Update #3254.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* automake/compile.am: Use hard-coded RTEMS_* flags.
* configure.ac: Pass CFLAGS to cpukit configure.
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
* aclocal/env-rtemsbsp.m4:
Comment out CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Add AM_CXXFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE, ASFLAGS.
Cleanup comments.
* automake/compile.am: Remove build-variant support.
* Makefile.am: Don't include host.am.
* automake/compile.am: Further cleanups.
* automake/lib.am: Remove (Unused).
* wrapup/Makefile.am: Don't include lib.am.
* automake/compile.am: Use automake compilation rules.
* aclocal/rtems-top.m4: Remove check for version.m4.
* automake/compile.am: Remove LINK_OBJS, LINK_FILES (Unused).
* automake/compile.am: Add RTEMS_RELLDFLAGS.
Remove XLDFLAGS.
* wrapup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* automake/lib.am: Remove TMPINSTALL_FILES.
* automake/compile.am: Remove LINK_LIBS (Unused).
* configure.ac: Reflect changes to RTEMS_CONFIG_SUBDIR.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* wrapup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* acinclude.m4: Rework RTEMS_CONFIG_SUBDIR.
* Makefile.am: Reflect changes to RTEMS_CONFIG_SUBDIR.
* aclocal/lead-dot.m4: Remove (Provided by automake-1.8).
* automake/compile.am: Use mkdir_p instead of mkinstalldirs.
* automake/lib.am: Use mkdir_p instead of mkdir.
Remove $(PROJECT_RELEASE)/lib/$(dirstamp) handling.
* aclocal/env-rtemsbsp.m4: Remove bsplibdir.
Cleanups.
* aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir).
* automake/lib.am: Remove project_libdir.
* wrapup/Makefile.am: Reworked.
* Makefile.am: Cosmetics.
* automake/lib.am: Add project_libdir.
Add preinstallation dirstamp support.
* automake/compile.am: Remove $(ARCH):-rule.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* automake/force-preinstall.am: Remove.
* configure.ac: Remove stray comments.
* automake/local.am, automake/host.am: Remove "debug".
* automake/compile.am, automake/force-preinstall.am,
automake/host.am, automake/lib.am, automake/local.am,
automake/subdirs.am: New (copied from ../../automake).
