* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+2 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -2/+0 |
* | 2003-11-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-11 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Reflect having moved tests/. * mptests/Makefile.am: Reflect having moved tests/. * mptests/mp01/Makefile.am: Reflect having moved tests/. * mptests/mp01/node1/Makefile.am: Reflect having moved tests/. * mptests/mp01/node2/Makefile.am: Reflect having moved tests/. * samples/Makefile.am: Reflect having moved tests/. * samples/base_mp/Makefile.am: Reflect having moved tests/. * samples/base_mp/node1/Makefile.am: Reflect having moved tests/. * samples/base_mp/node2/Makefile.am: Reflect having moved tests/. * samples/base_sp/Makefile.am: Reflect having moved tests/. * samples/hello/Makefile.am: Reflect having moved tests/. * samples/ticker/Makefile.am: Reflect having moved tests/. * sptests/Makefile.am: Reflect having moved tests/. * sptests/sp01/Makefile.am: Reflect having moved tests/. * sptests/sp02/Makefile.am: Reflect having moved tests/. * sptests/sp03/Makefile.am: Reflect having moved tests/. * sptests/sp04/Makefile.am: Reflect having moved tests/. * sptests/sp05/Makefile.am: Reflect having moved tests/. * sptests/sp06/Makefile.am: Reflect having moved tests/. * sptests/sp07/Makefile.am: Reflect having moved tests/. * sptests/sp08/Makefile.am: Reflect having moved tests/. * sptests/sp09/Makefile.am: Reflect having moved tests/. * sptests/sp11/Makefile.am: Reflect having moved tests/. * sptests/sp12/Makefile.am: Reflect having moved tests/. * sptests/sp13/Makefile.am: Reflect having moved tests/. * sptests/sp14/Makefile.am: Reflect having moved tests/. * sptests/sp15/Makefile.am: Reflect having moved tests/. * sptests/sp16/Makefile.am: Reflect having moved tests/. * sptests/sp17/Makefile.am: Reflect having moved tests/. * sptests/sp19/Makefile.am: Reflect having moved tests/. * sptests/sp20/Makefile.am: Reflect having moved tests/. * sptests/sp21/Makefile.am: Reflect having moved tests/. * sptests/sp22/Makefile.am: Reflect having moved tests/. * sptests/sp23/Makefile.am: Reflect having moved tests/. * sptests/sp24/Makefile.am: Reflect having moved tests/. * sptests/sp25/Makefile.am: Reflect having moved tests/. * sptests/spsize/Makefile.am: Reflect having moved tests/. * support/Makefile.am: Reflect having moved tests/. * tmtests/Makefile.am: Reflect having moved tests/. * tmtests/tm01/Makefile.am: Reflect having moved tests/. * tmtests/tm02/Makefile.am: Reflect having moved tests/. * tmtests/tm03/Makefile.am: Reflect having moved tests/. * tmtests/tm04/Makefile.am: Reflect having moved tests/. * tmtests/tm05/Makefile.am: Reflect having moved tests/. * tmtests/tm06/Makefile.am: Reflect having moved tests/. * tmtests/tm07/Makefile.am: Reflect having moved tests/. * tmtests/tm08/Makefile.am: Reflect having moved tests/. * tmtests/tm09/Makefile.am: Reflect having moved tests/. * tmtests/tm10/Makefile.am: Reflect having moved tests/. * tmtests/tm11/Makefile.am: Reflect having moved tests/. * tmtests/tm12/Makefile.am: Reflect having moved tests/. * tmtests/tm13/Makefile.am: Reflect having moved tests/. * tmtests/tm14/Makefile.am: Reflect having moved tests/. * tmtests/tm15/Makefile.am: Reflect having moved tests/. * tmtests/tm16/Makefile.am: Reflect having moved tests/. * tmtests/tm17/Makefile.am: Reflect having moved tests/. * tmtests/tm18/Makefile.am: Reflect having moved tests/. * tmtests/tm19/Makefile.am: Reflect having moved tests/. * tmtests/tm20/Makefile.am: Reflect having moved tests/. * tmtests/tm21/Makefile.am: Reflect having moved tests/. * tmtests/tm22/Makefile.am: Reflect having moved tests/. * tmtests/tm23/Makefile.am: Reflect having moved tests/. * tmtests/tm24/Makefile.am: Reflect having moved tests/. * tmtests/tm25/Makefile.am: Reflect having moved tests/. * tmtests/tm28/Makefile.am: Reflect having moved tests/. * tmtests/tm29/Makefile.am: Reflect having moved tests/. * tmtests/tmck/Makefile.am: Reflect having moved tests/. * tmtests/tmoverhd/Makefile.am: Reflect having moved tests/. | ||||
* | 2003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-20 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, mptests/Makefile.am, mptests/mp01/Makefile.am, mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/ticker/Makefile.am, sptests/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp21/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, sptests/spsize/Makefile.am, support/Makefile.am, tmtests/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Pick up am-fragments from ../tests/automake. | ||||
* | 2002-08-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-26 | 1 | -2/+0 |
| | | | | | | | | | | * tm27 and tm27 are irrelevant as Ada binding tests. * tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb, tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp, tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README, tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb, tmtests/tm27/tmtest.ads: Removed. * configure.ac, tmtests/Makefile.am: Modified to reflect above. | ||||
* | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-26 | 1 | -0/+37 |
* tmtests/Makefile.am: New. * tmtests/tm01/Makefile.am: New. * tmtests/tm02/Makefile.am: New. * tmtests/tm03/Makefile.am: New. * tmtests/tm04/Makefile.am: New. * tmtests/tm05/Makefile.am: New. * tmtests/tm06/Makefile.am: New. * tmtests/tm07/Makefile.am: New. * tmtests/tm08/Makefile.am: New. * tmtests/tm09/Makefile.am: New. * tmtests/tm10/Makefile.am: New. * tmtests/tm11/Makefile.am: New. * tmtests/tm12/Makefile.am: New. * tmtests/tm13/Makefile.am: New. * tmtests/tm14/Makefile.am: New. * tmtests/tm15/Makefile.am: New. * tmtests/tm16/Makefile.am: New. * tmtests/tm17/Makefile.am: New. * tmtests/tm18/Makefile.am: New. * tmtests/tm19/Makefile.am: New. * tmtests/tm20/Makefile.am: New. * tmtests/tm21/Makefile.am: New. * tmtests/tm22/Makefile.am: New. * tmtests/tm23/Makefile.am: New. * tmtests/tm24/Makefile.am: New. * tmtests/tm25/Makefile.am: New. * tmtests/tm26/Makefile.am: New. * tmtests/tm26/tmtest.adb * tmtests/tm27/Makefile.am: New. * tmtests/tm28/Makefile.am: New. * tmtests/tm29/Makefile.am: New. * tmtests/tmck/Makefile.am: New. * tmtests/tmoverhd/Makefile.am: New. |
