1998-10-29 | Cleanup. | Joel Sherrill | 1 | -1/+6 | |
1997-06-04 | new file | Joel Sherrill | 2 | -0/+90 | |
1997-06-03 | corrected name of test suite | Joel Sherrill | 30 | -30/+30 | |
1997-06-03 | fixed comment | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | Removed configuration information. | Joel Sherrill | 1 | -54/+0 | |
1997-06-03 | new file | Joel Sherrill | 4 | -0/+181 | |
1997-06-03 | Removed Configuration Information. | Joel Sherrill | 1 | -54/+0 | |
1997-06-03 | new files. | Joel Sherrill | 2 | -0/+89 | |
1997-06-03 | Removed configuration information. | Joel Sherrill | 1 | -42/+0 | |
1997-06-03 | new files | Joel Sherrill | 5 | -0/+362 | |
1997-06-03 | new file. | Joel Sherrill | 1 | -0/+9 | |
1997-06-03 | corrected to compile with the new binding. | Joel Sherrill | 5 | -35/+119 | |
1997-06-03 | Corrected for this test. | Joel Sherrill | 1 | -0/+1 | |
1997-06-03 | Added correct contents | Joel Sherrill | 1 | -0/+57 | |
1997-06-03 | new file | Joel Sherrill | 4 | -0/+700 | |
1997-06-03 | Corrected maximum number of messages to be non-zero | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | removed reference to Stub Device Driver | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | Replaced prototype for Last_Task which was accidentally removed when | Joel Sherrill | 1 | -0/+14 | |
the Configuration Tables were deleted from the Ada specification. | |||||
1997-06-03 | Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | Fixed incorrect invocation of Message_Queue_Create | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | fixed typo which resulted in Message_Queue_Create being invoked incorrectly. | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | Fixed calls to Message_Queue_Create to include maximum message size | Joel Sherrill | 9 | -5/+14 | |
parameter. | |||||
1997-06-03 | Changed to variable length messages. | Joel Sherrill | 17 | -66/+219 | |
1997-06-03 | Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. | Joel Sherrill | 11 | -11/+11 | |
1997-06-03 | Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | Fixed all references to Semaphore_Create to have the correct | Joel Sherrill | 7 | -5/+12 | |
argument sequence. | |||||
1997-06-03 | New file. | Joel Sherrill | 28 | -0/+1045 | |
1997-06-03 | new file | Joel Sherrill | 28 | -0/+1596 | |
1997-06-03 | Removed Configuration Table information. | Joel Sherrill | 30 | -1170/+0 | |
1997-06-03 | Corrected call to Semaphore_Create to have the proper calling sequence | Joel Sherrill | 1 | -0/+2 | |
1997-06-03 | Removed Configuration Table information | Joel Sherrill | 1 | -38/+0 | |
1997-06-03 | new file | Joel Sherrill | 2 | -0/+94 | |
1997-06-03 | Removed unnecessary dependency on RTEMS_Test_Support which existed | Joel Sherrill | 1 | -1/+0 | |
in the RTEMS Ada implementation but does not exist in this binding. | |||||
1997-06-03 | new file | Joel Sherrill | 6 | -0/+209 | |
1997-06-03 | removed reference to the Stub Device Driver | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | Changed mode and priority of initialization task. | Joel Sherrill | 2 | -5/+2 | |
1997-06-03 | Changed attribute of Initialization Task to Floating_Point | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | new files | Joel Sherrill | 2 | -0/+56 | |
1997-06-03 | new file | Joel Sherrill | 3 | -0/+326 | |
1997-06-03 | new file | Joel Sherrill | 14 | -0/+504 | |
1997-06-03 | Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | new files | Joel Sherrill | 2 | -0/+82 | |
1997-06-03 | Switched to proper types for booleans and increased the stack space | Joel Sherrill | 2 | -5/+6 | |
for the tasks in this test. | |||||
1997-06-03 | Modifed to make the test run to completion. Primarily provided | Joel Sherrill | 2 | -32/+96 | |
the Buffer type and support routines although some work was required to account for the directives which required message size information. | |||||
1997-06-03 | Commented out exception handling code since these routines are not | Joel Sherrill | 1 | -9/+9 | |
called from Ada tasks. It is questionable whether the exception handling would work correctly. | |||||
1997-06-03 | removed with of unchecked_conversion | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | sptest.adb: update Semaphore_Create calling sequence | Joel Sherrill | 2 | -1/+8 | |
sp12.adb: doubled the initialization task stack size | |||||
1997-06-03 | Fixed problems which prevented the test from compiling and running to | Joel Sherrill | 3 | -85/+157 | |
completion. | |||||
1997-06-03 | changed reference for Configuration Table from BSP to RTEMS. | Joel Sherrill | 1 | -2/+1 | |
1997-06-03 | *** empty log message *** | Joel Sherrill | 19 | -18/+13 | |
