* aclocal/env-rtemsbsp.m4: Remove refs to bare BSP.
* aclocal/enable-bare.m4: Remove.
* configure.ac: Remove BARE_CPU_MODEL.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
* configure.ac: Explicitly pass --includedir and --libdir to
cpukit/configure.
* configure.ac: Reflect changes testsuites/configure.ac and
cpukit/configure.ac.
* configure.ac: Reflect changes to testsuites's configuration.
* acinclude.m4: Fix loosing arguments when configuring cpukit and
testsuites (Was exposed with --enable-multilib, only).
Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR.
Add RTEMS_BSP_CONFIG_SUBDIR.
* configure.ac: Reflect changes to acinclude.m4. Reflect new args to
testsuites's configure.
* aclocal/rtems-top.m4: Remove ENDIF hack.
Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am:
Remove.
* librdbg/src/Makefile.am: Merge-in librdbg/src/i386/Makefile.am,
librdbg/src/m68k/Makefile.am, librdbg/src/powerpc/Makefile.am.
* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* configure.ac: Use AS_HELP_STRING(ada).
* configure.ac: Add powerpc's <bsp>/wrapup/Makefile.am detection
hack.
* aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP).
Add AM_CONDITIONAL(HAS_MP).
* wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(Deprecated by autoconf 2.59).
* configure.ac: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* configure.ac: Reflect changes to cpukit.
* configure.ac: Remove libnetworking/wrapup/Makefile.
* wrapup/Makefile.am: Reflect change to libnetworking/*.
Use libnetworking/*/lib*.a instead of libnetapps.a
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake-1.8.2.
Add RTEMS_PROG_CCAS.
Add AM_PROG_CC_C_O.
* automake/compile.am: Remove LINK_LIBS (Unused).
* configure.ac: Reflect changes to RTEMS_CONFIG_SUBDIR.
* configure.ac: Reflect changes to librdbg.
* configure.ac: Remove lib/libbsp/shared/Makefile,
lib/libbsp/shmdr/Makefile.
* configure.ac: Remove libchip/ide/Makefile, libchip/network/Makefile,
libchip/serial/Makefile, libchip/rtc/Makefile.
* configure.ac: Reflect having moved tests to ../../testsuites.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/check-cpu.m4: Remove.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Make presence of tests/ optional.
* configure.ac: Remove stray comments.
* automake/local.am, automake/host.am: Remove "debug".
* lib/Makefile.am: New (Required by 'make dist').
* lib/ChangeLog: Remove.
* lib/.cvsignore: Cleanup.
* configure.ac: Reflect having added lib/Makefile.am.
* configure.ac: Merge-in lib/libcpu/configure.ac.
Merge-in lib/libbsp/configure.ac.
* configure.ac: Use relative dir to make/${RTEMS_BSP}.cache.
* configure.ac: Merge-in librdbg/configure.ac.
* configure.ac: Merge-in libnetworking/configure.ac.
Merge-in parts of librdbg/configure.ac.
* configure.ac: Merge-in libchip/configure.ac.
Merge-in optman/configure.ac.
* configure.ac: Remove support for profile-variant.
* configure.ac: Remove libmisc.
* configure.ac: Append RTEMS_CPU_MODEL to ac_configure_args.
Resort cache-checking.
* configure.ac: Expand RTEMS_CHECK_BSP_CACHE.
* configure.ac: Append CPU_CFLAGS, CFLAGS_OPTIMIZE_V,
CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY to
ac_configure_args.
* configure.ac: Use test "$RTEMS_BSP_FAMILY" != "bare" to setup
HAS_LIBBSP conditional (Solaris/bash incompatibility fix).
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* configure.ac: Add ada-tests.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* configure.ac: Add BSP_SUBDIRS.
* Makefile.am: Use BSP_SUBDIRS to setup SUBDIRS.
* configure.ac: Remove AC_CONFIG_SUBDIR(wrapup).
Cosmetic cleanups.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Append BARE_CPU_MODEL tp make/@RTEMS_BSP@.cache
creation (Make the bare BSP happy).
* configure.ac: Ditto.
