path: root/c/src/ada/rtems-port.adb (follow)
* 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-161-0/+137
* ada/Makefile.am, ada/preinstall.am, ada/rtems.adb, ada/rtems.ads: Split RTEMS Ada95 binding into a master package and a child package per Manager. This is better Ada style. * ada/rtems-barrier.adb, ada/rtems-barrier.ads, ada/rtems-clock.adb, ada/rtems-clock.ads, ada/rtems-cpu_usage.ads, ada/rtems-debug.adb, ada/rtems-debug.ads, ada/rtems-event.adb, ada/rtems-event.ads, ada/rtems-extension.adb, ada/rtems-extension.ads, ada/rtems-fatal.adb, ada/rtems-fatal.ads, ada/rtems-interrupt.ads, ada/rtems-io.adb, ada/rtems-io.ads, ada/rtems-message_queue.adb, ada/rtems-message_queue.ads, ada/rtems-object.adb, ada/rtems-object.ads, ada/rtems-partition.adb, ada/rtems-partition.ads, ada/rtems-port.adb, ada/rtems-port.ads, ada/rtems-rate_monotonic.adb, ada/rtems-rate_monotonic.ads, ada/rtems-region.adb, ada/rtems-region.ads, ada/rtems-semaphore.adb, ada/rtems-semaphore.ads, ada/rtems-signal.adb, ada/rtems-signal.ads, ada/rtems-stack_checker.ads, ada/rtems-tasks.adb, ada/rtems-tasks.ads, ada/rtems-timer.adb, ada/rtems-timer.ads: New files.
