TOD_MILLISECONDS_TO_TICKS().
for details.
* configure.ac: Rename RTEMS_API into _RTEMS_API.
* ada-tests/mptests/mp01/mp01.adb, ada-tests/mptests/mp01/mptest.adb,
ada-tests/mptests/mp01/mptest.ads,
ada-tests/mptests/mp01/node1/mp01_node1.adb,
ada-tests/mptests/mp01/node2/mp01_node2.adb,
ada-tests/mptests/mp02/mptest.adb, ada-tests/mptests/mp02/mptest.ads,
ada-tests/mptests/mp02/node1/mp02_node1.adb,
ada-tests/mptests/mp02/node2/mp02_node2.adb,
ada-tests/mptests/mp03/mptest.adb, ada-tests/mptests/mp03/mptest.ads,
ada-tests/mptests/mp03/node1/mp03_node1.adb,
ada-tests/mptests/mp03/node2/mp03_node2.adb,
ada-tests/mptests/mp04/mptest.adb, ada-tests/mptests/mp04/mptest.ads,
ada-tests/mptests/mp04/node1/mp04_node1.adb,
ada-tests/mptests/mp04/node2/mp04_node2.adb,
ada-tests/mptests/mp05/mptest.adb, ada-tests/mptests/mp05/mptest.ads,
ada-tests/mptests/mp05/node1/mp05_node1.adb,
ada-tests/mptests/mp05/node2/mp05_node2.adb,
ada-tests/mptests/mp06/mptest.adb, ada-tests/mptests/mp06/mptest.ads,
ada-tests/mptests/mp06/node1/mp06_node1.adb,
ada-tests/mptests/mp06/node2/mp06_node2.adb,
ada-tests/mptests/mp07/mptest.adb, ada-tests/mptests/mp07/mptest.ads,
ada-tests/mptests/mp07/node1/mp07_node1.adb,
ada-tests/mptests/mp07/node2/mp07_node2.adb,
ada-tests/mptests/mp08/mptest.adb, ada-tests/mptests/mp08/mptest.ads,
ada-tests/mptests/mp08/node1/mp08_node1.adb,
ada-tests/mptests/mp08/node2/mp08_node2.adb,
ada-tests/mptests/mp09/mptest.adb, ada-tests/mptests/mp09/mptest.ads,
ada-tests/mptests/mp09/node1/mp09_node1.adb,
ada-tests/mptests/mp09/node2/mp09_node2.adb,
ada-tests/mptests/mp10/mptest.adb, ada-tests/mptests/mp10/mptest.ads,
ada-tests/mptests/mp10/node1/mp10_node1.adb,
ada-tests/mptests/mp10/node2/mp10_node2.adb,
ada-tests/mptests/mp11/mptest.adb, ada-tests/mptests/mp11/mptest.ads,
ada-tests/mptests/mp11/node1/mp11_node1.adb,
ada-tests/mptests/mp11/node2/mp11_node2.adb,
ada-tests/mptests/mp12/mptest.adb, ada-tests/mptests/mp12/mptest.ads,
ada-tests/mptests/mp12/node1/mp12_node1.adb,
ada-tests/mptests/mp12/node2/mp12_node2.adb,
ada-tests/mptests/mp13/mptest.adb, ada-tests/mptests/mp13/mptest.ads,
ada-tests/mptests/mp13/node1/mp13_node1.adb,
ada-tests/mptests/mp13/node2/mp13_node2.adb,
ada-tests/mptests/mp14/mptest.adb, ada-tests/mptests/mp14/mptest.ads,
ada-tests/mptests/mp14/node1/mp14_node1.adb,
ada-tests/mptests/mp14/node2/mp14_node2.adb,
ada-tests/samples/base_mp/mptest.adb,
ada-tests/samples/base_mp/mptest.ads,
ada-tests/samples/base_sp/base_sp.adb,
ada-tests/samples/base_sp/sptest.adb,
ada-tests/samples/base_sp/sptest.ads,
ada-tests/samples/hello/hello.adb,
ada-tests/samples/hello/sptest.adb,
ada-tests/samples/hello/sptest.ads,
ada-tests/samples/nsecs/nsecs.adb,
ada-tests/samples/nsecs/sptest.adb,
ada-tests/samples/nsecs/sptest.ads,
ada-tests/samples/ticker/sptest.adb,
ada-tests/samples/ticker/sptest.ads,
ada-tests/samples/ticker/ticker.adb, ada-tests/sptests/sp01/sp01.adb,
ada-tests/sptests/sp01/sptest.adb, ada-tests/sptests/sp01/sptest.ads,
ada-tests/sptests/sp02/sp02.adb, ada-tests/sptests/sp02/sptest.adb,
ada-tests/sptests/sp02/sptest.ads, ada-tests/sptests/sp03/sp03.adb,
ada-tests/sptests/sp03/sptest.adb, ada-tests/sptests/sp03/sptest.ads,
ada-tests/sptests/sp04/sp04.adb, ada-tests/sptests/sp04/sptest.adb,
ada-tests/sptests/sp04/sptest.ads, ada-tests/sptests/sp05/sp05.adb,
ada-tests/sptests/sp05/sptest.adb, ada-tests/sptests/sp05/sptest.ads,
ada-tests/sptests/sp06/sp06.adb, ada-tests/sptests/sp06/sptest.adb,
ada-tests/sptests/sp06/sptest.ads, ada-tests/sptests/sp07/sp07.adb,
ada-tests/sptests/sp07/sptest.adb, ada-tests/sptests/sp07/sptest.ads,
ada-tests/sptests/sp08/sp08.adb, ada-tests/sptests/sp08/sptest.adb,
ada-tests/sptests/sp08/sptest.ads, ada-tests/sptests/sp09/sp09.adb,
ada-tests/sptests/sp09/sptest.adb, ada-tests/sptests/sp09/sptest.ads,
ada-tests/sptests/sp11/sp11.adb, ada-tests/sptests/sp11/sptest.adb,
ada-tests/sptests/sp11/sptest.ads, ada-tests/sptests/sp12/sp12.adb,
ada-tests/sptests/sp12/sptest.adb, ada-tests/sptests/sp12/sptest.ads,
ada-tests/sptests/sp13/sp13.adb, ada-tests/sptests/sp13/sptest.adb,
ada-tests/sptests/sp13/sptest.ads, ada-tests/sptests/sp14/sp14.adb,
ada-tests/sptests/sp14/sptest.adb, ada-tests/sptests/sp14/sptest.ads,
ada-tests/sptests/sp15/sp15.adb, ada-tests/sptests/sp15/sptest.adb,
ada-tests/sptests/sp15/sptest.ads, ada-tests/sptests/sp16/sp16.adb,
ada-tests/sptests/sp16/sptest.adb, ada-tests/sptests/sp16/sptest.ads,
ada-tests/sptests/sp17/sp17.adb, ada-tests/sptests/sp17/sptest.adb,
ada-tests/sptests/sp17/sptest.ads, ada-tests/sptests/sp19/sp19.adb,
ada-tests/sptests/sp19/sptest.adp, ada-tests/sptests/sp19/sptest.ads,
ada-tests/sptests/sp20/sp20.adb, ada-tests/sptests/sp20/sptest.adb,
ada-tests/sptests/sp20/sptest.ads, ada-tests/sptests/sp22/sp22.adb,
ada-tests/sptests/sp22/sptest.adb, ada-tests/sptests/sp22/sptest.ads,
ada-tests/sptests/sp23/sp23.adb, ada-tests/sptests/sp23/sptest.adb,
ada-tests/sptests/sp23/sptest.ads, ada-tests/sptests/sp24/sp24.adb,
ada-tests/sptests/sp24/sptest.adb, ada-tests/sptests/sp24/sptest.ads,
ada-tests/sptests/sp25/sp25.adb, ada-tests/sptests/sp25/sptest.adb,
ada-tests/sptests/sp25/sptest.ads,
ada-tests/support/test_support.adb, ada-tests/tmtests/tm01/tm01.adb,
ada-tests/tmtests/tm01/tmtest.adb, ada-tests/tmtests/tm01/tmtest.ads,
ada-tests/tmtests/tm02/tm02.adb, ada-tests/tmtests/tm02/tmtest.adb,
ada-tests/tmtests/tm02/tmtest.ads, ada-tests/tmtests/tm03/tm03.adb,
ada-tests/tmtests/tm03/tmtest.adb, ada-tests/tmtests/tm03/tmtest.ads,
ada-tests/tmtests/tm04/tm04.adb, ada-tests/tmtests/tm04/tmtest.adb,
ada-tests/tmtests/tm04/tmtest.ads, ada-tests/tmtests/tm05/tm05.adb,
ada-tests/tmtests/tm05/tmtest.adb, ada-tests/tmtests/tm05/tmtest.ads,
ada-tests/tmtests/tm06/tm06.adb, ada-tests/tmtests/tm06/tmtest.adb,
ada-tests/tmtests/tm06/tmtest.ads, ada-tests/tmtests/tm07/tm07.adb,
ada-tests/tmtests/tm07/tmtest.adb, ada-tests/tmtests/tm07/tmtest.ads,
ada-tests/tmtests/tm08/tm08.adb, ada-tests/tmtests/tm08/tmtest.adb,
ada-tests/tmtests/tm08/tmtest.ads, ada-tests/tmtests/tm09/tm09.adb,
ada-tests/tmtests/tm09/tmtest.adb, ada-tests/tmtests/tm09/tmtest.ads,
ada-tests/tmtests/tm10/tm10.adb, ada-tests/tmtests/tm10/tmtest.adb,
ada-tests/tmtests/tm10/tmtest.ads, ada-tests/tmtests/tm11/tm11.adb,
ada-tests/tmtests/tm11/tmtest.adb, ada-tests/tmtests/tm11/tmtest.ads,
ada-tests/tmtests/tm12/tm12.adb, ada-tests/tmtests/tm12/tmtest.adb,
ada-tests/tmtests/tm12/tmtest.ads, ada-tests/tmtests/tm13/tm13.adb,
ada-tests/tmtests/tm13/tmtest.adb, ada-tests/tmtests/tm13/tmtest.ads,
ada-tests/tmtests/tm14/tm14.adb, ada-tests/tmtests/tm14/tmtest.adb,
ada-tests/tmtests/tm14/tmtest.ads, ada-tests/tmtests/tm15/tm15.adb,
ada-tests/tmtests/tm15/tmtest.adb, ada-tests/tmtests/tm15/tmtest.ads,
ada-tests/tmtests/tm16/tm16.adb, ada-tests/tmtests/tm16/tmtest.adb,
ada-tests/tmtests/tm16/tmtest.ads, ada-tests/tmtests/tm17/tm17.adb,
ada-tests/tmtests/tm17/tmtest.adb, ada-tests/tmtests/tm17/tmtest.ads,
ada-tests/tmtests/tm18/tm18.adb, ada-tests/tmtests/tm18/tmtest.adb,
ada-tests/tmtests/tm18/tmtest.ads, ada-tests/tmtests/tm19/tm19.adb,
ada-tests/tmtests/tm19/tmtest.adb, ada-tests/tmtests/tm19/tmtest.ads,
ada-tests/tmtests/tm20/tm20.adb, ada-tests/tmtests/tm20/tmtest.adb,
ada-tests/tmtests/tm20/tmtest.ads, ada-tests/tmtests/tm21/tm21.adb,
ada-tests/tmtests/tm21/tmtest.adb, ada-tests/tmtests/tm21/tmtest.ads,
ada-tests/tmtests/tm22/tm22.adb, ada-tests/tmtests/tm22/tmtest.adb,
ada-tests/tmtests/tm22/tmtest.ads, ada-tests/tmtests/tm23/tm23.adb,
ada-tests/tmtests/tm23/tmtest.adb, ada-tests/tmtests/tm23/tmtest.ads,
ada-tests/tmtests/tm24/tm24.adb, ada-tests/tmtests/tm24/tmtest.adb,
ada-tests/tmtests/tm24/tmtest.ads, ada-tests/tmtests/tm25/tm25.adb,
ada-tests/tmtests/tm25/tmtest.adb, ada-tests/tmtests/tm25/tmtest.ads,
ada-tests/tmtests/tm28/tm28.adb, ada-tests/tmtests/tm28/tmtest.adb,
ada-tests/tmtests/tm28/tmtest.ads, ada-tests/tmtests/tm29/tm29.adb,
ada-tests/tmtests/tm29/tmtest.adb, ada-tests/tmtests/tm29/tmtest.ads,
ada-tests/tmtests/tmck/tmck.adb, ada-tests/tmtests/tmck/tmtest.adb,
ada-tests/tmtests/tmck/tmtest.ads,
ada-tests/tmtests/tmoverhd/dummy_rtems.adb,
ada-tests/tmtests/tmoverhd/dummy_rtems.ads,
ada-tests/tmtests/tmoverhd/tmoverhd.adb,
ada-tests/tmtests/tmoverhd/tmtest.adb,
ada-tests/tmtests/tmoverhd/tmtest.ads: Account for RTEMS binding
child package rework. Eliminate all warnings.
PR 1655/testing:
* ada.am: Reflect changes to testsuites/automake/compile.am.
* mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/mp01_node2.adb,
mptests/mp02/node1/mp02_node1.adb, mptests/mp02/node2/mp02_node2.adb,
mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/mp03_node2.adb,
mptests/mp04/node1/mp04_node1.adb, mptests/mp04/node2/mp04_node2.adb,
mptests/mp05/mptest.adb, mptests/mp05/node1/mp05_node1.adb,
mptests/mp05/node2/mp05_node2.adb, mptests/mp06/node1/mp06_node1.adb,
mptests/mp06/node2/mp06_node2.adb, mptests/mp07/node1/mp07_node1.adb,
mptests/mp07/node2/mp07_node2.adb, mptests/mp08/node1/mp08_node1.adb,
mptests/mp08/node2/mp08_node2.adb, mptests/mp09/node1/mp09_node1.adb,
mptests/mp09/node2/mp09_node2.adb, mptests/mp10/node1/mp10_node1.adb,
mptests/mp10/node2/mp10_node2.adb, mptests/mp11/node1/mp11_node1.adb,
mptests/mp11/node2/mp11_node2.adb, mptests/mp12/node1/mp12_node1.adb,
mptests/mp12/node2/mp12_node2.adb, mptests/mp13/node1/mp13_node1.adb,
mptests/mp13/node2/mp13_node2.adb, mptests/mp14/mptest.adb,
mptests/mp14/node1/mp14_node1.adb, mptests/mp14/node2/mp14_node2.adb,
sptests/sp09/sptest.adb, sptests/sp11/sptest.adb,
sptests/sp13/sptest.adb, sptests/sp16/sptest.adb,
support/test_support.adb: Lines are now all less than 80 columns.
* samples/base_sp/sptest.adb, samples/hello/sptest.adb,
samples/nsecs/sptest.adb, samples/ticker/sptest.adb,
sptests/sp01/sptest.adb, sptests/sp02/sptest.adb,
sptests/sp03/sptest.adb, sptests/sp04/sptest.adb,
sptests/sp05/sptest.adb, sptests/sp06/sptest.adb,
sptests/sp07/sptest.adb, sptests/sp08/sptest.adb,
sptests/sp12/sptest.adb, sptests/sp13/sptest.adb,
sptests/sp14/sptest.adb, sptests/sp15/sptest.adb,
sptests/sp16/sptest.adb, sptests/sp17/sptest.adb,
sptests/sp19/sptest.adp, sptests/sp20/sptest.adb,
sptests/sp22/sptest.adb, sptests/sp23/sptest.adb,
sptests/sp24/sptest.adb, sptests/sp25/sptest.adb,
sptests/spname01/spname01.adb, sptests/spname01/sptest.adb,
sptests/spname01/sptest.ads, support/address_io.adb, support/init.c,
support/test_support.adb, support/test_support.ads,
support/time_test_support.adb, support/timer_driver.adb,
tmtests/tm01/tmtest.adb, tmtests/tm01/tmtest.ads,
tmtests/tm02/tmtest.adb, tmtests/tm02/tmtest.ads,
tmtests/tm03/tmtest.adb, tmtests/tm03/tmtest.ads,
tmtests/tm04/tmtest.adb, tmtests/tm04/tmtest.ads,
tmtests/tm05/tmtest.adb, tmtests/tm05/tmtest.ads,
tmtests/tm06/tmtest.adb, tmtests/tm06/tmtest.ads,
tmtests/tm07/tmtest.adb, tmtests/tm07/tmtest.ads,
tmtests/tm08/tmtest.adb, tmtests/tm08/tmtest.ads,
tmtests/tm09/tmtest.adb, tmtests/tm09/tmtest.ads,
tmtests/tm10/tmtest.adb, tmtests/tm10/tmtest.ads,
tmtests/tm11/tmtest.adb, tmtests/tm11/tmtest.ads,
tmtests/tm12/tmtest.adb, tmtests/tm12/tmtest.ads,
tmtests/tm13/tmtest.adb, tmtests/tm13/tmtest.ads,
tmtests/tm14/tmtest.adb, tmtests/tm14/tmtest.ads,
tmtests/tm15/tmtest.adb, tmtests/tm15/tmtest.ads,
tmtests/tm16/tmtest.adb, tmtests/tm16/tmtest.ads,
tmtests/tm17/tmtest.adb, tmtests/tm17/tmtest.ads,
tmtests/tm18/tmtest.adb, tmtests/tm18/tmtest.ads,
tmtests/tm19/tmtest.adb, tmtests/tm19/tmtest.ads,
tmtests/tm20/tmtest.adb, tmtests/tm20/tmtest.ads,
tmtests/tm21/tmtest.adb, tmtests/tm21/tmtest.ads,
tmtests/tm22/tmtest.adb, tmtests/tm22/tmtest.ads,
tmtests/tm23/tmtest.adb, tmtests/tm23/tmtest.ads,
tmtests/tm24/tmtest.adb, tmtests/tm24/tmtest.ads,
tmtests/tm25/tmtest.adb, tmtests/tm25/tmtest.ads,
tmtests/tm28/tmtest.adb, tmtests/tm28/tmtest.ads,
tmtests/tm29/tmtest.adb, tmtests/tm29/tmtest.ads,
tmtests/tmck/tmtest.adb, tmtests/tmck/tmtest.ads,
tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/tmtest.adb,
tmtests/tmoverhd/tmtest.ads: Remove many warnings.
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am,
mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am,
mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am,
mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am,
mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am,
mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am,
mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am,
mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am,
mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am,
mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am,
mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am,
mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am,
mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am,
mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am,
samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am,
samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am,
samples/hello/Makefile.am, samples/nsecs/Makefile.am,
samples/ticker/Makefile.am, sptests/sp01/Makefile.am,
sptests/sp02/Makefile.am, sptests/sp03/Makefile.am,
sptests/sp04/Makefile.am, sptests/sp05/Makefile.am,
sptests/sp06/Makefile.am, sptests/sp07/Makefile.am,
sptests/sp08/Makefile.am, sptests/sp09/Makefile.am,
sptests/sp11/Makefile.am, sptests/sp12/Makefile.am,
sptests/sp13/Makefile.am, sptests/sp14/Makefile.am,
sptests/sp15/Makefile.am, sptests/sp16/Makefile.am,
sptests/sp17/Makefile.am, sptests/sp19/Makefile.am,
sptests/sp20/Makefile.am, sptests/sp22/Makefile.am,
sptests/sp23/Makefile.am, sptests/sp24/Makefile.am,
sptests/sp25/Makefile.am, sptests/spname01/Makefile.am,
tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am,
tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am,
tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am,
tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am,
tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am,
tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am,
tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am,
tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am,
tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am,
tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am,
tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am,
tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am,
tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am,
tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am,
tmtests/tmoverhd/Makefile.am: Update so all tests build.
* support/timer_driver.adb, support/timer_driver.ads,
tmtests/tm01/tmtest.adb, tmtests/tm02/tmtest.adb,
tmtests/tm03/tmtest.adb, tmtests/tm04/tmtest.adb,
tmtests/tm05/tmtest.adb, tmtests/tm06/tmtest.adb,
tmtests/tm07/tmtest.adb, tmtests/tm08/tmtest.adb,
tmtests/tm09/tmtest.adb, tmtests/tm10/tmtest.adb,
tmtests/tm11/tmtest.adb, tmtests/tm12/tmtest.adb,
tmtests/tm13/tmtest.adb, tmtests/tm14/tmtest.adb,
tmtests/tm15/tmtest.adb, tmtests/tm16/tmtest.adb,
tmtests/tm17/tmtest.adb, tmtests/tm18/tmtest.adb,
tmtests/tm19/tmtest.adb, tmtests/tm20/config.h,
tmtests/tm20/tmtest.adb, tmtests/tm21/tmtest.adb,
tmtests/tm22/tmtest.adb, tmtests/tm23/tmtest.adb,
tmtests/tm24/tmtest.adb, tmtests/tm25/tmtest.adb,
tmtests/tm28/tmtest.adb, tmtests/tm29/tmtest.adb,
tmtests/tmck/tmtest.adb, tmtests/tmoverhd/tmtest.adb: Clean up.
Verified to run on psim with gcc 4.3.2.
* support/timer_driver.ads: Switch to new names.
* samples/hello/config.h, sptests/spname01/config.h: These needed
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* mptests/mp01/mptest.ads, mptests/mp02/mptest.ads,
mptests/mp03/mptest.ads, mptests/mp04/mptest.ads,
mptests/mp05/mptest.ads, mptests/mp06/mptest.ads,
mptests/mp07/mptest.ads, mptests/mp08/mptest.ads,
mptests/mp09/mptest.ads, mptests/mp10/mptest.ads,
mptests/mp11/mptest.ads, mptests/mp12/mptest.ads,
mptests/mp13/mptest.ads, mptests/mp14/mptest.ads,
samples/base_mp/mptest.ads, samples/base_sp/sptest.ads,
samples/hello/sptest.ads, samples/nsecs/sptest.ads,
samples/ticker/sptest.ads, sptests/sp01/sptest.ads,
sptests/sp02/sptest.ads, sptests/sp03/sptest.ads,
sptests/sp04/sptest.ads, sptests/sp05/sptest.ads,
sptests/sp06/sptest.ads, sptests/sp07/sptest.ads,
sptests/sp08/sptest.ads, sptests/sp09/sptest.ads,
sptests/sp11/sptest.ads, sptests/sp12/sptest.ads,
sptests/sp13/sptest.ads, sptests/sp14/sptest.ads,
sptests/sp15/sptest.ads, sptests/sp16/sptest.ads,
sptests/sp17/sptest.ads, sptests/sp19/sptest.ads,
sptests/sp20/sptest.ads, sptests/sp22/sptest.ads,
sptests/sp23/sptest.ads, sptests/sp24/sptest.ads,
sptests/sp25/sptest.ads, sptests/spname01/spname01.adb,
tmtests/tm01/tmtest.ads, tmtests/tm02/tmtest.ads,
tmtests/tm03/tmtest.ads, tmtests/tm04/tmtest.ads,
tmtests/tm05/tmtest.ads, tmtests/tm06/tmtest.ads,
tmtests/tm07/tmtest.ads, tmtests/tm08/tmtest.ads,
tmtests/tm09/tmtest.ads, tmtests/tm10/tmtest.ads,
tmtests/tm11/tmtest.ads, tmtests/tm12/tmtest.ads,
tmtests/tm13/tmtest.ads, tmtests/tm14/tmtest.ads,
tmtests/tm15/tmtest.ads, tmtests/tm16/tmtest.ads,
tmtests/tm17/tmtest.ads, tmtests/tm18/tmtest.ads,
tmtests/tm19/tmtest.ads, tmtests/tm20/tmtest.adb,
tmtests/tm20/tmtest.ads, tmtests/tm21/tmtest.ads,
tmtests/tm22/tmtest.ads, tmtests/tm23/tmtest.ads,
tmtests/tm24/tmtest.ads, tmtests/tm25/tmtest.ads,
tmtests/tm28/tmtest.ads, tmtests/tm29/tmtest.ads,
tmtests/tmck/tmtest.ads, tmtests/tmoverhd/tmtest.ads:
Added pragma Convention C as required by gcc > 4.3.
* sptests/spname01/config.h: New file.
* configure.ac, sptests/Makefile.am: Exercise passing as object Id of
SELF.
* sptests/spname01/.cvsignore, sptests/spname01/Makefile.am,
sptests/spname01/ada_spname01.scn, sptests/spname01/spname01.adb,
sptests/spname01/sptest.adb, sptests/spname01/sptest.ads: New files.
samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am,
samples/base_sp/Makefile.am, samples/hello/Makefile.am,
samples/nsecs/Makefile.am, samples/ticker/Makefile.am,
sptests/sp01/Makefile.am, sptests/sp02/Makefile.am,
sptests/sp03/Makefile.am, sptests/sp04/Makefile.am,
sptests/sp05/Makefile.am, sptests/sp06/Makefile.am,
sptests/sp07/Makefile.am, sptests/sp08/Makefile.am,
sptests/sp09/Makefile.am, sptests/sp11/Makefile.am,
sptests/sp12/Makefile.am, sptests/sp13/Makefile.am,
sptests/sp14/Makefile.am, sptests/sp15/Makefile.am,
sptests/sp16/Makefile.am, sptests/sp17/Makefile.am,
sptests/sp19/Makefile.am, sptests/sp20/Makefile.am,
sptests/sp22/Makefile.am, sptests/sp23/Makefile.am,
sptests/sp24/Makefile.am, sptests/sp25/Makefile.am,
tmtests/tmoverhd/Makefile.am: Make all test names unique. All needed
ada_ as prefix to distinguish them from the C tests. MP tests should
produce an executable with test name and node number in it. Screens
renamed to follow.
* ada_mvscn, mptests/mp01/node1/ada_mp01-node1.scn,
mptests/mp01/node2/ada_mp01-node2.scn,
mptests/mp02/node1/ada_mp02-node1.scn,
mptests/mp02/node2/ada_mp02-node2.scn,
mptests/mp03/node1/ada_mp03-node1.scn,
mptests/mp03/node2/ada_mp03-node2.scn,
mptests/mp04/node1/ada_mp04-node1.scn,
mptests/mp04/node2/ada_mp04-node2.scn,
mptests/mp05/node1/ada_mp05-node1.scn,
mptests/mp05/node2/ada_mp05-node2.scn,
mptests/mp06/node1/ada_mp06-node1.scn,
mptests/mp06/node2/ada_mp06-node2.scn,
mptests/mp07/node1/ada_mp07-node1.scn,
mptests/mp07/node2/ada_mp07-node2.scn,
mptests/mp08/node1/ada_mp08-node1.scn,
mptests/mp08/node2/ada_mp08-node2.scn,
mptests/mp09/node1/ada_mp09-node1.scn,
mptests/mp09/node2/ada_mp09-node2.scn,
mptests/mp10/node1/ada_mp10-node1.scn,
mptests/mp10/node2/ada_mp10-node2.scn,
mptests/mp11/node1/ada_mp11-node1.scn,
mptests/mp11/node2/ada_mp11-node2.scn,
mptests/mp12/node1/ada_mp12-node1.scn,
mptests/mp12/node2/ada_mp12-node2.scn,
mptests/mp13/node1/ada_mp13-node1.scn,
mptests/mp13/node2/ada_mp13-node2.scn,
mptests/mp14/node1/ada_mp14-node1.scn,
mptests/mp14/node2/ada_mp14-node2.scn,
samples/base_mp/node1/ada_base_mp-node1.scn,
samples/base_mp/node2/ada_base_mp-node2.scn,
samples/base_sp/ada_base_sp.scn, samples/hello/ada_hello.scn,
samples/nsecs/ada_nsecs.scn, samples/ticker/ada_ticker.scn,
sptests/sp01/ada_sp01.scn, sptests/sp02/ada_sp02.scn,
sptests/sp03/ada_sp03.scn, sptests/sp04/ada_sp04.scn,
sptests/sp05/ada_sp05.scn, sptests/sp06/ada_sp06.scn,
sptests/sp07/ada_sp07.scn, sptests/sp08/ada_sp08.scn,
sptests/sp09/ada_sp09.scn, sptests/sp11/ada_sp11.scn,
sptests/sp12/ada_sp12.scn, sptests/sp13/ada_sp13.scn,
sptests/sp14/ada_sp14.scn, sptests/sp15/ada_sp15.scn,
sptests/sp16/ada_sp16.scn, sptests/sp17/ada_sp17.scn,
sptests/sp19/ada_sp19.scn, sptests/sp20/ada_sp20.scn,
sptests/sp22/ada_sp22.scn, sptests/sp23/ada_sp23.scn,
sptests/sp24/ada_sp24.scn, sptests/sp25/ada_sp25.scn: New files.
* mptests/mp01/node1/mp01-node1.scn, mptests/mp01/node2/mp01-node2.scn,
mptests/mp02/node1/mp02-node1.scn, mptests/mp02/node2/mp02-node2.scn,
mptests/mp03/node1/mp03-node1.scn, mptests/mp03/node2/mp03-node2.scn,
mptests/mp04/node1/mp04-node1.scn, mptests/mp04/node2/mp04-node2.scn,
mptests/mp05/node1/mp05-node1.scn, mptests/mp05/node2/mp05-node2.scn,
mptests/mp06/node1/mp06-node1.scn, mptests/mp06/node2/mp06-node2.scn,
mptests/mp07/node1/mp07-node1.scn, mptests/mp07/node2/mp07-node2.scn,
mptests/mp08/node1/mp08-node1.scn, mptests/mp08/node2/mp08-node2.scn,
mptests/mp09/node1/mp09-node1.scn, mptests/mp09/node2/mp09-node2.scn,
mptests/mp10/node1/mp10-node1.scn, mptests/mp10/node2/mp10-node2.scn,
mptests/mp11/node1/mp11-node1.scn, mptests/mp11/node2/mp11-node2.scn,
mptests/mp12/node1/mp12-node1.scn, mptests/mp12/node2/mp12-node2.scn,
mptests/mp13/node1/mp13-node1.scn, mptests/mp13/node2/mp13-node2.scn,
mptests/mp14/node1/mp14-node1.scn, mptests/mp14/node2/mp14-node2.scn,
samples/base_mp/node1/base_mp-node1.scn,
samples/base_mp/node2/base_mp-node2.scn, samples/base_sp/base_sp.scn,
samples/hello/hello.scn, samples/nsecs/nsecs.scn,
samples/ticker/ticker.scn, sptests/sp01/sp01.scn,
sptests/sp02/sp02.scn, sptests/sp03/sp03.scn, sptests/sp04/sp04.scn,
sptests/sp05/sp05.scn, sptests/sp06/sp06.scn, sptests/sp07/sp07.scn,
sptests/sp08/sp08.scn, sptests/sp09/sp09.scn, sptests/sp11/sp11.scn,
sptests/sp12/sp12.scn, sptests/sp13/sp13.scn, sptests/sp14/sp14.scn,
sptests/sp15/sp15.scn, sptests/sp16/sp16.scn, sptests/sp17/sp17.scn,
sptests/sp19/sp19.scn, sptests/sp20/sp20.scn, sptests/sp22/sp22.scn,
sptests/sp23/sp23.scn, sptests/sp24/sp24.scn, sptests/sp25/sp25.scn:
Removed.
* ada.am: Now builds cleanly with GCC trunk.
sptests/sp25/Makefile.am, tmtests/tm01/Makefile.am,
tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am,
tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am,
tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am,
tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am,
tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am,
tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am,
tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am,
tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am,
tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am,
tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am,
tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am,
tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am,
tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am,
tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Executables
should end in .exe just like their C counterparts.
* configure.ac, samples/Makefile.am: Added a test for Clock_Get_Uptime
* samples/nsecs/.cvsignore, samples/nsecs/Makefile.am,
samples/nsecs/config.h, samples/nsecs/nsecs.adb,
samples/nsecs/nsecs.scn, samples/nsecs/sptest.adb,
samples/nsecs/sptest.ads: New files.
* sptests/sp16/sptest.ads, sptests/sp20/sptest.adb,
sptests/sp20/sptest.ads: Forgot to update the copyright.
* sptests/sp09/sp09.scn, sptests/sp09/sptest.adb,
sptests/sp13/sp13.scn, sptests/sp13/sptest.adb,
sptests/sp16/sp16.scn, sptests/sp16/sptest.adb,
sptests/sp16/sptest.ads, sptests/sp20/sp20.scn,
sptests/sp20/sptest.adb, sptests/sp20/sptest.ads: Updated tests to
match the current C tests and regenerated the .scn files.
* configure.ac, samples/base_sp/base_sp.scn, samples/base_sp/config.h,
samples/base_sp/sptest.adb, samples/hello/config.h,
samples/ticker/config.h, samples/ticker/ticker.scn,
sptests/Makefile.am, sptests/sp01/sp01.scn, sptests/sp02/config.h,
sptests/sp02/sp02.scn, sptests/sp03/config.h, sptests/sp03/sp03.scn,
sptests/sp04/sp04.scn, sptests/sp04/sptest.adb,
sptests/sp05/config.h, sptests/sp05/sp05.scn, sptests/sp06/config.h,
sptests/sp07/config.h, sptests/sp07/sp07.scn,
sptests/sp07/sptest.adb, sptests/sp07/sptest.ads,
sptests/sp08/config.h, sptests/sp08/sp08.scn,
sptests/sp09/Makefile.am, sptests/sp09/config.h,
sptests/sp09/sptest.ads, sptests/sp11/config.h,
sptests/sp11/sp11.scn, sptests/sp12/config.h, sptests/sp12/sp12.scn,
sptests/sp13/config.h, sptests/sp13/sp13.scn,
sptests/sp13/sptest.adb, sptests/sp14/config.h,
sptests/sp14/sp14.scn, sptests/sp15/config.h, sptests/sp15/sp15.scn,
sptests/sp16/config.h, sptests/sp16/sp16.scn,
sptests/sp16/sptest.adb, sptests/sp17/config.h,
sptests/sp19/config.h, sptests/sp19/sp19.scn, sptests/sp20/config.h,
sptests/sp20/sp20.scn, sptests/sp22/config.h, sptests/sp22/sp22.scn,
sptests/sp23/config.h, sptests/sp23/sp23.scn, sptests/sp24/config.h,
sptests/sp24/sp24.scn, sptests/sp25/config.h, sptests/sp25/sp25.scn,
support/init.c, support/test_support.adb, support/test_support.ads,
tmtests/tm09/config.h, tmtests/tm20/tmtest.adb,
tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/dummy_rtems.ads,
tmtests/tmoverhd/tmtest.adb, tmtests/tmoverhd/tmtest.ads: Updated
tests so that they would all compile and run without errors. Some
tests that are no longer valid using the current binding were
removed. Also updated the .scn files to reflect the current test
output.
* sptests/sp21/.cvsignore, sptests/sp21/Makefile.am,
sptests/sp21/config.h, sptests/sp21/sp21.adb, sptests/sp21/sp21.scn,
sptests/sp21/sptest.adb, sptests/sp21/sptest.ads,
sptests/spsize/.cvsignore, sptests/spsize/Makefile.am,
sptests/spsize/spsize.adb, sptests/spsize/sptest.adb,
sptests/spsize/sptest.ads: Removed.
mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am: Basic
build structure should now be correct. The remaining issues should be
test specific.
* mptests/mp01/config_base.h, mptests/mp01/node1/config.h,
mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/config.h,
mptests/mp01/node2/mp01_node2.adb, mptests/mp02/config_base.h,
mptests/mp02/node1/config.h, mptests/mp02/node1/mp02_node1.adb,
mptests/mp02/node2/config.h, mptests/mp02/node2/mp02_node2.adb,
mptests/mp03/config_base.h, mptests/mp03/node1/config.h,
mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/config.h,
mptests/mp03/node2/mp03_node2.adb, mptests/mp04/config_base.h,
mptests/mp04/node1/config.h, mptests/mp04/node1/mp04_node1.adb,
mptests/mp04/node2/config.h, mptests/mp04/node2/mp04_node2.adb,
mptests/mp05/config_base.h, mptests/mp05/node1/config.h,
mptests/mp05/node1/mp05_node1.adb, mptests/mp05/node2/config.h,
mptests/mp05/node2/mp05_node2.adb, mptests/mp06/config_base.h,
mptests/mp06/node1/config.h, mptests/mp06/node1/mp06_node1.adb,
mptests/mp06/node2/config.h, mptests/mp06/node2/mp06_node2.adb,
mptests/mp07/config_base.h, mptests/mp07/node1/config.h,
mptests/mp07/node1/mp07_node1.adb, mptests/mp07/node2/config.h,
mptests/mp07/node2/mp07_node2.adb, mptests/mp08/config_base.h,
mptests/mp08/node1/config.h, mptests/mp08/node1/mp08_node1.adb,
mptests/mp08/node2/config.h, mptests/mp08/node2/mp08_node2.adb,
mptests/mp09/config_base.h, mptests/mp09/node1/config.h,
mptests/mp09/node1/mp09_node1.adb, mptests/mp09/node2/config.h,
mptests/mp09/node2/mp09_node2.adb, mptests/mp10/config_base.h,
mptests/mp10/node1/config.h, mptests/mp10/node1/mp10_node1.adb,
mptests/mp10/node2/config.h, mptests/mp10/node2/mp10_node2.adb,
mptests/mp11/config_base.h, mptests/mp11/node1/config.h,
mptests/mp11/node1/mp11_node1.adb, mptests/mp11/node2/config.h,
mptests/mp11/node2/mp11_node2.adb, mptests/mp12/config_base.h,
mptests/mp12/node1/config.h, mptests/mp12/node1/mp12_node1.adb,
mptests/mp12/node2/config.h, mptests/mp12/node2/mp12_node2.adb,
mptests/mp13/config_base.h, mptests/mp13/node1/config.h,
mptests/mp13/node1/mp13_node1.adb, mptests/mp13/node2/config.h,
mptests/mp13/node2/mp13_node2.adb, mptests/mp14/config_base.h,
mptests/mp14/node1/config.h, mptests/mp14/node1/mp14_node1.adb,
mptests/mp14/node2/config.h, mptests/mp14/node2/mp14_node2.adb:
New files. GNATMAKE is easier to operate if the filename of the
main package matches the executable name. In this case, we needed
one for each node's executable.
* mptests/mp01/config.h: Removed.
* mptests/mp01/mptest.adb, mptests/mp01/mptest.ads,
mptests/mp01/node1/Makefile.am, mptests/mp02/mptest.adb,
mptests/mp02/mptest.ads, mptests/mp03/mptest.adb,
mptests/mp03/mptest.ads, mptests/mp04/mptest.adb,
mptests/mp04/mptest.ads, mptests/mp05/mptest.adb,
mptests/mp05/mptest.ads, mptests/mp06/mptest.adb,
mptests/mp06/mptest.ads, mptests/mp07/mptest.adb,
mptests/mp07/mptest.ads, mptests/mp08/mptest.adb,
mptests/mp08/mptest.ads, mptests/mp09/mptest.adb,
mptests/mp09/mptest.ads, mptests/mp10/mptest.adb,
mptests/mp10/mptest.ads, mptests/mp11/mptest.adb,
mptests/mp11/mptest.ads, mptests/mp12/mptest.adb,
mptests/mp12/mptest.ads, mptests/mp13/mptest.adb,
mptests/mp13/mptest.ads, mptests/mp14/mptest.adb,
mptests/mp14/mptest.ads, support/init.c, support/test_support.adb,
support/test_support.ads: Most of single processor Ada tests now
build. Some run.
* support/init.c: Spacing cleanup.
* mptests/mp01/config.h, samples/base_sp/config.h,
samples/hello/config.h, samples/ticker/config.h,
sptests/sp01/config.h, sptests/sp02/config.h, sptests/sp03/config.h,
sptests/sp04/config.h, sptests/sp05/config.h, sptests/sp06/config.h,
sptests/sp07/config.h, sptests/sp08/config.h, sptests/sp09/config.h,
sptests/sp11/config.h, sptests/sp12/config.h, sptests/sp13/config.h,
sptests/sp14/config.h, sptests/sp15/config.h, sptests/sp16/config.h,
sptests/sp17/config.h, sptests/sp19/config.h, sptests/sp20/config.h,
sptests/sp21/config.h, sptests/sp22/config.h, sptests/sp23/config.h,
sptests/sp24/config.h, sptests/sp25/config.h, tmtests/tm01/config.h,
tmtests/tm02/config.h, tmtests/tm03/config.h, tmtests/tm04/config.h,
tmtests/tm05/config.h, tmtests/tm06/config.h, tmtests/tm07/config.h,
tmtests/tm08/config.h, tmtests/tm09/config.h, tmtests/tm10/config.h,
tmtests/tm11/config.h, tmtests/tm12/config.h, tmtests/tm13/config.h,
tmtests/tm14/config.h, tmtests/tm15/config.h, tmtests/tm16/config.h,
tmtests/tm17/config.h, tmtests/tm18/config.h, tmtests/tm19/config.h,
tmtests/tm20/config.h, tmtests/tm21/config.h, tmtests/tm22/config.h,
tmtests/tm23/config.h, tmtests/tm24/config.h, tmtests/tm25/config.h,
tmtests/tm28/config.h, tmtests/tm29/config.h, tmtests/tmck/config.h,
tmtests/tmoverhd/config.h: Change all obsoleted
CONFIGURE_TEST_NEEDS_XXX configuration constants to
CONFIGURE_APPLICATION_NEEDS_XXX.
* configure.ac: Re-add mptests*Makefile.am.
* mptests/Makefile.am: Re-add mp?? tests.
* mptests/mp02/Makefile.am, mptests/mp02/node1/Makefile.am,
mptests/mp02/node2/Makefile.am, mptests/mp03/Makefile.am,
mptests/mp04/Makefile.am, mptests/mp04/node1/Makefile.am,
mptests/mp04/node2/Makefile.am, mptests/mp05/Makefile.am,
mptests/mp06/Makefile.am, mptests/mp06/node1/Makefile.am,
mptests/mp06/node2/Makefile.am, mptests/mp07/Makefile.am,
mptests/mp08/Makefile.am, mptests/mp08/node1/Makefile.am,
mptests/mp08/node2/Makefile.am, mptests/mp09/Makefile.am,
mptests/mp10/Makefile.am, mptests/mp10/node1/Makefile.am,
mptests/mp10/node2/Makefile.am, mptests/mp11/Makefile.am,
mptests/mp12/Makefile.am, mptests/mp12/node1/Makefile.am,
mptests/mp12/node2/Makefile.am, mptests/mp13/Makefile.am,
mptests/mp14/Makefile.am, mptests/mp14/node1/Makefile.am,
mptests/mp14/node2/Makefile.am: New.
