This solves a build dependency issue, e.g. building tests before
librtemsbsp.a exists.
Close #3079.
* ada-tests/mptests/mp01/mp01.adb, ada-tests/mptests/mp01/mptest.adb,
ada-tests/mptests/mp01/mptest.ads,
ada-tests/mptests/mp01/node1/mp01_node1.adb,
ada-tests/mptests/mp01/node2/mp01_node2.adb,
ada-tests/mptests/mp02/mptest.adb, ada-tests/mptests/mp02/mptest.ads,
ada-tests/mptests/mp02/node1/mp02_node1.adb,
ada-tests/mptests/mp02/node2/mp02_node2.adb,
ada-tests/mptests/mp03/mptest.adb, ada-tests/mptests/mp03/mptest.ads,
ada-tests/mptests/mp03/node1/mp03_node1.adb,
ada-tests/mptests/mp03/node2/mp03_node2.adb,
ada-tests/mptests/mp04/mptest.adb, ada-tests/mptests/mp04/mptest.ads,
ada-tests/mptests/mp04/node1/mp04_node1.adb,
ada-tests/mptests/mp04/node2/mp04_node2.adb,
ada-tests/mptests/mp05/mptest.adb, ada-tests/mptests/mp05/mptest.ads,
ada-tests/mptests/mp05/node1/mp05_node1.adb,
ada-tests/mptests/mp05/node2/mp05_node2.adb,
ada-tests/mptests/mp06/mptest.adb, ada-tests/mptests/mp06/mptest.ads,
ada-tests/mptests/mp06/node1/mp06_node1.adb,
ada-tests/mptests/mp06/node2/mp06_node2.adb,
ada-tests/mptests/mp07/mptest.adb, ada-tests/mptests/mp07/mptest.ads,
ada-tests/mptests/mp07/node1/mp07_node1.adb,
ada-tests/mptests/mp07/node2/mp07_node2.adb,
ada-tests/mptests/mp08/mptest.adb, ada-tests/mptests/mp08/mptest.ads,
ada-tests/mptests/mp08/node1/mp08_node1.adb,
ada-tests/mptests/mp08/node2/mp08_node2.adb,
ada-tests/mptests/mp09/mptest.adb, ada-tests/mptests/mp09/mptest.ads,
ada-tests/mptests/mp09/node1/mp09_node1.adb,
ada-tests/mptests/mp09/node2/mp09_node2.adb,
ada-tests/mptests/mp10/mptest.adb, ada-tests/mptests/mp10/mptest.ads,
ada-tests/mptests/mp10/node1/mp10_node1.adb,
ada-tests/mptests/mp10/node2/mp10_node2.adb,
ada-tests/mptests/mp11/mptest.adb, ada-tests/mptests/mp11/mptest.ads,
ada-tests/mptests/mp11/node1/mp11_node1.adb,
ada-tests/mptests/mp11/node2/mp11_node2.adb,
ada-tests/mptests/mp12/mptest.adb, ada-tests/mptests/mp12/mptest.ads,
ada-tests/mptests/mp12/node1/mp12_node1.adb,
ada-tests/mptests/mp12/node2/mp12_node2.adb,
ada-tests/mptests/mp13/mptest.adb, ada-tests/mptests/mp13/mptest.ads,
ada-tests/mptests/mp13/node1/mp13_node1.adb,
ada-tests/mptests/mp13/node2/mp13_node2.adb,
ada-tests/mptests/mp14/mptest.adb, ada-tests/mptests/mp14/mptest.ads,
ada-tests/mptests/mp14/node1/mp14_node1.adb,
ada-tests/mptests/mp14/node2/mp14_node2.adb,
ada-tests/samples/base_mp/mptest.adb,
ada-tests/samples/base_mp/mptest.ads,
ada-tests/samples/base_sp/base_sp.adb,
ada-tests/samples/base_sp/sptest.adb,
ada-tests/samples/base_sp/sptest.ads,
ada-tests/samples/hello/hello.adb,
ada-tests/samples/hello/sptest.adb,
ada-tests/samples/hello/sptest.ads,
ada-tests/samples/nsecs/nsecs.adb,
ada-tests/samples/nsecs/sptest.adb,
ada-tests/samples/nsecs/sptest.ads,
ada-tests/samples/ticker/sptest.adb,
ada-tests/samples/ticker/sptest.ads,
ada-tests/samples/ticker/ticker.adb, ada-tests/sptests/sp01/sp01.adb,
ada-tests/sptests/sp01/sptest.adb, ada-tests/sptests/sp01/sptest.ads,
ada-tests/sptests/sp02/sp02.adb, ada-tests/sptests/sp02/sptest.adb,
ada-tests/sptests/sp02/sptest.ads, ada-tests/sptests/sp03/sp03.adb,
ada-tests/sptests/sp03/sptest.adb, ada-tests/sptests/sp03/sptest.ads,
ada-tests/sptests/sp04/sp04.adb, ada-tests/sptests/sp04/sptest.adb,
ada-tests/sptests/sp04/sptest.ads, ada-tests/sptests/sp05/sp05.adb,
ada-tests/sptests/sp05/sptest.adb, ada-tests/sptests/sp05/sptest.ads,
ada-tests/sptests/sp06/sp06.adb, ada-tests/sptests/sp06/sptest.adb,
ada-tests/sptests/sp06/sptest.ads, ada-tests/sptests/sp07/sp07.adb,
ada-tests/sptests/sp07/sptest.adb, ada-tests/sptests/sp07/sptest.ads,
ada-tests/sptests/sp08/sp08.adb, ada-tests/sptests/sp08/sptest.adb,
ada-tests/sptests/sp08/sptest.ads, ada-tests/sptests/sp09/sp09.adb,
ada-tests/sptests/sp09/sptest.adb, ada-tests/sptests/sp09/sptest.ads,
ada-tests/sptests/sp11/sp11.adb, ada-tests/sptests/sp11/sptest.adb,
ada-tests/sptests/sp11/sptest.ads, ada-tests/sptests/sp12/sp12.adb,
ada-tests/sptests/sp12/sptest.adb, ada-tests/sptests/sp12/sptest.ads,
ada-tests/sptests/sp13/sp13.adb, ada-tests/sptests/sp13/sptest.adb,
ada-tests/sptests/sp13/sptest.ads, ada-tests/sptests/sp14/sp14.adb,
ada-tests/sptests/sp14/sptest.adb, ada-tests/sptests/sp14/sptest.ads,
ada-tests/sptests/sp15/sp15.adb, ada-tests/sptests/sp15/sptest.adb,
ada-tests/sptests/sp15/sptest.ads, ada-tests/sptests/sp16/sp16.adb,
ada-tests/sptests/sp16/sptest.adb, ada-tests/sptests/sp16/sptest.ads,
ada-tests/sptests/sp17/sp17.adb, ada-tests/sptests/sp17/sptest.adb,
ada-tests/sptests/sp17/sptest.ads, ada-tests/sptests/sp19/sp19.adb,
ada-tests/sptests/sp19/sptest.adp, ada-tests/sptests/sp19/sptest.ads,
ada-tests/sptests/sp20/sp20.adb, ada-tests/sptests/sp20/sptest.adb,
ada-tests/sptests/sp20/sptest.ads, ada-tests/sptests/sp22/sp22.adb,
ada-tests/sptests/sp22/sptest.adb, ada-tests/sptests/sp22/sptest.ads,
ada-tests/sptests/sp23/sp23.adb, ada-tests/sptests/sp23/sptest.adb,
ada-tests/sptests/sp23/sptest.ads, ada-tests/sptests/sp24/sp24.adb,
ada-tests/sptests/sp24/sptest.adb, ada-tests/sptests/sp24/sptest.ads,
ada-tests/sptests/sp25/sp25.adb, ada-tests/sptests/sp25/sptest.adb,
ada-tests/sptests/sp25/sptest.ads,
ada-tests/support/test_support.adb, ada-tests/tmtests/tm01/tm01.adb,
ada-tests/tmtests/tm01/tmtest.adb, ada-tests/tmtests/tm01/tmtest.ads,
ada-tests/tmtests/tm02/tm02.adb, ada-tests/tmtests/tm02/tmtest.adb,
ada-tests/tmtests/tm02/tmtest.ads, ada-tests/tmtests/tm03/tm03.adb,
ada-tests/tmtests/tm03/tmtest.adb, ada-tests/tmtests/tm03/tmtest.ads,
ada-tests/tmtests/tm04/tm04.adb, ada-tests/tmtests/tm04/tmtest.adb,
ada-tests/tmtests/tm04/tmtest.ads, ada-tests/tmtests/tm05/tm05.adb,
ada-tests/tmtests/tm05/tmtest.adb, ada-tests/tmtests/tm05/tmtest.ads,
ada-tests/tmtests/tm06/tm06.adb, ada-tests/tmtests/tm06/tmtest.adb,
ada-tests/tmtests/tm06/tmtest.ads, ada-tests/tmtests/tm07/tm07.adb,
ada-tests/tmtests/tm07/tmtest.adb, ada-tests/tmtests/tm07/tmtest.ads,
ada-tests/tmtests/tm08/tm08.adb, ada-tests/tmtests/tm08/tmtest.adb,
ada-tests/tmtests/tm08/tmtest.ads, ada-tests/tmtests/tm09/tm09.adb,
ada-tests/tmtests/tm09/tmtest.adb, ada-tests/tmtests/tm09/tmtest.ads,
ada-tests/tmtests/tm10/tm10.adb, ada-tests/tmtests/tm10/tmtest.adb,
ada-tests/tmtests/tm10/tmtest.ads, ada-tests/tmtests/tm11/tm11.adb,
ada-tests/tmtests/tm11/tmtest.adb, ada-tests/tmtests/tm11/tmtest.ads,
ada-tests/tmtests/tm12/tm12.adb, ada-tests/tmtests/tm12/tmtest.adb,
ada-tests/tmtests/tm12/tmtest.ads, ada-tests/tmtests/tm13/tm13.adb,
ada-tests/tmtests/tm13/tmtest.adb, ada-tests/tmtests/tm13/tmtest.ads,
ada-tests/tmtests/tm14/tm14.adb, ada-tests/tmtests/tm14/tmtest.adb,
ada-tests/tmtests/tm14/tmtest.ads, ada-tests/tmtests/tm15/tm15.adb,
ada-tests/tmtests/tm15/tmtest.adb, ada-tests/tmtests/tm15/tmtest.ads,
ada-tests/tmtests/tm16/tm16.adb, ada-tests/tmtests/tm16/tmtest.adb,
ada-tests/tmtests/tm16/tmtest.ads, ada-tests/tmtests/tm17/tm17.adb,
ada-tests/tmtests/tm17/tmtest.adb, ada-tests/tmtests/tm17/tmtest.ads,
ada-tests/tmtests/tm18/tm18.adb, ada-tests/tmtests/tm18/tmtest.adb,
ada-tests/tmtests/tm18/tmtest.ads, ada-tests/tmtests/tm19/tm19.adb,
ada-tests/tmtests/tm19/tmtest.adb, ada-tests/tmtests/tm19/tmtest.ads,
ada-tests/tmtests/tm20/tm20.adb, ada-tests/tmtests/tm20/tmtest.adb,
ada-tests/tmtests/tm20/tmtest.ads, ada-tests/tmtests/tm21/tm21.adb,
ada-tests/tmtests/tm21/tmtest.adb, ada-tests/tmtests/tm21/tmtest.ads,
ada-tests/tmtests/tm22/tm22.adb, ada-tests/tmtests/tm22/tmtest.adb,
ada-tests/tmtests/tm22/tmtest.ads, ada-tests/tmtests/tm23/tm23.adb,
ada-tests/tmtests/tm23/tmtest.adb, ada-tests/tmtests/tm23/tmtest.ads,
ada-tests/tmtests/tm24/tm24.adb, ada-tests/tmtests/tm24/tmtest.adb,
ada-tests/tmtests/tm24/tmtest.ads, ada-tests/tmtests/tm25/tm25.adb,
ada-tests/tmtests/tm25/tmtest.adb, ada-tests/tmtests/tm25/tmtest.ads,
ada-tests/tmtests/tm28/tm28.adb, ada-tests/tmtests/tm28/tmtest.adb,
ada-tests/tmtests/tm28/tmtest.ads, ada-tests/tmtests/tm29/tm29.adb,
ada-tests/tmtests/tm29/tmtest.adb, ada-tests/tmtests/tm29/tmtest.ads,
ada-tests/tmtests/tmck/tmck.adb, ada-tests/tmtests/tmck/tmtest.adb,
ada-tests/tmtests/tmck/tmtest.ads,
ada-tests/tmtests/tmoverhd/dummy_rtems.adb,
ada-tests/tmtests/tmoverhd/dummy_rtems.ads,
ada-tests/tmtests/tmoverhd/tmoverhd.adb,
ada-tests/tmtests/tmoverhd/tmtest.adb,
ada-tests/tmtests/tmoverhd/tmtest.ads: Account for RTEMS binding
child package rework. Eliminate all warnings.
* mptests/mp01/config.h, mptests/mp01/mp01.adb,
mptests/mp01/mptest.adb, mptests/mp01/mptest.ads,
mptests/mp02/mptest.adb, mptests/mp02/mptest.ads,
mptests/mp03/mptest.adb, mptests/mp03/mptest.ads,
mptests/mp04/mptest.adb, mptests/mp04/mptest.ads,
mptests/mp05/mptest.adb, mptests/mp05/mptest.ads,
mptests/mp06/mptest.adb, mptests/mp06/mptest.ads,
mptests/mp07/mptest.adb, mptests/mp07/mptest.ads,
mptests/mp08/mptest.adb, mptests/mp08/mptest.ads,
mptests/mp09/mptest.adb, mptests/mp09/mptest.ads,
mptests/mp10/mptest.adb, mptests/mp10/mptest.ads,
mptests/mp11/mptest.adb, mptests/mp11/mptest.ads,
mptests/mp12/mptest.adb, mptests/mp12/mptest.ads,
mptests/mp13/mptest.adb, mptests/mp13/mptest.ads,
mptests/mp14/mptest.adb, mptests/mp14/mptest.ads,
samples/base_mp/config.h, samples/base_mp/mptest.adb,
samples/base_mp/mptest.ads, samples/base_sp/base_sp.adb,
samples/base_sp/config.h, samples/base_sp/sptest.adb,
samples/base_sp/sptest.ads, samples/hello/config.h,
samples/hello/hello.adb, samples/hello/sptest.adb,
samples/hello/sptest.ads, samples/ticker/config.h,
samples/ticker/sptest.adb, samples/ticker/sptest.ads,
samples/ticker/ticker.adb, sptests/sp01/config.h,
sptests/sp01/sp01.adb, sptests/sp01/sptest.adb,
sptests/sp01/sptest.ads, sptests/sp02/config.h,
sptests/sp02/sp02.adb, sptests/sp02/sptest.adb,
sptests/sp02/sptest.ads, sptests/sp03/config.h,
sptests/sp03/sp03.adb, sptests/sp03/sptest.adb,
sptests/sp03/sptest.ads, sptests/sp04/config.h,
sptests/sp04/sp04.adb, sptests/sp04/sptest.adb,
sptests/sp04/sptest.ads, sptests/sp05/config.h,
sptests/sp05/sp05.adb, sptests/sp05/sptest.adb,
sptests/sp05/sptest.ads, sptests/sp06/config.h,
sptests/sp06/sp06.adb, sptests/sp06/sptest.adb,
sptests/sp06/sptest.ads, sptests/sp07/config.h,
sptests/sp07/sp07.adb, sptests/sp07/sptest.adb,
sptests/sp07/sptest.ads, sptests/sp08/config.h,
sptests/sp08/sp08.adb, sptests/sp08/sptest.adb,
sptests/sp08/sptest.ads, sptests/sp09/config.h,
sptests/sp09/sp09.adb, sptests/sp09/sptest.adb,
sptests/sp09/sptest.ads, sptests/sp11/config.h,
sptests/sp11/sp11.adb, sptests/sp11/sptest.adb,
sptests/sp11/sptest.ads, sptests/sp12/config.h,
sptests/sp12/sp12.adb, sptests/sp12/sptest.adb,
sptests/sp12/sptest.ads, sptests/sp13/config.h,
sptests/sp13/sp13.adb, sptests/sp13/sptest.adb,
sptests/sp13/sptest.ads, sptests/sp14/config.h,
sptests/sp14/sp14.adb, sptests/sp14/sptest.adb,
sptests/sp14/sptest.ads, sptests/sp15/config.h,
sptests/sp15/sp15.adb, sptests/sp15/sptest.adb,
sptests/sp15/sptest.ads, sptests/sp16/config.h,
sptests/sp16/sp16.adb, sptests/sp16/sptest.adb,
sptests/sp16/sptest.ads, sptests/sp17/config.h,
sptests/sp17/sp17.adb, sptests/sp17/sptest.adb,
sptests/sp17/sptest.ads, sptests/sp19/config.h,
sptests/sp19/sp19.adb, sptests/sp19/sptest.ads,
sptests/sp20/config.h, sptests/sp20/sp20.adb,
sptests/sp20/sptest.adb, sptests/sp20/sptest.ads,
sptests/sp21/config.h, sptests/sp21/sp21.adb,
sptests/sp21/sptest.adb, sptests/sp21/sptest.ads,
sptests/sp22/config.h, sptests/sp22/sp22.adb,
sptests/sp22/sptest.adb, sptests/sp22/sptest.ads,
sptests/sp23/config.h, sptests/sp23/sp23.adb,
sptests/sp23/sptest.adb, sptests/sp23/sptest.ads,
sptests/sp24/config.h, sptests/sp24/sp24.adb,
sptests/sp24/sptest.adb, sptests/sp24/sptest.ads,
sptests/sp25/config.h, sptests/sp25/sp25.adb,
sptests/sp25/sptest.adb, sptests/sp25/sptest.ads,
sptests/spsize/spsize.adb, sptests/spsize/sptest.adb,
sptests/spsize/sptest.ads, support/address_io.adb,
support/address_io.ads, support/float_io.ads, support/fp.inc,
support/integer.inc, support/rtems_calling_overhead.ads,
support/status_io.ads, support/test_support.adb,
support/test_support.ads, support/time_test_support.adb,
support/time_test_support.ads, support/timer_driver.adb,
support/timer_driver.ads, support/unsigned32_io.ads,
tmtests/tm01/config.h, tmtests/tm01/tm01.adb,
tmtests/tm01/tmtest.adb, tmtests/tm01/tmtest.ads,
tmtests/tm02/config.h, tmtests/tm02/tm02.adb,
tmtests/tm02/tmtest.adb, tmtests/tm02/tmtest.ads,
tmtests/tm03/config.h, tmtests/tm03/tm03.adb,
tmtests/tm03/tmtest.adb, tmtests/tm03/tmtest.ads,
tmtests/tm04/config.h, tmtests/tm04/tm04.adb,
tmtests/tm04/tmtest.adb, tmtests/tm04/tmtest.ads,
tmtests/tm05/config.h, tmtests/tm05/tm05.adb,
tmtests/tm05/tmtest.adb, tmtests/tm05/tmtest.ads,
tmtests/tm06/config.h, tmtests/tm06/tm06.adb,
tmtests/tm06/tmtest.adb, tmtests/tm06/tmtest.ads,
tmtests/tm07/config.h, tmtests/tm07/tm07.adb,
tmtests/tm07/tmtest.adb, tmtests/tm07/tmtest.ads,
tmtests/tm08/config.h, tmtests/tm08/tm08.adb,
tmtests/tm08/tmtest.adb, tmtests/tm08/tmtest.ads,
tmtests/tm09/config.h, tmtests/tm09/tm09.adb,
tmtests/tm09/tmtest.adb, tmtests/tm09/tmtest.ads,
tmtests/tm10/config.h, tmtests/tm10/tm10.adb,
tmtests/tm10/tmtest.adb, tmtests/tm10/tmtest.ads,
tmtests/tm11/config.h, tmtests/tm11/tm11.adb,
tmtests/tm11/tmtest.adb, tmtests/tm11/tmtest.ads,
tmtests/tm12/config.h, tmtests/tm12/tm12.adb,
tmtests/tm12/tmtest.adb, tmtests/tm12/tmtest.ads,
tmtests/tm13/config.h, tmtests/tm13/tm13.adb,
tmtests/tm13/tmtest.adb, tmtests/tm13/tmtest.ads,
tmtests/tm14/config.h, tmtests/tm14/tm14.adb,
tmtests/tm14/tmtest.adb, tmtests/tm14/tmtest.ads,
tmtests/tm15/config.h, tmtests/tm15/tm15.adb,
tmtests/tm15/tmtest.adb, tmtests/tm15/tmtest.ads,
tmtests/tm16/config.h, tmtests/tm16/tm16.adb,
tmtests/tm16/tmtest.adb, tmtests/tm16/tmtest.ads,
tmtests/tm17/config.h, tmtests/tm17/tm17.adb,
tmtests/tm17/tmtest.adb, tmtests/tm17/tmtest.ads,
tmtests/tm18/config.h, tmtests/tm18/tm18.adb,
tmtests/tm18/tmtest.adb, tmtests/tm18/tmtest.ads,
tmtests/tm19/config.h, tmtests/tm19/tm19.adb,
tmtests/tm19/tmtest.adb, tmtests/tm19/tmtest.ads,
tmtests/tm20/config.h, tmtests/tm20/tm20.adb,
tmtests/tm20/tmtest.adb, tmtests/tm20/tmtest.ads,
tmtests/tm21/config.h, tmtests/tm21/tm21.adb,
tmtests/tm21/tmtest.adb, tmtests/tm21/tmtest.ads,
tmtests/tm22/config.h, tmtests/tm22/tm22.adb,
tmtests/tm22/tmtest.adb, tmtests/tm22/tmtest.ads,
tmtests/tm23/config.h, tmtests/tm23/tm23.adb,
tmtests/tm23/tmtest.adb, tmtests/tm23/tmtest.ads,
tmtests/tm24/config.h, tmtests/tm24/tm24.adb,
tmtests/tm24/tmtest.adb, tmtests/tm24/tmtest.ads,
tmtests/tm25/config.h, tmtests/tm25/tm25.adb,
tmtests/tm25/tmtest.adb, tmtests/tm25/tmtest.ads,
tmtests/tm28/config.h, tmtests/tm28/tm28.adb,
tmtests/tm28/tmtest.adb, tmtests/tm28/tmtest.ads,
tmtests/tm29/config.h, tmtests/tm29/tm29.adb,
tmtests/tm29/tmtest.adb, tmtests/tm29/tmtest.ads,
tmtests/tmck/config.h, tmtests/tmck/tmck.adb,
tmtests/tmck/tmtest.adb, tmtests/tmck/tmtest.ads,
tmtests/tmoverhd/config.h, tmtests/tmoverhd/dummy_rtems.adb,
tmtests/tmoverhd/dummy_rtems.ads, tmtests/tmoverhd/tmoverhd.adb,
tmtests/tmoverhd/tmtest.adb, tmtests/tmoverhd/tmtest.ads: URL for
license changed.
samples/base_mp/mptest.adb, samples/base_mp/mptest.ads,
samples/base_sp/base_sp.adb, samples/base_sp/config.h,
samples/base_sp/sptest.adb, samples/base_sp/sptest.ads,
samples/hello/config.h, samples/hello/hello.adb,
samples/hello/sptest.adb, samples/hello/sptest.ads,
samples/ticker/config.h, samples/ticker/sptest.adb,
samples/ticker/sptest.ads, samples/ticker/ticker.adb,
sptests/sp01/config.h, sptests/sp01/sp01.adb,
sptests/sp01/sptest.adb, sptests/sp01/sptest.ads,
sptests/sp02/config.h, sptests/sp02/sp02.adb,
sptests/sp02/sptest.adb, sptests/sp02/sptest.ads,
sptests/sp03/config.h, sptests/sp03/sp03.adb,
sptests/sp03/sptest.adb, sptests/sp03/sptest.ads,
sptests/sp04/config.h, sptests/sp04/sp04.adb,
sptests/sp04/sptest.adb, sptests/sp04/sptest.ads,
sptests/sp05/config.h, sptests/sp05/sp05.adb,
sptests/sp05/sptest.adb, sptests/sp05/sptest.ads,
sptests/sp06/config.h, sptests/sp06/sp06.adb,
sptests/sp06/sptest.adb, sptests/sp06/sptest.ads,
sptests/sp07/config.h, sptests/sp07/sp07.adb,
sptests/sp07/sptest.adb, sptests/sp07/sptest.ads,
sptests/sp08/config.h, sptests/sp08/sp08.adb,
sptests/sp08/sptest.adb, sptests/sp08/sptest.ads,
sptests/sp09/config.h, sptests/sp09/sp09.adb,
sptests/sp09/sptest.adb, sptests/sp09/sptest.ads,
sptests/sp11/config.h, sptests/sp11/sp11.adb,
sptests/sp11/sptest.adb, sptests/sp11/sptest.ads,
sptests/sp12/config.h, sptests/sp12/sp12.adb,
sptests/sp12/sptest.adb, sptests/sp12/sptest.ads,
sptests/sp13/config.h, sptests/sp13/sp13.adb,
sptests/sp13/sptest.adb, sptests/sp13/sptest.ads,
sptests/sp14/config.h, sptests/sp14/sp14.adb,
sptests/sp14/sptest.adb, sptests/sp14/sptest.ads,
sptests/sp15/config.h, sptests/sp15/sp15.adb,
sptests/sp15/sptest.adb, sptests/sp15/sptest.ads,
sptests/sp16/config.h, sptests/sp16/sp16.adb,
sptests/sp16/sptest.adb, sptests/sp16/sptest.ads,
sptests/sp17/config.h, sptests/sp17/sp17.adb,
sptests/sp17/sptest.adb, sptests/sp17/sptest.ads,
sptests/sp19/config.h, sptests/sp19/sp19.adb,
sptests/sp19/sptest.ads, sptests/sp20/config.h,
sptests/sp20/sp20.adb, sptests/sp20/sptest.adb,
sptests/sp20/sptest.ads, sptests/sp21/config.h,
sptests/sp21/sp21.adb, sptests/sp21/sptest.adb,
sptests/sp21/sptest.ads, sptests/sp22/config.h,
sptests/sp22/sp22.adb, sptests/sp22/sptest.adb,
sptests/sp22/sptest.ads, sptests/sp23/config.h,
sptests/sp23/sp23.adb, sptests/sp23/sptest.adb,
sptests/sp23/sptest.ads, sptests/sp24/config.h,
sptests/sp24/sp24.adb, sptests/sp24/sptest.adb,
sptests/sp24/sptest.ads, sptests/sp25/config.h,
sptests/sp25/sp25.adb, sptests/sp25/sptest.adb,
sptests/sp25/sptest.ads, sptests/spsize/spsize.adb,
sptests/spsize/sptest.adb, sptests/spsize/sptest.ads,
support/address_io.adb, support/address_io.ads, support/float_io.ads,
support/fp.inc, support/integer.inc,
support/rtems_calling_overhead.ads, support/status_io.ads,
support/test_support.adb, support/test_support.ads,
support/time_test_support.adb, support/time_test_support.ads,
support/timer_driver.adb, support/timer_driver.ads,
support/unsigned32_io.ads, tmtests/tm01/config.h,
tmtests/tm01/tm01.adb, tmtests/tm01/tmtest.adb,
tmtests/tm01/tmtest.ads, tmtests/tm02/config.h,
tmtests/tm02/tm02.adb, tmtests/tm02/tmtest.adb,
tmtests/tm02/tmtest.ads, tmtests/tm03/config.h,
tmtests/tm03/tm03.adb, tmtests/tm03/tmtest.adb,
tmtests/tm03/tmtest.ads, tmtests/tm04/config.h,
tmtests/tm04/tm04.adb, tmtests/tm04/tmtest.adb,
tmtests/tm04/tmtest.ads, tmtests/tm05/config.h,
tmtests/tm05/tm05.adb, tmtests/tm05/tmtest.adb,
tmtests/tm05/tmtest.ads, tmtests/tm06/config.h,
tmtests/tm06/tm06.adb, tmtests/tm06/tmtest.adb,
tmtests/tm06/tmtest.ads, tmtests/tm07/config.h,
tmtests/tm07/tm07.adb, tmtests/tm07/tmtest.adb,
tmtests/tm07/tmtest.ads, tmtests/tm08/config.h,
tmtests/tm08/tm08.adb, tmtests/tm08/tmtest.adb,
tmtests/tm08/tmtest.ads, tmtests/tm09/config.h,
tmtests/tm09/tm09.adb, tmtests/tm09/tmtest.adb,
tmtests/tm09/tmtest.ads, tmtests/tm10/config.h,
tmtests/tm10/tm10.adb, tmtests/tm10/tmtest.adb,
tmtests/tm10/tmtest.ads, tmtests/tm11/config.h,
tmtests/tm11/tm11.adb, tmtests/tm11/tmtest.adb,
tmtests/tm11/tmtest.ads, tmtests/tm12/config.h,
tmtests/tm12/tm12.adb, tmtests/tm12/tmtest.adb,
tmtests/tm12/tmtest.ads, tmtests/tm13/config.h,
tmtests/tm13/tm13.adb, tmtests/tm13/tmtest.adb,
tmtests/tm13/tmtest.ads, tmtests/tm14/config.h,
tmtests/tm14/tm14.adb, tmtests/tm14/tmtest.adb,
tmtests/tm14/tmtest.ads, tmtests/tm15/config.h,
tmtests/tm15/tm15.adb, tmtests/tm15/tmtest.adb,
tmtests/tm15/tmtest.ads, tmtests/tm16/config.h,
tmtests/tm16/tm16.adb, tmtests/tm16/tmtest.adb,
tmtests/tm16/tmtest.ads, tmtests/tm17/config.h,
tmtests/tm17/tm17.adb, tmtests/tm17/tmtest.adb,
tmtests/tm17/tmtest.ads, tmtests/tm18/config.h,
tmtests/tm18/tm18.adb, tmtests/tm18/tmtest.adb,
tmtests/tm18/tmtest.ads, tmtests/tm19/config.h,
tmtests/tm19/tm19.adb, tmtests/tm19/tmtest.adb,
tmtests/tm19/tmtest.ads, tmtests/tm20/config.h,
tmtests/tm20/tm20.adb, tmtests/tm20/tmtest.adb,
tmtests/tm20/tmtest.ads, tmtests/tm21/config.h,
tmtests/tm21/tm21.adb, tmtests/tm21/tmtest.adb,
tmtests/tm21/tmtest.ads, tmtests/tm22/config.h,
tmtests/tm22/tm22.adb, tmtests/tm22/tmtest.adb,
tmtests/tm22/tmtest.ads, tmtests/tm23/config.h,
tmtests/tm23/tm23.adb, tmtests/tm23/tmtest.adb,
tmtests/tm23/tmtest.ads, tmtests/tm24/config.h,
tmtests/tm24/tm24.adb, tmtests/tm24/tmtest.adb,
tmtests/tm24/tmtest.ads, tmtests/tm25/config.h,
tmtests/tm25/tm25.adb, tmtests/tm25/tmtest.adb,
tmtests/tm25/tmtest.ads, tmtests/tm28/config.h,
tmtests/tm28/tm28.adb, tmtests/tm28/tmtest.adb,
tmtests/tm28/tmtest.ads, tmtests/tm29/config.h,
tmtests/tm29/tm29.adb, tmtests/tm29/tmtest.adb,
tmtests/tm29/tmtest.ads, tmtests/tmck/config.h,
tmtests/tmck/tmck.adb, tmtests/tmck/tmtest.adb,
tmtests/tmck/tmtest.ads, tmtests/tmoverhd/config.h,
tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/dummy_rtems.ads,
tmtests/tmoverhd/tmoverhd.adb, tmtests/tmoverhd/tmtest.adb,
tmtests/tmoverhd/tmtest.ads: Correct copyright statements.
