49/731/501-999 http://www.faw.uni-ulm.de
