path: root/c/src/ada-tests (unfollow)
1998-10-29Cleanup.Joel Sherrill1-1/+6
1997-06-04new fileJoel Sherrill2-0/+90
1997-06-03corrected name of test suiteJoel Sherrill30-30/+30
1997-06-03fixed commentJoel Sherrill1-1/+1
1997-06-03Removed configuration information.Joel Sherrill1-54/+0
1997-06-03new fileJoel Sherrill4-0/+181
1997-06-03Removed Configuration Information.Joel Sherrill1-54/+0
1997-06-03new files.Joel Sherrill2-0/+89
1997-06-03Removed configuration information.Joel Sherrill1-42/+0
1997-06-03new filesJoel Sherrill5-0/+362
1997-06-03new file.Joel Sherrill1-0/+9
1997-06-03corrected to compile with the new binding.Joel Sherrill5-35/+119
1997-06-03Corrected for this test.Joel Sherrill1-0/+1
1997-06-03Added correct contentsJoel Sherrill1-0/+57
1997-06-03new fileJoel Sherrill4-0/+700
1997-06-03Corrected maximum number of messages to be non-zeroJoel Sherrill1-1/+1
1997-06-03removed reference to Stub Device DriverJoel Sherrill1-1/+0
1997-06-03Replaced prototype for Last_Task which was accidentally removed whenJoel Sherrill1-0/+14
the Configuration Tables were deleted from the Ada specification.
1997-06-03Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems.Joel Sherrill1-1/+1
1997-06-03Fixed incorrect invocation of Message_Queue_CreateJoel Sherrill1-1/+0
1997-06-03fixed typo which resulted in Message_Queue_Create being invoked incorrectly.Joel Sherrill1-1/+0
1997-06-03Fixed calls to Message_Queue_Create to include maximum message sizeJoel Sherrill9-5/+14
parameter.
1997-06-03Changed to variable length messages.Joel Sherrill17-66/+219
1997-06-03Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0.Joel Sherrill11-11/+11
1997-06-03Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0.Joel Sherrill1-1/+1
1997-06-03Fixed all references to Semaphore_Create to have the correctJoel Sherrill7-5/+12
argument sequence.
1997-06-03New file.Joel Sherrill28-0/+1045
1997-06-03new fileJoel Sherrill28-0/+1596
1997-06-03Removed Configuration Table information.Joel Sherrill30-1170/+0
1997-06-03Corrected call to Semaphore_Create to have the proper calling sequenceJoel Sherrill1-0/+2
1997-06-03Removed Configuration Table informationJoel Sherrill1-38/+0
1997-06-03new fileJoel Sherrill2-0/+94
1997-06-03Removed unnecessary dependency on RTEMS_Test_Support which existedJoel Sherrill1-1/+0
in the RTEMS Ada implementation but does not exist in this binding.
1997-06-03new fileJoel Sherrill6-0/+209
1997-06-03removed reference to the Stub Device DriverJoel Sherrill1-1/+0
1997-06-03Changed mode and priority of initialization task.Joel Sherrill2-5/+2
1997-06-03Changed attribute of Initialization Task to Floating_PointJoel Sherrill1-1/+1
1997-06-03new filesJoel Sherrill2-0/+56
1997-06-03new fileJoel Sherrill3-0/+326
1997-06-03new fileJoel Sherrill14-0/+504
1997-06-03Changed from RTEMS.Boolean to Standard.Boolean to avoid problems.Joel Sherrill1-1/+1
1997-06-03new filesJoel Sherrill2-0/+82
1997-06-03Switched to proper types for booleans and increased the stack spaceJoel Sherrill2-5/+6
for the tasks in this test.
1997-06-03Modifed to make the test run to completion. Primarily providedJoel Sherrill2-32/+96
the Buffer type and support routines although some work was required to account for the directives which required message size information.
1997-06-03Commented out exception handling code since these routines are notJoel Sherrill1-9/+9
called from Ada tasks. It is questionable whether the exception handling would work correctly.
1997-06-03removed with of unchecked_conversionJoel Sherrill1-1/+0
1997-06-03sptest.adb: update Semaphore_Create calling sequenceJoel Sherrill2-1/+8
sp12.adb: doubled the initialization task stack size
1997-06-03Fixed problems which prevented the test from compiling and running toJoel Sherrill3-85/+157
completion.
1997-06-03changed reference for Configuration Table from BSP to RTEMS.Joel Sherrill1-2/+1
1997-06-03*** empty log message ***Joel Sherrill19-18/+13
