* samples/hello/config.h: Change CONFIGURE_SPTEST to
CONFIGURE_APPLICATION to reflect current usage.
* support/init.c: Include stdlib.h not unistd.h to remove warning.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* support/init.c: Included <unistd.h> for exit(2).
* support/test_support.adb: Eliminated warnings by commenting out
unused variables.
* samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am:
Now appear to mostly compile.
* samples/hello/Makefile.am: Make sure init.c is compiled and
included. This test now runs.
* samples/base_mp/config.h: New file previously missed.
* base_mp now builds and can be considered a bit of an example for
the other mptests.
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am,
samples/base_mp/mptest.adb, samples/base_mp/mptest.ads,
Modified to make compile.
* mptests/mp01/node1/mptest-per_node_configuration.adb,
mptests/mp01/node2/mptest-per_node_configuration.adb,
mptests/mp02/node1/mptest-per_node_configuration.adb,
mptests/mp02/node2/mptest-per_node_configuration.adb,
mptests/mp03/node1/mptest-per_node_configuration.adb,
mptests/mp03/node2/mptest-per_node_configuration.adb,
mptests/mp04/node1/mptest-per_node_configuration.adb,
mptests/mp04/node2/mptest-per_node_configuration.adb,
mptests/mp05/node1/mptest-per_node_configuration.adb,
mptests/mp05/node2/mptest-per_node_configuration.adb,
mptests/mp06/node1/mptest-per_node_configuration.adb,
mptests/mp06/node2/mptest-per_node_configuration.adb,
mptests/mp07/node1/mptest-per_node_configuration.adb,
mptests/mp07/node2/mptest-per_node_configuration.adb,
mptests/mp08/node1/mptest-per_node_configuration.adb,
mptests/mp08/node2/mptest-per_node_configuration.adb,
mptests/mp09/node1/mptest-per_node_configuration.adb,
mptests/mp09/node2/mptest-per_node_configuration.adb,
mptests/mp10/node1/mptest-per_node_configuration.adb,
mptests/mp10/node2/mptest-per_node_configuration.adb,
mptests/mp11/node1/mptest-per_node_configuration.adb,
mptests/mp11/node2/mptest-per_node_configuration.adb,
mptests/mp12/node1/mptest-per_node_configuration.adb,
mptests/mp12/node2/mptest-per_node_configuration.adb,
mptests/mp13/node1/mptest-per_node_configuration.adb,
mptests/mp13/node2/mptest-per_node_configuration.adb,
mptests/mp14/node1/mptest-per_node_configuration.adb,
mptests/mp14/node2/mptest-per_node_configuration.adb,
samples/base_mp/node1/mptest-per_node_configuration.adb,
samples/base_mp/node2/mptest-per_node_configuration.adb: Removed
as this information should come from config.h.
* mptests/mp01/node1/.cvsignore: New.
* mptests/mp01/node2/.cvsignore: New.
* mptests/mp02/node1/.cvsignore: New.
* mptests/mp02/node2/.cvsignore: New.
* mptests/mp03/node1/.cvsignore: New.
* mptests/mp03/node2/.cvsignore: New.
* mptests/mp04/node1/.cvsignore: New.
* mptests/mp04/node2/.cvsignore: New.
* mptests/mp05/node1/.cvsignore: New.
* mptests/mp05/node2/.cvsignore: New.
* mptests/mp06/node1/.cvsignore: New.
* mptests/mp06/node2/.cvsignore: New.
* mptests/mp07/node1/.cvsignore: New.
* mptests/mp07/node2/.cvsignore: New.
* mptests/mp08/node1/.cvsignore: New.
* mptests/mp08/node2/.cvsignore: New.
* mptests/mp09/node1/.cvsignore: New.
* mptests/mp09/node2/.cvsignore: New.
* mptests/mp10/node1/.cvsignore: New.
* mptests/mp10/node2/.cvsignore: New.
* mptests/mp11/node1/.cvsignore: New.
* mptests/mp11/node2/.cvsignore: New.
* mptests/mp12/node1/.cvsignore: New.
* mptests/mp12/node2/.cvsignore: New.
* mptests/mp13/node1/.cvsignore: New.
* mptests/mp13/node2/.cvsignore: New.
* mptests/mp14/node1/.cvsignore: New.
* mptests/mp14/node2/.cvsignore: New.
* samples/base_mp/node1/.cvsignore: New.
* samples/base_mp/node2/.cvsignore: New.
* mptests/Makefile.am: New.
* mptests/mp01/Makefile.am: New.
* mptests/mp01/node1/Makefile.am: New.
* mptests/mp01/node2/Makefile.am: New.
* samples/base_mp/Makefile.am: Comment out building mptest$(EXEEXT).
* samples/base_mp/node1/Makefile.am: New.
* samples/base_mp/node2/Makefile.am: New.
* configure.ac: Add mptests/mp01. Add samples/base_mp.
* tmtests/tm20/Makefile.am: Remove EXPADA.
* samples/base_mp/mptest.ads: Removed lingering reference to BSP_MPCI.
* samples/base_mp/.cvsignore: New file.
* sptests/sp09/Makefile.am: Remove EXPADA.
* sptests/sp09/sptest.adb: Remove RESULT from SCREEN_13.
* sptests/sp19/Makefile.am: Remove EXPADA.
* sptests/sp21/Makefile.am: Remove EXPADA.
* sptests/sp21/sptest.adb: Remove RESULT from TASK_1.
* tmtests/tmoverhd/dummy_rtems.adb: Reflect changes to IO_Managers.
* tmtests/tmoverhd/dummy_rtems.ads: Reflect changes to IO_Managers.
* tmtests/tm20/tmtest.adb, tmtests/tmoverhd/tmtest.adb: Fixed
call to RTEMS IO Manager services.
* sptests/sp19/sptest.adp: Fix include paths.
* sptests/sp19/sptest.adb: Remove.
* sptests/sp19/Makefile.am: Let m4 generate sptests.adb from
sptests.adp.
* sptests/sp21/sptest.adb: Fixed IO_Initialize invocations to
match corrected prototype.
* sptests/sp19/sptest.adp: Added from old Ada implementation.
* tmtests/tm27/.cvsignore: Removed. Missed in previous attempts.
* sptests/sp09/sptest.adb: Add Result to SCREEN_13.
Remove Status from TASK_1.
* sptests/sp21/sptest.adb: Add Result to TASK_1.
* tmtests/tm20/tmtest.adb: Remove various RETURN_VALUEs.
* ada.am: Remove ADACOMPILE, ADAC. Add AM_LDFLAGS, LDFLAGS.
* configure.ac: Check for m4. Abort if HAS_GNAT = no.
* tm27 and tm27 are irrelevant as Ada binding tests.
* tmtests/tm26/config.h, tmtests/tm26/config.h: Removed.
* tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb,
tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp,
tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README,
tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb,
tmtests/tm27/tmtest.ads: Removed.
* configure.ac, tmtests/Makefile.am: Modified to reflect above.
* sptests/sp19/sptest.adb: Modified to follow pattern of SP01
even though this test is not supported.
* sptests/sp19/sp19.adb: New file.
* mptests/mp01/mptest.ads, mptests/mp02/mptest.ads,
mptests/mp03/mptest.ads, mptests/mp04/mptest.ads,
mptests/mp05/mptest.ads, mptests/mp06/mptest.ads,
mptests/mp07/mptest.ads, mptests/mp08/mptest.ads,
mptests/mp09/mptest.ads, mptests/mp10/mptest.ads,
mptests/mp11/mptest.ads, mptests/mp12/mptest.ads,
mptests/mp13/mptest.ads, mptests/mp14/mptest.adb,
mptests/mp14/mptest.ads: Per PR274, identify the need for the
BSP_MPCI package. It was a trivial dependency and eliminated.
* sptests/sp19/sp19.adb: Removed/Renamed to sptest.adb.
* sptests/sp19/sptest.adb: Added/Renamed from sptest.adb.
* sptests/sp09/sptest.adb, sptests/sp21/sptest.adb: All RTEMS IO
Manager directives take fewer arguments than these tests used.
* sptests/sp04/Makefile.am: Remove init.$(OBJEXT).
* Makefile.am: Activate tmtests.
* configure.ac: Activate tmtests.
* samples/base_mp/Makefile.am: Add nodeX subdirs.
* sptests/sp01/Makefile.am: Add *.scn.
* sptests/sp02/Makefile.am: Add *.scn.
* sptests/sp03/Makefile.am: Add *.scn.
* sptests/sp04/Makefile.am: Add *.scn.
* sptests/sp05/Makefile.am: Add *.scn.
* sptests/sp06/Makefile.am: Add *.scn.
* sptests/sp07/Makefile.am: Add *.scn.
* sptests/sp08/Makefile.am: Add *.scn.
* sptests/sp09/Makefile.am: Add *.scn.
* sptests/sp11/Makefile.am: Add *.scn.
* sptests/sp12/Makefile.am: Add *.scn.
* sptests/sp13/Makefile.am: Add *.scn.
* sptests/sp14/Makefile.am: Add *.scn.
* sptests/sp15/Makefile.am: Add *.scn.
* sptests/sp16/Makefile.am: Add *.scn.
* sptests/sp17/Makefile.am: Add *.scn.
* sptests/sp19/Makefile.am: Add *.scn.
* sptests/sp20/Makefile.am: Add *.scn.
* sptests/sp21/Makefile.am: Add *.scn.
* sptests/sp22/Makefile.am: Add *.scn.
* sptests/sp23/Makefile.am: Add *.scn.
* sptests/sp24/Makefile.am: Add *.scn.
* sptests/sp25/Makefile.am: Add *.scn.
* tmtests/Makefile.am: New.
* tmtests/tm01/Makefile.am: New.
* tmtests/tm02/Makefile.am: New.
* tmtests/tm03/Makefile.am: New.
* tmtests/tm04/Makefile.am: New.
* tmtests/tm05/Makefile.am: New.
* tmtests/tm06/Makefile.am: New.
* tmtests/tm07/Makefile.am: New.
* tmtests/tm08/Makefile.am: New.
* tmtests/tm09/Makefile.am: New.
* tmtests/tm10/Makefile.am: New.
* tmtests/tm11/Makefile.am: New.
* tmtests/tm12/Makefile.am: New.
* tmtests/tm13/Makefile.am: New.
* tmtests/tm14/Makefile.am: New.
* tmtests/tm15/Makefile.am: New.
* tmtests/tm16/Makefile.am: New.
* tmtests/tm17/Makefile.am: New.
* tmtests/tm18/Makefile.am: New.
* tmtests/tm19/Makefile.am: New.
* tmtests/tm20/Makefile.am: New.
* tmtests/tm21/Makefile.am: New.
* tmtests/tm22/Makefile.am: New.
* tmtests/tm23/Makefile.am: New.
* tmtests/tm24/Makefile.am: New.
* tmtests/tm25/Makefile.am: New.
* tmtests/tm26/Makefile.am: New.
* tmtests/tm26/tmtest.adb
* tmtests/tm27/Makefile.am: New.
* tmtests/tm28/Makefile.am: New.
* tmtests/tm29/Makefile.am: New.
* tmtests/tmck/Makefile.am: New.
* tmtests/tmoverhd/Makefile.am: New.
* Makefile.am: New.
* configure.ac: New.
* ada.am: New.
* support/Makefile.am: New.
* samples/Makefile.am: New.
* samples/base_mp/Makefile.am: New.
* samples/base_sp/Makefile.am: New.
* samples/hello/Makefile.am: New.
* samples/ticker/Makefile.am: New.
* sptests/Makefile.am: New.
* sptests/sp01/Makefile.am: New.
* sptests/sp02/Makefile.am: New.
* sptests/sp03/Makefile.am: New.
* sptests/sp04/Makefile.am: New.
* sptests/sp05/Makefile.am: New.
* sptests/sp06/Makefile.am: New.
* sptests/sp07/Makefile.am: New.
* sptests/sp08/Makefile.am: New.
* sptests/sp09/Makefile.am: New.
* sptests/sp11/Makefile.am: New.
* sptests/sp12/Makefile.am: New.
* sptests/sp13/Makefile.am: New.
* sptests/sp14/Makefile.am: New.
* sptests/sp15/Makefile.am: New.
* sptests/sp16/Makefile.am: New.
* sptests/sp17/Makefile.am: New.
* sptests/sp19/Makefile.am: New.
* sptests/sp20/Makefile.am: New.
* sptests/sp21/Makefile.am: New.
* sptests/sp22/Makefile.am: New.
* sptests/sp23/Makefile.am: New.
* sptests/sp24/Makefile.am: New.
* sptests/sp25/Makefile.am: New.
* sptests/spsize/Makefile.am: New.
* ChangeLog: New.
* .cvsignore: New.
* mptests/.cvsignore: New.
* mptests/mp01/.cvsignore: New.
* mptests/mp02/.cvsignore: New.
* mptests/mp03/.cvsignore: New.
* mptests/mp04/.cvsignore: New.
* mptests/mp05/.cvsignore: New.
* mptests/mp06/.cvsignore: New.
* mptests/mp07/.cvsignore: New.
* mptests/mp08/.cvsignore: New.
* mptests/mp09/.cvsignore: New.
* mptests/mp10/.cvsignore: New.
* mptests/mp11/.cvsignore: New.
* mptests/mp12/.cvsignore: New.
* mptests/mp13/.cvsignore: New.
* mptests/mp14/.cvsignore: New.
* samples/.cvsignore: New.
* samples/base_sp/.cvsignore: New.
* samples/hello/.cvsignore: New.
* samples/ticker/.cvsignore: New.
* sptests/.cvsignore: New.
* sptests/sp01/.cvsignore: New.
* sptests/sp02/.cvsignore: New.
* sptests/sp03/.cvsignore: New.
* sptests/sp04/.cvsignore: New.
* sptests/sp05/.cvsignore: New.
* sptests/sp06/.cvsignore: New.
* sptests/sp07/.cvsignore: New.
* sptests/sp08/.cvsignore: New.
* sptests/sp09/.cvsignore: New.
* sptests/sp11/.cvsignore: New.
* sptests/sp12/.cvsignore: New.
* sptests/sp13/.cvsignore: New.
* sptests/sp14/.cvsignore: New.
* sptests/sp15/.cvsignore: New.
* sptests/sp16/.cvsignore: New.
* sptests/sp17/.cvsignore: New.
* sptests/sp19/.cvsignore: New.
* sptests/sp20/.cvsignore: New.
* sptests/sp21/.cvsignore: New.
* sptests/sp22/.cvsignore: New.
* sptests/sp23/.cvsignore: New.
* sptests/sp24/.cvsignore: New.
* sptests/sp25/.cvsignore: New.
* sptests/spsize/.cvsignore: New.
* support/.cvsignore: New.
* tmtests/.cvsignore: New.
* tmtests/tm01/.cvsignore: New.
* tmtests/tm02/.cvsignore: New.
* tmtests/tm03/.cvsignore: New.
* tmtests/tm04/.cvsignore: New.
* tmtests/tm05/.cvsignore: New.
* tmtests/tm06/.cvsignore: New.
* tmtests/tm07/.cvsignore: New.
* tmtests/tm08/.cvsignore: New.
* tmtests/tm09/.cvsignore: New.
* tmtests/tm10/.cvsignore: New.
* tmtests/tm11/.cvsignore: New.
* tmtests/tm12/.cvsignore: New.
* tmtests/tm13/.cvsignore: New.
* tmtests/tm14/.cvsignore: New.
* tmtests/tm15/.cvsignore: New.
* tmtests/tm16/.cvsignore: New.
* tmtests/tm17/.cvsignore: New.
* tmtests/tm18/.cvsignore: New.
* tmtests/tm19/.cvsignore: New.
* tmtests/tm20/.cvsignore: New.
* tmtests/tm21/.cvsignore: New.
* tmtests/tm22/.cvsignore: New.
* tmtests/tm23/.cvsignore: New.
* tmtests/tm24/.cvsignore: New.
* tmtests/tm25/.cvsignore: New.
* tmtests/tm26/.cvsignore: New.
* tmtests/tm27/.cvsignore: New.
* tmtests/tm28/.cvsignore: New.
* tmtests/tm29/.cvsignore: New.
* tmtests/tmck/.cvsignore: New.
* tmtests/tmoverhd/.cvsignore: New.
