path: root/c/src/automake/lib.am (follow)
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-8/+2
| | | | | | | | | * aclocal/lead-dot.m4: Remove (Provided by automake-1.8). * automake/compile.am: Use mkdir_p instead of mkinstalldirs. * automake/lib.am: Use mkdir_p instead of mkdir. Remove $(PROJECT_RELEASE)/lib/$(dirstamp) handling. * aclocal/env-rtemsbsp.m4: Remove bsplibdir. Cleanups.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-2/+0
| | | | | | * aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir). * automake/lib.am: Remove project_libdir. * wrapup/Makefile.am: Reworked.
* 2003-12-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-051-1/+4
| | | | | | * Makefile.am: Cosmetics. * automake/lib.am: Add project_libdir. Add preinstallation dirstamp support.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-0/+23
* automake/compile.am, automake/force-preinstall.am, automake/host.am, automake/lib.am, automake/local.am, automake/subdirs.am: New (copied from ../../automake).
