* | new file | Joel Sherrill | 1997-06-03 | 1 | -0/+36 |
* | sptest.adb: update Semaphore_Create calling sequence | Joel Sherrill | 1997-06-03 | 2 | -1/+8 |
| | | | | sp12.adb: doubled the initialization task stack size | ||||
* | New style main procedure which creates the test's RTEMS initialization task | Joel Sherrill | 1997-06-03 | 1 | -1/+27 |
| | | | | | | as an RTEMS task. This avoid problems resulting from differences in the tasking mode/priority of Ada tasks from the typical way an RTEMS initialization task is created. | ||||
* | readded body for "main" procedures | Joel Sherrill | 1997-06-02 | 2 | -1/+31 |
* | removed configuration table definition in Ada | Joel Sherrill | 1997-06-02 | 1 | -54/+0 |
* | new file - automatically generated by a script | Joel Sherrill | 1997-06-02 | 1 | -0/+0 |
* | added screen files from 3.2.1 | Joel Sherrill | 1997-06-02 | 1 | -0/+78 |
* | modified copyright notice to be the same as RTEMS 4.0.0. | Joel Sherrill | 1997-06-02 | 2 | -12/+12 |
| | | | | changed the CVS ID string to be a "development" version. | ||||
* | Initial revision | Joel Sherrill | 1997-06-02 | 2 | -0/+1003 |
