1997-06-03 | Removed unnecessary dependency on RTEMS_Test_Support which existed | Joel Sherrill | 1 | -1/+0 | |
in the RTEMS Ada implementation but does not exist in this binding. | |||||
1997-06-03 | new file | Joel Sherrill | 6 | -0/+209 | |
1997-06-03 | removed reference to the Stub Device Driver | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | Changed mode and priority of initialization task. | Joel Sherrill | 2 | -5/+2 | |
1997-06-03 | Changed attribute of Initialization Task to Floating_Point | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | new files | Joel Sherrill | 2 | -0/+56 | |
1997-06-03 | new file | Joel Sherrill | 14 | -0/+504 | |
1997-06-03 | Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. | Joel Sherrill | 1 | -1/+1 | |
1997-06-03 | Switched to proper types for booleans and increased the stack space | Joel Sherrill | 2 | -5/+6 | |
for the tasks in this test. | |||||
1997-06-03 | Modifed to make the test run to completion. Primarily provided | Joel Sherrill | 2 | -32/+96 | |
the Buffer type and support routines although some work was required to account for the directives which required message size information. | |||||
1997-06-03 | removed with of unchecked_conversion | Joel Sherrill | 1 | -1/+0 | |
1997-06-03 | sptest.adb: update Semaphore_Create calling sequence | Joel Sherrill | 2 | -1/+8 | |
sp12.adb: doubled the initialization task stack size | |||||
1997-06-03 | Fixed problems which prevented the test from compiling and running to | Joel Sherrill | 3 | -85/+157 | |
completion. | |||||
1997-06-03 | changed reference for Configuration Table from BSP to RTEMS. | Joel Sherrill | 1 | -2/+1 | |
1997-06-03 | updated to run | Joel Sherrill | 2 | -15/+42 | |
1997-06-03 | New style main procedure which creates the test's RTEMS initialization task | Joel Sherrill | 28 | -27/+687 | |
as an RTEMS task. This avoid problems resulting from differences in the tasking mode/priority of Ada tasks from the typical way an RTEMS initialization task is created. | |||||
1997-06-02 | new file | Joel Sherrill | 1 | -0/+33 | |
1997-06-02 | readded body for "main" procedures | Joel Sherrill | 47 | -23/+744 | |
1997-06-02 | removed configuration table definition in Ada | Joel Sherrill | 23 | -1290/+0 | |
1997-06-02 | new file - automatically generated by a script | Joel Sherrill | 24 | -0/+0 | |
1997-06-02 | New file -- works in conjunction with support/init.c. | Joel Sherrill | 1 | -0/+33 | |
1997-06-02 | Removed Ada Configuration Table definition. | Joel Sherrill | 1 | -55/+0 | |
1997-06-02 | added screen files from 3.2.1 | Joel Sherrill | 23 | -0/+976 | |
1997-06-02 | modified copyright notice to be the same as RTEMS 4.0.0. | Joel Sherrill | 47 | -282/+282 | |
changed the CVS ID string to be a "development" version. | |||||
1997-06-02 | Initial revision | Joel Sherrill | 47 | -0/+15263 | |
