path: root/c/src/ada-tests/tmtests/tmck/Makefile.am (follow)
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+2
* Remove CVS-Ids.Ralf Corsépius2012-05-041-2/+0
* 2009-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-141-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/nsecs/Makefile.am, samples/ticker/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, sptests/spname01/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Update so all tests build.
* 2008-02-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-011-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/nsecs/Makefile.am, samples/ticker/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Make all test names unique. All needed ada_ as prefix to distinguish them from the C tests. MP tests should produce an executable with test name and node number in it. Screens renamed to follow. * ada_mvscn, mptests/mp01/node1/ada_mp01-node1.scn, mptests/mp01/node2/ada_mp01-node2.scn, mptests/mp02/node1/ada_mp02-node1.scn, mptests/mp02/node2/ada_mp02-node2.scn, mptests/mp03/node1/ada_mp03-node1.scn, mptests/mp03/node2/ada_mp03-node2.scn, mptests/mp04/node1/ada_mp04-node1.scn, mptests/mp04/node2/ada_mp04-node2.scn, mptests/mp05/node1/ada_mp05-node1.scn, mptests/mp05/node2/ada_mp05-node2.scn, mptests/mp06/node1/ada_mp06-node1.scn, mptests/mp06/node2/ada_mp06-node2.scn, mptests/mp07/node1/ada_mp07-node1.scn, mptests/mp07/node2/ada_mp07-node2.scn, mptests/mp08/node1/ada_mp08-node1.scn, mptests/mp08/node2/ada_mp08-node2.scn, mptests/mp09/node1/ada_mp09-node1.scn, mptests/mp09/node2/ada_mp09-node2.scn, mptests/mp10/node1/ada_mp10-node1.scn, mptests/mp10/node2/ada_mp10-node2.scn, mptests/mp11/node1/ada_mp11-node1.scn, mptests/mp11/node2/ada_mp11-node2.scn, mptests/mp12/node1/ada_mp12-node1.scn, mptests/mp12/node2/ada_mp12-node2.scn, mptests/mp13/node1/ada_mp13-node1.scn, mptests/mp13/node2/ada_mp13-node2.scn, mptests/mp14/node1/ada_mp14-node1.scn, mptests/mp14/node2/ada_mp14-node2.scn, samples/base_mp/node1/ada_base_mp-node1.scn, samples/base_mp/node2/ada_base_mp-node2.scn, samples/base_sp/ada_base_sp.scn, samples/hello/ada_hello.scn, samples/nsecs/ada_nsecs.scn, samples/ticker/ada_ticker.scn, sptests/sp01/ada_sp01.scn, sptests/sp02/ada_sp02.scn, sptests/sp03/ada_sp03.scn, sptests/sp04/ada_sp04.scn, sptests/sp05/ada_sp05.scn, sptests/sp06/ada_sp06.scn, sptests/sp07/ada_sp07.scn, sptests/sp08/ada_sp08.scn, sptests/sp09/ada_sp09.scn, sptests/sp11/ada_sp11.scn, sptests/sp12/ada_sp12.scn, sptests/sp13/ada_sp13.scn, sptests/sp14/ada_sp14.scn, sptests/sp15/ada_sp15.scn, sptests/sp16/ada_sp16.scn, sptests/sp17/ada_sp17.scn, sptests/sp19/ada_sp19.scn, sptests/sp20/ada_sp20.scn, sptests/sp22/ada_sp22.scn, sptests/sp23/ada_sp23.scn, sptests/sp24/ada_sp24.scn, sptests/sp25/ada_sp25.scn: New files. * mptests/mp01/node1/mp01-node1.scn, mptests/mp01/node2/mp01-node2.scn, mptests/mp02/node1/mp02-node1.scn, mptests/mp02/node2/mp02-node2.scn, mptests/mp03/node1/mp03-node1.scn, mptests/mp03/node2/mp03-node2.scn, mptests/mp04/node1/mp04-node1.scn, mptests/mp04/node2/mp04-node2.scn, mptests/mp05/node1/mp05-node1.scn, mptests/mp05/node2/mp05-node2.scn, mptests/mp06/node1/mp06-node1.scn, mptests/mp06/node2/mp06-node2.scn, mptests/mp07/node1/mp07-node1.scn, mptests/mp07/node2/mp07-node2.scn, mptests/mp08/node1/mp08-node1.scn, mptests/mp08/node2/mp08-node2.scn, mptests/mp09/node1/mp09-node1.scn, mptests/mp09/node2/mp09-node2.scn, mptests/mp10/node1/mp10-node1.scn, mptests/mp10/node2/mp10-node2.scn, mptests/mp11/node1/mp11-node1.scn, mptests/mp11/node2/mp11-node2.scn, mptests/mp12/node1/mp12-node1.scn, mptests/mp12/node2/mp12-node2.scn, mptests/mp13/node1/mp13-node1.scn, mptests/mp13/node2/mp13-node2.scn, mptests/mp14/node1/mp14-node1.scn, mptests/mp14/node2/mp14-node2.scn, samples/base_mp/node1/base_mp-node1.scn, samples/base_mp/node2/base_mp-node2.scn, samples/base_sp/base_sp.scn, samples/hello/hello.scn, samples/nsecs/nsecs.scn, samples/ticker/ticker.scn, sptests/sp01/sp01.scn, sptests/sp02/sp02.scn, sptests/sp03/sp03.scn, sptests/sp04/sp04.scn, sptests/sp05/sp05.scn, sptests/sp06/sp06.scn, sptests/sp07/sp07.scn, sptests/sp08/sp08.scn, sptests/sp09/sp09.scn, sptests/sp11/sp11.scn, sptests/sp12/sp12.scn, sptests/sp13/sp13.scn, sptests/sp14/sp14.scn, sptests/sp15/sp15.scn, sptests/sp16/sp16.scn, sptests/sp17/sp17.scn, sptests/sp19/sp19.scn, sptests/sp20/sp20.scn, sptests/sp22/sp22.scn, sptests/sp23/sp23.scn, sptests/sp24/sp24.scn, sptests/sp25/sp25.scn: Removed.
* 2007-10-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-10-251-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/nsecs/Makefile.am, samples/ticker/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Executables should end in .exe just like their C counterparts.
* 2003-11-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-111-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Reflect having moved tests/. * mptests/Makefile.am: Reflect having moved tests/. * mptests/mp01/Makefile.am: Reflect having moved tests/. * mptests/mp01/node1/Makefile.am: Reflect having moved tests/. * mptests/mp01/node2/Makefile.am: Reflect having moved tests/. * samples/Makefile.am: Reflect having moved tests/. * samples/base_mp/Makefile.am: Reflect having moved tests/. * samples/base_mp/node1/Makefile.am: Reflect having moved tests/. * samples/base_mp/node2/Makefile.am: Reflect having moved tests/. * samples/base_sp/Makefile.am: Reflect having moved tests/. * samples/hello/Makefile.am: Reflect having moved tests/. * samples/ticker/Makefile.am: Reflect having moved tests/. * sptests/Makefile.am: Reflect having moved tests/. * sptests/sp01/Makefile.am: Reflect having moved tests/. * sptests/sp02/Makefile.am: Reflect having moved tests/. * sptests/sp03/Makefile.am: Reflect having moved tests/. * sptests/sp04/Makefile.am: Reflect having moved tests/. * sptests/sp05/Makefile.am: Reflect having moved tests/. * sptests/sp06/Makefile.am: Reflect having moved tests/. * sptests/sp07/Makefile.am: Reflect having moved tests/. * sptests/sp08/Makefile.am: Reflect having moved tests/. * sptests/sp09/Makefile.am: Reflect having moved tests/. * sptests/sp11/Makefile.am: Reflect having moved tests/. * sptests/sp12/Makefile.am: Reflect having moved tests/. * sptests/sp13/Makefile.am: Reflect having moved tests/. * sptests/sp14/Makefile.am: Reflect having moved tests/. * sptests/sp15/Makefile.am: Reflect having moved tests/. * sptests/sp16/Makefile.am: Reflect having moved tests/. * sptests/sp17/Makefile.am: Reflect having moved tests/. * sptests/sp19/Makefile.am: Reflect having moved tests/. * sptests/sp20/Makefile.am: Reflect having moved tests/. * sptests/sp21/Makefile.am: Reflect having moved tests/. * sptests/sp22/Makefile.am: Reflect having moved tests/. * sptests/sp23/Makefile.am: Reflect having moved tests/. * sptests/sp24/Makefile.am: Reflect having moved tests/. * sptests/sp25/Makefile.am: Reflect having moved tests/. * sptests/spsize/Makefile.am: Reflect having moved tests/. * support/Makefile.am: Reflect having moved tests/. * tmtests/Makefile.am: Reflect having moved tests/. * tmtests/tm01/Makefile.am: Reflect having moved tests/. * tmtests/tm02/Makefile.am: Reflect having moved tests/. * tmtests/tm03/Makefile.am: Reflect having moved tests/. * tmtests/tm04/Makefile.am: Reflect having moved tests/. * tmtests/tm05/Makefile.am: Reflect having moved tests/. * tmtests/tm06/Makefile.am: Reflect having moved tests/. * tmtests/tm07/Makefile.am: Reflect having moved tests/. * tmtests/tm08/Makefile.am: Reflect having moved tests/. * tmtests/tm09/Makefile.am: Reflect having moved tests/. * tmtests/tm10/Makefile.am: Reflect having moved tests/. * tmtests/tm11/Makefile.am: Reflect having moved tests/. * tmtests/tm12/Makefile.am: Reflect having moved tests/. * tmtests/tm13/Makefile.am: Reflect having moved tests/. * tmtests/tm14/Makefile.am: Reflect having moved tests/. * tmtests/tm15/Makefile.am: Reflect having moved tests/. * tmtests/tm16/Makefile.am: Reflect having moved tests/. * tmtests/tm17/Makefile.am: Reflect having moved tests/. * tmtests/tm18/Makefile.am: Reflect having moved tests/. * tmtests/tm19/Makefile.am: Reflect having moved tests/. * tmtests/tm20/Makefile.am: Reflect having moved tests/. * tmtests/tm21/Makefile.am: Reflect having moved tests/. * tmtests/tm22/Makefile.am: Reflect having moved tests/. * tmtests/tm23/Makefile.am: Reflect having moved tests/. * tmtests/tm24/Makefile.am: Reflect having moved tests/. * tmtests/tm25/Makefile.am: Reflect having moved tests/. * tmtests/tm28/Makefile.am: Reflect having moved tests/. * tmtests/tm29/Makefile.am: Reflect having moved tests/. * tmtests/tmck/Makefile.am: Reflect having moved tests/. * tmtests/tmoverhd/Makefile.am: Reflect having moved tests/.
* 2003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-201-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, mptests/Makefile.am, mptests/mp01/Makefile.am, mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/ticker/Makefile.am, sptests/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp21/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, sptests/spsize/Makefile.am, support/Makefile.am, tmtests/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Pick up am-fragments from ../tests/automake.
* 2003-07-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-091-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada.am: Add .adp to SUFFIXES. Remove c-compilation rule. * samples/base_sp/Makefile.am: Add init.$(OBJEXT). * samples/hello/Makefile.am: Add init.$(OBJEXT). * samples/ticker/Makefile.am: Add init.$(OBJEXT). * samples/ticker/Makefile.am: Remove VPATH. * sptests/sp01/Makefile.am: Add init.$(OBJEXT). * sptests/sp01/Makefile.am: Don't include */lib.am. * sptests/sp01/Makefile.am: Remove VPATH. * sptests/sp02/Makefile.am: Add init.$(OBJEXT). * sptests/sp02/Makefile.am: Don't include */lib.am. * sptests/sp03/Makefile.am: Add init.$(OBJEXT). * sptests/sp03/Makefile.am: Don't include */lib.am. * sptests/sp04/Makefile.am: Add init.$(OBJEXT). * sptests/sp04/Makefile.am: Don't include */lib.am. * sptests/sp04/Makefile.am: Remove EXPADA. * sptests/sp04/Makefile.am: Remove VPATH. * sptests/sp05/Makefile.am: Add init.$(OBJEXT). * sptests/sp05/Makefile.am: Don't include */lib.am. * sptests/sp06/Makefile.am: Add init.$(OBJEXT). * sptests/sp06/Makefile.am: Don't include */lib.am. * sptests/sp07/Makefile.am: Add init.$(OBJEXT). * sptests/sp07/Makefile.am: Don't include */lib.am. * sptests/sp07/Makefile.am: Remove EXPADA. * sptests/sp08/Makefile.am: Add init.$(OBJEXT). * sptests/sp08/Makefile.am: Don't include */lib.am. * sptests/sp09/Makefile.am: Add init.$(OBJEXT). * sptests/sp09/Makefile.am: Don't include */lib.am. * sptests/sp11/Makefile.am: Add init.$(OBJEXT). * sptests/sp11/Makefile.am: Don't include */lib.am. * sptests/sp12/Makefile.am: Add init.$(OBJEXT). * sptests/sp12/Makefile.am: Don't include */lib.am. * sptests/sp13/Makefile.am: Add init.$(OBJEXT). * sptests/sp13/Makefile.am: Don't include */lib.am. * sptests/sp14/Makefile.am: Add init.$(OBJEXT). * sptests/sp14/Makefile.am: Don't include */lib.am. * sptests/sp15/Makefile.am: Add init.$(OBJEXT). * sptests/sp15/Makefile.am: Don't include */lib.am. * sptests/sp16/Makefile.am: Add init.$(OBJEXT). * sptests/sp16/Makefile.am: Don't include */lib.am. * sptests/sp17/Makefile.am: Add init.$(OBJEXT). * sptests/sp17/Makefile.am: Don't include */lib.am. * sptests/sp19/Makefile.am: Add init.$(OBJEXT). * sptests/sp19/Makefile.am: Don't include */lib.am. * sptests/sp20/Makefile.am: Add init.$(OBJEXT). * sptests/sp20/Makefile.am: Don't include */lib.am. * sptests/sp21/Makefile.am: Add init.$(OBJEXT). * sptests/sp21/Makefile.am: Don't include */lib.am. * sptests/sp22/Makefile.am: Add init.$(OBJEXT). * sptests/sp22/Makefile.am: Don't include */lib.am. * sptests/sp23/Makefile.am: Add init.$(OBJEXT). * sptests/sp23/Makefile.am: Don't include */lib.am. * sptests/sp24/Makefile.am: Add init.$(OBJEXT). * sptests/sp24/Makefile.am: Don't include */lib.am. * sptests/sp25/Makefile.am: Add init.$(OBJEXT). * sptests/sp25/Makefile.am: Don't include */lib.am. * sptests/spsize/Makefile.am: Add init.$(OBJEXT). * sptests/spsize/Makefile.am: Don't include */lib.am. * tmtests/tm01/Makefile.am: Add init.$(OBJEXT). * tmtests/tm01/Makefile.am: Don't include */lib.am. * tmtests/tm02/Makefile.am: Add init.$(OBJEXT). * tmtests/tm02/Makefile.am: Don't include */lib.am. * tmtests/tm03/Makefile.am: Add init.$(OBJEXT). * tmtests/tm03/Makefile.am: Don't include */lib.am. * tmtests/tm04/Makefile.am: Add init.$(OBJEXT). * tmtests/tm04/Makefile.am: Don't include */lib.am. * tmtests/tm05/Makefile.am: Add init.$(OBJEXT). * tmtests/tm05/Makefile.am: Don't include */lib.am. * tmtests/tm06/Makefile.am: Add init.$(OBJEXT). * tmtests/tm06/Makefile.am: Don't include */lib.am. * tmtests/tm07/Makefile.am: Add init.$(OBJEXT). * tmtests/tm07/Makefile.am: Don't include */lib.am. * tmtests/tm08/Makefile.am: Add init.$(OBJEXT). * tmtests/tm08/Makefile.am: Don't include */lib.am. * tmtests/tm09/Makefile.am: Add init.$(OBJEXT). * tmtests/tm09/Makefile.am: Don't include */lib.am. * tmtests/tm10/Makefile.am: Add init.$(OBJEXT). * tmtests/tm10/Makefile.am: Don't include */lib.am. * tmtests/tm11/Makefile.am: Add init.$(OBJEXT). * tmtests/tm11/Makefile.am: Don't include */lib.am. * tmtests/tm12/Makefile.am: Add init.$(OBJEXT). * tmtests/tm12/Makefile.am: Don't include */lib.am. * tmtests/tm13/Makefile.am: Add init.$(OBJEXT). * tmtests/tm13/Makefile.am: Don't include */lib.am. * tmtests/tm14/Makefile.am: Add init.$(OBJEXT). * tmtests/tm14/Makefile.am: Don't include */lib.am. * tmtests/tm15/Makefile.am: Add init.$(OBJEXT). * tmtests/tm15/Makefile.am: Don't include */lib.am. * tmtests/tm16/Makefile.am: Add init.$(OBJEXT). * tmtests/tm16/Makefile.am: Don't include */lib.am. * tmtests/tm17/Makefile.am: Add init.$(OBJEXT). * tmtests/tm17/Makefile.am: Don't include */lib.am. * tmtests/tm18/Makefile.am: Add init.$(OBJEXT). * tmtests/tm18/Makefile.am: Don't include */lib.am. * tmtests/tm19/Makefile.am: Add init.$(OBJEXT). * tmtests/tm19/Makefile.am: Don't include */lib.am. * tmtests/tm20/Makefile.am: Add init.$(OBJEXT). * tmtests/tm20/Makefile.am: Don't include */lib.am. * tmtests/tm21/Makefile.am: Add init.$(OBJEXT). * tmtests/tm21/Makefile.am: Don't include */lib.am. * tmtests/tm22/Makefile.am: Add init.$(OBJEXT). * tmtests/tm22/Makefile.am: Don't include */lib.am. * tmtests/tm23/Makefile.am: Add init.$(OBJEXT). * tmtests/tm23/Makefile.am: Don't include */lib.am. * tmtests/tm24/Makefile.am: Add init.$(OBJEXT). * tmtests/tm24/Makefile.am: Don't include */lib.am. * tmtests/tm25/Makefile.am: Add init.$(OBJEXT). * tmtests/tm25/Makefile.am: Don't include */lib.am. * tmtests/tm28/Makefile.am: Add init.$(OBJEXT). * tmtests/tm28/Makefile.am: Don't include */lib.am. * tmtests/tm29/Makefile.am: Add init.$(OBJEXT). * tmtests/tm29/Makefile.am: Don't include */lib.am. * tmtests/tmck/Makefile.am: Add init.$(OBJEXT). * tmtests/tmck/Makefile.am: Don't include */lib.am. * tmtests/tmoverhd/Makefile.am: Add init.$(OBJEXT). * tmtests/tmoverhd/Makefile.am: Don't include */lib.am.
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-261-0/+15
* tmtests/Makefile.am: New. * tmtests/tm01/Makefile.am: New. * tmtests/tm02/Makefile.am: New. * tmtests/tm03/Makefile.am: New. * tmtests/tm04/Makefile.am: New. * tmtests/tm05/Makefile.am: New. * tmtests/tm06/Makefile.am: New. * tmtests/tm07/Makefile.am: New. * tmtests/tm08/Makefile.am: New. * tmtests/tm09/Makefile.am: New. * tmtests/tm10/Makefile.am: New. * tmtests/tm11/Makefile.am: New. * tmtests/tm12/Makefile.am: New. * tmtests/tm13/Makefile.am: New. * tmtests/tm14/Makefile.am: New. * tmtests/tm15/Makefile.am: New. * tmtests/tm16/Makefile.am: New. * tmtests/tm17/Makefile.am: New. * tmtests/tm18/Makefile.am: New. * tmtests/tm19/Makefile.am: New. * tmtests/tm20/Makefile.am: New. * tmtests/tm21/Makefile.am: New. * tmtests/tm22/Makefile.am: New. * tmtests/tm23/Makefile.am: New. * tmtests/tm24/Makefile.am: New. * tmtests/tm25/Makefile.am: New. * tmtests/tm26/Makefile.am: New. * tmtests/tm26/tmtest.adb * tmtests/tm27/Makefile.am: New. * tmtests/tm28/Makefile.am: New. * tmtests/tm29/Makefile.am: New. * tmtests/tmck/Makefile.am: New. * tmtests/tmoverhd/Makefile.am: New.
