path: root/c/src/exec/Makefile.in (follow)
* POSIX not properly conditionalizedJoel Sherrill1998-03-211-1/+1
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+17
