* tmtests/tm20/Makefile.am: Remove EXPADA.
* sptests/sp09/Makefile.am: Remove EXPADA.
* sptests/sp09/sptest.adb: Remove RESULT from SCREEN_13.
* sptests/sp19/Makefile.am: Remove EXPADA.
* sptests/sp21/Makefile.am: Remove EXPADA.
* sptests/sp21/sptest.adb: Remove RESULT from TASK_1.
* tmtests/tmoverhd/dummy_rtems.adb: Reflect changes to IO_Managers.
* tmtests/tmoverhd/dummy_rtems.ads: Reflect changes to IO_Managers.
* tmtests/tm20/tmtest.adb, tmtests/tmoverhd/tmtest.adb: Fixed
call to RTEMS IO Manager services.
* tmtests/tm27/.cvsignore: Removed. Missed in previous attempts.
* sptests/sp09/sptest.adb: Add Result to SCREEN_13.
Remove Status from TASK_1.
* sptests/sp21/sptest.adb: Add Result to TASK_1.
* tmtests/tm20/tmtest.adb: Remove various RETURN_VALUEs.
* ada.am: Remove ADACOMPILE, ADAC. Add AM_LDFLAGS, LDFLAGS.
* configure.ac: Check for m4. Abort if HAS_GNAT = no.
* tm27 and tm27 are irrelevant as Ada binding tests.
* tmtests/tm26/config.h, tmtests/tm26/config.h: Removed.
* tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb,
tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp,
tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README,
tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb,
tmtests/tm27/tmtest.ads: Removed.
* configure.ac, tmtests/Makefile.am: Modified to reflect above.
* tmtests/Makefile.am: New.
* tmtests/tm01/Makefile.am: New.
* tmtests/tm02/Makefile.am: New.
* tmtests/tm03/Makefile.am: New.
* tmtests/tm04/Makefile.am: New.
* tmtests/tm05/Makefile.am: New.
* tmtests/tm06/Makefile.am: New.
* tmtests/tm07/Makefile.am: New.
* tmtests/tm08/Makefile.am: New.
* tmtests/tm09/Makefile.am: New.
* tmtests/tm10/Makefile.am: New.
* tmtests/tm11/Makefile.am: New.
* tmtests/tm12/Makefile.am: New.
* tmtests/tm13/Makefile.am: New.
* tmtests/tm14/Makefile.am: New.
* tmtests/tm15/Makefile.am: New.
* tmtests/tm16/Makefile.am: New.
* tmtests/tm17/Makefile.am: New.
* tmtests/tm18/Makefile.am: New.
* tmtests/tm19/Makefile.am: New.
* tmtests/tm20/Makefile.am: New.
* tmtests/tm21/Makefile.am: New.
* tmtests/tm22/Makefile.am: New.
* tmtests/tm23/Makefile.am: New.
* tmtests/tm24/Makefile.am: New.
* tmtests/tm25/Makefile.am: New.
* tmtests/tm26/Makefile.am: New.
* tmtests/tm26/tmtest.adb
* tmtests/tm27/Makefile.am: New.
* tmtests/tm28/Makefile.am: New.
* tmtests/tm29/Makefile.am: New.
* tmtests/tmck/Makefile.am: New.
* tmtests/tmoverhd/Makefile.am: New.
* ChangeLog: New.
* .cvsignore: New.
* mptests/.cvsignore: New.
* mptests/mp01/.cvsignore: New.
* mptests/mp02/.cvsignore: New.
* mptests/mp03/.cvsignore: New.
* mptests/mp04/.cvsignore: New.
* mptests/mp05/.cvsignore: New.
* mptests/mp06/.cvsignore: New.
* mptests/mp07/.cvsignore: New.
* mptests/mp08/.cvsignore: New.
* mptests/mp09/.cvsignore: New.
* mptests/mp10/.cvsignore: New.
* mptests/mp11/.cvsignore: New.
* mptests/mp12/.cvsignore: New.
* mptests/mp13/.cvsignore: New.
* mptests/mp14/.cvsignore: New.
* samples/.cvsignore: New.
* samples/base_sp/.cvsignore: New.
* samples/hello/.cvsignore: New.
* samples/ticker/.cvsignore: New.
* sptests/.cvsignore: New.
* sptests/sp01/.cvsignore: New.
* sptests/sp02/.cvsignore: New.
* sptests/sp03/.cvsignore: New.
* sptests/sp04/.cvsignore: New.
* sptests/sp05/.cvsignore: New.
* sptests/sp06/.cvsignore: New.
* sptests/sp07/.cvsignore: New.
* sptests/sp08/.cvsignore: New.
* sptests/sp09/.cvsignore: New.
* sptests/sp11/.cvsignore: New.
* sptests/sp12/.cvsignore: New.
* sptests/sp13/.cvsignore: New.
* sptests/sp14/.cvsignore: New.
* sptests/sp15/.cvsignore: New.
* sptests/sp16/.cvsignore: New.
* sptests/sp17/.cvsignore: New.
* sptests/sp19/.cvsignore: New.
* sptests/sp20/.cvsignore: New.
* sptests/sp21/.cvsignore: New.
* sptests/sp22/.cvsignore: New.
* sptests/sp23/.cvsignore: New.
* sptests/sp24/.cvsignore: New.
* sptests/sp25/.cvsignore: New.
* sptests/spsize/.cvsignore: New.
* support/.cvsignore: New.
* tmtests/.cvsignore: New.
* tmtests/tm01/.cvsignore: New.
* tmtests/tm02/.cvsignore: New.
* tmtests/tm03/.cvsignore: New.
* tmtests/tm04/.cvsignore: New.
* tmtests/tm05/.cvsignore: New.
* tmtests/tm06/.cvsignore: New.
* tmtests/tm07/.cvsignore: New.
* tmtests/tm08/.cvsignore: New.
* tmtests/tm09/.cvsignore: New.
* tmtests/tm10/.cvsignore: New.
* tmtests/tm11/.cvsignore: New.
* tmtests/tm12/.cvsignore: New.
* tmtests/tm13/.cvsignore: New.
* tmtests/tm14/.cvsignore: New.
* tmtests/tm15/.cvsignore: New.
* tmtests/tm16/.cvsignore: New.
* tmtests/tm17/.cvsignore: New.
* tmtests/tm18/.cvsignore: New.
* tmtests/tm19/.cvsignore: New.
* tmtests/tm20/.cvsignore: New.
* tmtests/tm21/.cvsignore: New.
* tmtests/tm22/.cvsignore: New.
* tmtests/tm23/.cvsignore: New.
* tmtests/tm24/.cvsignore: New.
* tmtests/tm25/.cvsignore: New.
* tmtests/tm26/.cvsignore: New.
* tmtests/tm27/.cvsignore: New.
* tmtests/tm28/.cvsignore: New.
* tmtests/tm29/.cvsignore: New.
* tmtests/tmck/.cvsignore: New.
* tmtests/tmoverhd/.cvsignore: New.
the Configuration Tables were deleted from the Ada specification.
parameter.
argument sequence.
changed the CVS ID string to be a "development" version.
