* | Removed unnecessary dependency on RTEMS_Test_Support which existed | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
| | | | | in the RTEMS Ada implementation but does not exist in this binding. | ||||
* | new file | Joel Sherrill | 1997-06-03 | 6 | -0/+209 |
* | removed reference to the Stub Device Driver | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
* | Changed mode and priority of initialization task. | Joel Sherrill | 1997-06-03 | 2 | -5/+2 |
* | Changed attribute of Initialization Task to Floating_Point | Joel Sherrill | 1997-06-03 | 1 | -1/+1 |
* | new files | Joel Sherrill | 1997-06-03 | 2 | -0/+56 |
* | new file | Joel Sherrill | 1997-06-03 | 14 | -0/+504 |
* | Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. | Joel Sherrill | 1997-06-03 | 1 | -1/+1 |
* | Switched to proper types for booleans and increased the stack space | Joel Sherrill | 1997-06-03 | 2 | -5/+6 |
| | | | | for the tasks in this test. | ||||
* | Modifed to make the test run to completion. Primarily provided | Joel Sherrill | 1997-06-03 | 2 | -32/+96 |
| | | | | | | the Buffer type and support routines although some work was required to account for the directives which required message size information. | ||||
* | removed with of unchecked_conversion | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
* | sptest.adb: update Semaphore_Create calling sequence | Joel Sherrill | 1997-06-03 | 2 | -1/+8 |
| | | | | sp12.adb: doubled the initialization task stack size | ||||
* | Fixed problems which prevented the test from compiling and running to | Joel Sherrill | 1997-06-03 | 3 | -85/+157 |
| | | | | completion. | ||||
* | changed reference for Configuration Table from BSP to RTEMS. | Joel Sherrill | 1997-06-03 | 1 | -2/+1 |
* | updated to run | Joel Sherrill | 1997-06-03 | 2 | -15/+42 |
* | New style main procedure which creates the test's RTEMS initialization task | Joel Sherrill | 1997-06-03 | 28 | -27/+687 |
| | | | | | | as an RTEMS task. This avoid problems resulting from differences in the tasking mode/priority of Ada tasks from the typical way an RTEMS initialization task is created. | ||||
* | new file | Joel Sherrill | 1997-06-02 | 1 | -0/+33 |
* | readded body for "main" procedures | Joel Sherrill | 1997-06-02 | 47 | -23/+744 |
* | removed configuration table definition in Ada | Joel Sherrill | 1997-06-02 | 23 | -1290/+0 |
* | new file - automatically generated by a script | Joel Sherrill | 1997-06-02 | 24 | -0/+0 |
* | New file -- works in conjunction with support/init.c. | Joel Sherrill | 1997-06-02 | 1 | -0/+33 |
* | Removed Ada Configuration Table definition. | Joel Sherrill | 1997-06-02 | 1 | -55/+0 |
* | added screen files from 3.2.1 | Joel Sherrill | 1997-06-02 | 23 | -0/+976 |
* | modified copyright notice to be the same as RTEMS 4.0.0. | Joel Sherrill | 1997-06-02 | 47 | -282/+282 |
| | | | | changed the CVS ID string to be a "development" version. | ||||
* | Initial revision | Joel Sherrill | 1997-06-02 | 47 | -0/+15263 |
