* | updated to run | Joel Sherrill | 1997-06-03 | 2 | -15/+42 | |
* | New style main procedure which creates the test's RTEMS initialization task | Joel Sherrill | 1997-06-03 | 28 | -27/+687 | |
| | | | | | | as an RTEMS task. This avoid problems resulting from differences in the tasking mode/priority of Ada tasks from the typical way an RTEMS initialization task is created. | |||||
* | added subtract of 1 to Task_Number to account for the creation | Joel Sherrill | 1997-06-02 | 1 | -1/+1 | |
| | | | | of the initialization task | |||||
* | *** empty log message *** | Joel Sherrill | 1997-06-02 | 1 | -1/+0 | |
* | new file | Joel Sherrill | 1997-06-02 | 1 | -0/+33 | |
* | readded body for "main" procedures | Joel Sherrill | 1997-06-02 | 47 | -23/+744 | |
* | removed configuration table definition in Ada | Joel Sherrill | 1997-06-02 | 23 | -1290/+0 | |
* | new file - automatically generated by a script | Joel Sherrill | 1997-06-02 | 55 | -0/+0 | |
* | Changed license and copyright notice. | Joel Sherrill | 1997-06-02 | 5 | -52/+25 | |
| | | | | Added "development" style CVS Id | |||||
* | New file -- works in conjunction with support/init.c. | Joel Sherrill | 1997-06-02 | 1 | -0/+33 | |
* | Removed Ada Configuration Table definition. | Joel Sherrill | 1997-06-02 | 1 | -55/+0 | |
* | added screen files from 3.2.1 | Joel Sherrill | 1997-06-02 | 56 | -0/+1399 | |
* | added new files from test area. | Joel Sherrill | 1997-06-02 | 5 | -0/+520 | |
| | | | | This code has successfully been used to run sp01. | |||||
* | modified copyright notice to be the same as RTEMS 4.0.0. | Joel Sherrill | 1997-06-02 | 176 | -1056/+1056 | |
| | | | | changed the CVS ID string to be a "development" version. | |||||
* | Initial revision | Joel Sherrill | 1997-06-02 | 176 | -0/+39236 | |
