2013-03-08 | RTEMS: Delete ChangeLog files. | Gedare Bloom | 1 | -217/+0 | |
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
2009-08-24 | 2009-08-24 Christian Mauderer <christian.mauderer@embedded-brains.de> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb: Use rtems_debug_is_enabled(). | |||||
2008-12-16 | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb: Use public API not _TOD_Microseconds_per_tick. | |||||
2008-12-03 | 2008-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
PR 1345/Ada * rtems.ads: RTEMS boolean type is now C99 bool which is not an unsigned32. | |||||
2008-11-20 | 2008-11-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 1339/Ada * rtems.adb, rtems.ads: Re-add IO Manager to Ada binding. | |||||
2008-05-06 | 2008-05-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Fix prototype. | |||||
2008-03-11 | 2008-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+13 | |
* rtems.adb, rtems.ads: Refactored rtems_clock_get into 5 methods which are single purpose and more strongly typed. They are: rtems_clock_get_tod - Get TOD in Classic API structure rtems_clock_get_tod_timeval - Get TOD in struct timeval rtems_clock_get_seconds_since_epoch - Get TOD as seconds since 1988 rtems_clock_get_ticks_since_boot - Get ticks since boot rtems_clock_get_ticks_per_second - Get ticks per second Also switch from using 'Unchecked_Access to 'Access. Added pragma Convention C as required by gcc > 4.3. Changed style of parenthese on subprogram calls to match GNAT. | |||||
2008-02-04 | 2008-02-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Correct binding to Object_Get_Name. Now works. | |||||
2008-02-01 | 2008-02-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* rtems.adb, rtems.ads: Object_Get_Name now has a proper implementation thanks to a binding tip from Laurent Guerby. | |||||
2008-02-01 | 2008-02-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Add Ada binding for Object Services. | |||||
2007-12-04 | 2007-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb: Add missing semicolon. | |||||
2007-11-27 | 2007-11-27 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Fixed errors in the barrier binding. | |||||
2007-10-25 | 2007-10-25 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Added some more missing bindings. | |||||
2007-10-18 | 2007-10-18 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Added a missing binding. | |||||
2007-10-10 | 2007-10-10 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 1 | -0/+5 | |
* rtems.adb, rtems.ads: Cleaned up binding and removed bindings for things that are not reasonable to do in Ada. | |||||
2007-10-01 | 2007-10-01 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* rtems.adb, rtems.ads: Most of single processor Ada tests now build. Some run. | |||||
2007-09-05 | 2007-09-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb: Fix warnings. | |||||
2007-04-02 | 2007-04-02 Jennifer Averett <jennifer.averrett@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb, rtems.ads: Update. | |||||
2005-05-23 | 2005-05-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb: Fix variable name. | |||||
2005-05-23 | 2005-05-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR rtems_misc/795 * rtems.ads: Fix parameter ordering. | |||||
2005-05-03 | 2005-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb: Remove gcc 4.x warnings. | |||||
2005-05-02 | 2005-05-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
PR 782/rtems * rtems.ads: Remove stray ';'. * rtems.adb: Stub Task_Variable_Add, Task_Variable_Get, Task_Variable_Delete. | |||||
2005-05-02 | Remove bogus ChangeLog entry. | Ralf Corsepius | 1 | -2/+2 | |
2005-05-02 | changes | Ralf Corsepius | 1 | -0/+5 | |
2004-01-19 | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Add PREINSTALL_DIRS. | |||||
2004-01-14 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Move include_adadir into RTEMS_ADA condional block. Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | |||||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use include_ada_HEADERS. | |||||
2003-11-30 | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Preinstall adainclude_HEADERS. Add $(dirstamp) to preinstallation rules. | |||||
2003-11-25 | 2003-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 528/rtems_misc * rtems.ads: Add task variables to Ada binding. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* rtems-multiprocessing.adb, rtems-multiprocessing.ads, rtems.adb, rtems.ads: URL for license changed. | |||||
2003-07-08 | 2003-07-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 418/ada * rtems.adb: Add missing all keyword to derefence pointer. | |||||
2003-07-08 | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2003-02-03 | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
PR 338/filesystem * rtems.adb, rtems.ads: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | |||||
2003-01-03 | 2003-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* rtems.ads: Corrected Configuration_Table record definition to match current RTEMS source. sp01 now runs. | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Fix package name. | |||||
2002-10-29 | 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Remove AC_ENABLE_MULTILIB. * Makefile.am: Add CVS-Id. | |||||
2002-10-25 | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-08-30 | 2002-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.adb (IO_Initialize): Make this match the C prototype. | |||||
2002-08-27 | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems.ads: Corrected binding for Io_Initialize. | |||||
2002-08-23 | 2001-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* configure.ac: New. * Makefile.am: New. * .cvsignore: New. | |||||
2002-02-01 | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When. | |||||
2002-02-01 | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* ChangeLog: New file. |
