path: root/c/src/ada-tests/mptests/mp13/config_base.h (unfollow)
2017-10-12ada-tests: Move to testsuites/adaSebastian Huber1-28/+0
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079.
2017-10-05posix: Implement self-contained POSIX mutexSebastian Huber1-1/+0
POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112.
2017-10-05posix: Implement self-contained POSIX condvarSebastian Huber1-1/+0
POSIX condition variables are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3113.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2007-10-032007-10-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-6/+6
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am: Basic build structure should now be correct. The remaining issues should be test specific. * mptests/mp01/config_base.h, mptests/mp01/node1/config.h, mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/config.h, mptests/mp01/node2/mp01_node2.adb, mptests/mp02/config_base.h, mptests/mp02/node1/config.h, mptests/mp02/node1/mp02_node1.adb, mptests/mp02/node2/config.h, mptests/mp02/node2/mp02_node2.adb, mptests/mp03/config_base.h, mptests/mp03/node1/config.h, mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/config.h, mptests/mp03/node2/mp03_node2.adb, mptests/mp04/config_base.h, mptests/mp04/node1/config.h, mptests/mp04/node1/mp04_node1.adb, mptests/mp04/node2/config.h, mptests/mp04/node2/mp04_node2.adb, mptests/mp05/config_base.h, mptests/mp05/node1/config.h, mptests/mp05/node1/mp05_node1.adb, mptests/mp05/node2/config.h, mptests/mp05/node2/mp05_node2.adb, mptests/mp06/config_base.h, mptests/mp06/node1/config.h, mptests/mp06/node1/mp06_node1.adb, mptests/mp06/node2/config.h, mptests/mp06/node2/mp06_node2.adb, mptests/mp07/config_base.h, mptests/mp07/node1/config.h, mptests/mp07/node1/mp07_node1.adb, mptests/mp07/node2/config.h, mptests/mp07/node2/mp07_node2.adb, mptests/mp08/config_base.h, mptests/mp08/node1/config.h, mptests/mp08/node1/mp08_node1.adb, mptests/mp08/node2/config.h, mptests/mp08/node2/mp08_node2.adb, mptests/mp09/config_base.h, mptests/mp09/node1/config.h, mptests/mp09/node1/mp09_node1.adb, mptests/mp09/node2/config.h, mptests/mp09/node2/mp09_node2.adb, mptests/mp10/config_base.h, mptests/mp10/node1/config.h, mptests/mp10/node1/mp10_node1.adb, mptests/mp10/node2/config.h, mptests/mp10/node2/mp10_node2.adb, mptests/mp11/config_base.h, mptests/mp11/node1/config.h, mptests/mp11/node1/mp11_node1.adb, mptests/mp11/node2/config.h, mptests/mp11/node2/mp11_node2.adb, mptests/mp12/config_base.h, mptests/mp12/node1/config.h, mptests/mp12/node1/mp12_node1.adb, mptests/mp12/node2/config.h, mptests/mp12/node2/mp12_node2.adb, mptests/mp13/config_base.h, mptests/mp13/node1/config.h, mptests/mp13/node1/mp13_node1.adb, mptests/mp13/node2/config.h, mptests/mp13/node2/mp13_node2.adb, mptests/mp14/config_base.h, mptests/mp14/node1/config.h, mptests/mp14/node1/mp14_node1.adb, mptests/mp14/node2/config.h, mptests/mp14/node2/mp14_node2.adb: New files. GNATMAKE is easier to operate if the filename of the main package matches the executable name. In this case, we needed one for each node's executable. * mptests/mp01/config.h: Removed.
2007-04-052007-04-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
* mptests/mp01/config.h, samples/base_sp/config.h, samples/hello/config.h, samples/ticker/config.h, sptests/sp01/config.h, sptests/sp02/config.h, sptests/sp03/config.h, sptests/sp04/config.h, sptests/sp05/config.h, sptests/sp06/config.h, sptests/sp07/config.h, sptests/sp08/config.h, sptests/sp09/config.h, sptests/sp11/config.h, sptests/sp12/config.h, sptests/sp13/config.h, sptests/sp14/config.h, sptests/sp15/config.h, sptests/sp16/config.h, sptests/sp17/config.h, sptests/sp19/config.h, sptests/sp20/config.h, sptests/sp21/config.h, sptests/sp22/config.h, sptests/sp23/config.h, sptests/sp24/config.h, sptests/sp25/config.h, tmtests/tm01/config.h, tmtests/tm02/config.h, tmtests/tm03/config.h, tmtests/tm04/config.h, tmtests/tm05/config.h, tmtests/tm06/config.h, tmtests/tm07/config.h, tmtests/tm08/config.h, tmtests/tm09/config.h, tmtests/tm10/config.h, tmtests/tm11/config.h, tmtests/tm12/config.h, tmtests/tm13/config.h, tmtests/tm14/config.h, tmtests/tm15/config.h, tmtests/tm16/config.h, tmtests/tm17/config.h, tmtests/tm18/config.h, tmtests/tm19/config.h, tmtests/tm20/config.h, tmtests/tm21/config.h, tmtests/tm22/config.h, tmtests/tm23/config.h, tmtests/tm24/config.h, tmtests/tm25/config.h, tmtests/tm28/config.h, tmtests/tm29/config.h, tmtests/tmck/config.h, tmtests/tmoverhd/config.h: Change all obsoleted CONFIGURE_TEST_NEEDS_XXX configuration constants to CONFIGURE_APPLICATION_NEEDS_XXX.
2005-05-01Include <rtems/confdefs.h> instead of <confdefs.h> (obsolete).Ralf Corsepius1-1/+1
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* mptests/mp01/config.h, mptests/mp01/mp01.adb, mptests/mp01/mptest.adb, mptests/mp01/mptest.ads, mptests/mp02/mptest.adb, mptests/mp02/mptest.ads, mptests/mp03/mptest.adb, mptests/mp03/mptest.ads, mptests/mp04/mptest.adb, mptests/mp04/mptest.ads, mptests/mp05/mptest.adb, mptests/mp05/mptest.ads, mptests/mp06/mptest.adb, mptests/mp06/mptest.ads, mptests/mp07/mptest.adb, mptests/mp07/mptest.ads, mptests/mp08/mptest.adb, mptests/mp08/mptest.ads, mptests/mp09/mptest.adb, mptests/mp09/mptest.ads, mptests/mp10/mptest.adb, mptests/mp10/mptest.ads, mptests/mp11/mptest.adb, mptests/mp11/mptest.ads, mptests/mp12/mptest.adb, mptests/mp12/mptest.ads, mptests/mp13/mptest.adb, mptests/mp13/mptest.ads, mptests/mp14/mptest.adb, mptests/mp14/mptest.ads, samples/base_mp/config.h, samples/base_mp/mptest.adb, samples/base_mp/mptest.ads, samples/base_sp/base_sp.adb, samples/base_sp/config.h, samples/base_sp/sptest.adb, samples/base_sp/sptest.ads, samples/hello/config.h, samples/hello/hello.adb, samples/hello/sptest.adb, samples/hello/sptest.ads, samples/ticker/config.h, samples/ticker/sptest.adb, samples/ticker/sptest.ads, samples/ticker/ticker.adb, sptests/sp01/config.h, sptests/sp01/sp01.adb, sptests/sp01/sptest.adb, sptests/sp01/sptest.ads, sptests/sp02/config.h, sptests/sp02/sp02.adb, sptests/sp02/sptest.adb, sptests/sp02/sptest.ads, sptests/sp03/config.h, sptests/sp03/sp03.adb, sptests/sp03/sptest.adb, sptests/sp03/sptest.ads, sptests/sp04/config.h, sptests/sp04/sp04.adb, sptests/sp04/sptest.adb, sptests/sp04/sptest.ads, sptests/sp05/config.h, sptests/sp05/sp05.adb, sptests/sp05/sptest.adb, sptests/sp05/sptest.ads, sptests/sp06/config.h, sptests/sp06/sp06.adb, sptests/sp06/sptest.adb, sptests/sp06/sptest.ads, sptests/sp07/config.h, sptests/sp07/sp07.adb, sptests/sp07/sptest.adb, sptests/sp07/sptest.ads, sptests/sp08/config.h, sptests/sp08/sp08.adb, sptests/sp08/sptest.adb, sptests/sp08/sptest.ads, sptests/sp09/config.h, sptests/sp09/sp09.adb, sptests/sp09/sptest.adb, sptests/sp09/sptest.ads, sptests/sp11/config.h, sptests/sp11/sp11.adb, sptests/sp11/sptest.adb, sptests/sp11/sptest.ads, sptests/sp12/config.h, sptests/sp12/sp12.adb, sptests/sp12/sptest.adb, sptests/sp12/sptest.ads, sptests/sp13/config.h, sptests/sp13/sp13.adb, sptests/sp13/sptest.adb, sptests/sp13/sptest.ads, sptests/sp14/config.h, sptests/sp14/sp14.adb, sptests/sp14/sptest.adb, sptests/sp14/sptest.ads, sptests/sp15/config.h, sptests/sp15/sp15.adb, sptests/sp15/sptest.adb, sptests/sp15/sptest.ads, sptests/sp16/config.h, sptests/sp16/sp16.adb, sptests/sp16/sptest.adb, sptests/sp16/sptest.ads, sptests/sp17/config.h, sptests/sp17/sp17.adb, sptests/sp17/sptest.adb, sptests/sp17/sptest.ads, sptests/sp19/config.h, sptests/sp19/sp19.adb, sptests/sp19/sptest.ads, sptests/sp20/config.h, sptests/sp20/sp20.adb, sptests/sp20/sptest.adb, sptests/sp20/sptest.ads, sptests/sp21/config.h, sptests/sp21/sp21.adb, sptests/sp21/sptest.adb, sptests/sp21/sptest.ads, sptests/sp22/config.h, sptests/sp22/sp22.adb, sptests/sp22/sptest.adb, sptests/sp22/sptest.ads, sptests/sp23/config.h, sptests/sp23/sp23.adb, sptests/sp23/sptest.adb, sptests/sp23/sptest.ads, sptests/sp24/config.h, sptests/sp24/sp24.adb, sptests/sp24/sptest.adb, sptests/sp24/sptest.ads, sptests/sp25/config.h, sptests/sp25/sp25.adb, sptests/sp25/sptest.adb, sptests/sp25/sptest.ads, sptests/spsize/spsize.adb, sptests/spsize/sptest.adb, sptests/spsize/sptest.ads, support/address_io.adb, support/address_io.ads, support/float_io.ads, support/fp.inc, support/integer.inc, support/rtems_calling_overhead.ads, support/status_io.ads, support/test_support.adb, support/test_support.ads, support/time_test_support.adb, support/time_test_support.ads, support/timer_driver.adb, support/timer_driver.ads, support/unsigned32_io.ads, tmtests/tm01/config.h, tmtests/tm01/tm01.adb, tmtests/tm01/tmtest.adb, tmtests/tm01/tmtest.ads, tmtests/tm02/config.h, tmtests/tm02/tm02.adb, tmtests/tm02/tmtest.adb, tmtests/tm02/tmtest.ads, tmtests/tm03/config.h, tmtests/tm03/tm03.adb, tmtests/tm03/tmtest.adb, tmtests/tm03/tmtest.ads, tmtests/tm04/config.h, tmtests/tm04/tm04.adb, tmtests/tm04/tmtest.adb, tmtests/tm04/tmtest.ads, tmtests/tm05/config.h, tmtests/tm05/tm05.adb, tmtests/tm05/tmtest.adb, tmtests/tm05/tmtest.ads, tmtests/tm06/config.h, tmtests/tm06/tm06.adb, tmtests/tm06/tmtest.adb, tmtests/tm06/tmtest.ads, tmtests/tm07/config.h, tmtests/tm07/tm07.adb, tmtests/tm07/tmtest.adb, tmtests/tm07/tmtest.ads, tmtests/tm08/config.h, tmtests/tm08/tm08.adb, tmtests/tm08/tmtest.adb, tmtests/tm08/tmtest.ads, tmtests/tm09/config.h, tmtests/tm09/tm09.adb, tmtests/tm09/tmtest.adb, tmtests/tm09/tmtest.ads, tmtests/tm10/config.h, tmtests/tm10/tm10.adb, tmtests/tm10/tmtest.adb, tmtests/tm10/tmtest.ads, tmtests/tm11/config.h, tmtests/tm11/tm11.adb, tmtests/tm11/tmtest.adb, tmtests/tm11/tmtest.ads, tmtests/tm12/config.h, tmtests/tm12/tm12.adb, tmtests/tm12/tmtest.adb, tmtests/tm12/tmtest.ads, tmtests/tm13/config.h, tmtests/tm13/tm13.adb, tmtests/tm13/tmtest.adb, tmtests/tm13/tmtest.ads, tmtests/tm14/config.h, tmtests/tm14/tm14.adb, tmtests/tm14/tmtest.adb, tmtests/tm14/tmtest.ads, tmtests/tm15/config.h, tmtests/tm15/tm15.adb, tmtests/tm15/tmtest.adb, tmtests/tm15/tmtest.ads, tmtests/tm16/config.h, tmtests/tm16/tm16.adb, tmtests/tm16/tmtest.adb, tmtests/tm16/tmtest.ads, tmtests/tm17/config.h, tmtests/tm17/tm17.adb, tmtests/tm17/tmtest.adb, tmtests/tm17/tmtest.ads, tmtests/tm18/config.h, tmtests/tm18/tm18.adb, tmtests/tm18/tmtest.adb, tmtests/tm18/tmtest.ads, tmtests/tm19/config.h, tmtests/tm19/tm19.adb, tmtests/tm19/tmtest.adb, tmtests/tm19/tmtest.ads, tmtests/tm20/config.h, tmtests/tm20/tm20.adb, tmtests/tm20/tmtest.adb, tmtests/tm20/tmtest.ads, tmtests/tm21/config.h, tmtests/tm21/tm21.adb, tmtests/tm21/tmtest.adb, tmtests/tm21/tmtest.ads, tmtests/tm22/config.h, tmtests/tm22/tm22.adb, tmtests/tm22/tmtest.adb, tmtests/tm22/tmtest.ads, tmtests/tm23/config.h, tmtests/tm23/tm23.adb, tmtests/tm23/tmtest.adb, tmtests/tm23/tmtest.ads, tmtests/tm24/config.h, tmtests/tm24/tm24.adb, tmtests/tm24/tmtest.adb, tmtests/tm24/tmtest.ads, tmtests/tm25/config.h, tmtests/tm25/tm25.adb, tmtests/tm25/tmtest.adb, tmtests/tm25/tmtest.ads, tmtests/tm28/config.h, tmtests/tm28/tm28.adb, tmtests/tm28/tmtest.adb, tmtests/tm28/tmtest.ads, tmtests/tm29/config.h, tmtests/tm29/tm29.adb, tmtests/tm29/tmtest.adb, tmtests/tm29/tmtest.ads, tmtests/tmck/config.h, tmtests/tmck/tmck.adb, tmtests/tmck/tmtest.adb, tmtests/tmck/tmtest.ads, tmtests/tmoverhd/config.h, tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/dummy_rtems.ads, tmtests/tmoverhd/tmoverhd.adb, tmtests/tmoverhd/tmtest.adb, tmtests/tmoverhd/tmtest.ads: URL for license changed.
2003-08-202003-08-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+0
* mptests/mp01/config.h, mptests/mp01/mp01.adb, mptests/mp01/mptest.adb, mptests/mp01/mptest.ads, mptests/mp02/mptest.adb, mptests/mp02/mptest.ads, mptests/mp03/mptest.adb, mptests/mp03/mptest.ads, mptests/mp04/mptest.adb, mptests/mp04/mptest.ads, mptests/mp05/mptest.adb, mptests/mp05/mptest.ads, mptests/mp06/mptest.adb, mptests/mp06/mptest.ads, mptests/mp07/mptest.adb, mptests/mp07/mptest.ads, mptests/mp08/mptest.adb, mptests/mp08/mptest.ads, mptests/mp09/mptest.adb, mptests/mp09/mptest.ads, mptests/mp10/mptest.adb, mptests/mp10/mptest.ads, mptests/mp11/mptest.adb, mptests/mp11/mptest.ads, mptests/mp12/mptest.adb, mptests/mp12/mptest.ads, mptests/mp13/mptest.adb, mptests/mp13/mptest.ads, mptests/mp14/mptest.adb, mptests/mp14/mptest.ads, samples/base_mp/mptest.adb, samples/base_mp/mptest.ads, samples/base_sp/base_sp.adb, samples/base_sp/config.h, samples/base_sp/sptest.adb, samples/base_sp/sptest.ads, samples/hello/config.h, samples/hello/hello.adb, samples/hello/sptest.adb, samples/hello/sptest.ads, samples/ticker/config.h, samples/ticker/sptest.adb, samples/ticker/sptest.ads, samples/ticker/ticker.adb, sptests/sp01/config.h, sptests/sp01/sp01.adb, sptests/sp01/sptest.adb, sptests/sp01/sptest.ads, sptests/sp02/config.h, sptests/sp02/sp02.adb, sptests/sp02/sptest.adb, sptests/sp02/sptest.ads, sptests/sp03/config.h, sptests/sp03/sp03.adb, sptests/sp03/sptest.adb, sptests/sp03/sptest.ads, sptests/sp04/config.h, sptests/sp04/sp04.adb, sptests/sp04/sptest.adb, sptests/sp04/sptest.ads, sptests/sp05/config.h, sptests/sp05/sp05.adb, sptests/sp05/sptest.adb, sptests/sp05/sptest.ads, sptests/sp06/config.h, sptests/sp06/sp06.adb, sptests/sp06/sptest.adb, sptests/sp06/sptest.ads, sptests/sp07/config.h, sptests/sp07/sp07.adb, sptests/sp07/sptest.adb, sptests/sp07/sptest.ads, sptests/sp08/config.h, sptests/sp08/sp08.adb, sptests/sp08/sptest.adb, sptests/sp08/sptest.ads, sptests/sp09/config.h, sptests/sp09/sp09.adb, sptests/sp09/sptest.adb, sptests/sp09/sptest.ads, sptests/sp11/config.h, sptests/sp11/sp11.adb, sptests/sp11/sptest.adb, sptests/sp11/sptest.ads, sptests/sp12/config.h, sptests/sp12/sp12.adb, sptests/sp12/sptest.adb, sptests/sp12/sptest.ads, sptests/sp13/config.h, sptests/sp13/sp13.adb, sptests/sp13/sptest.adb, sptests/sp13/sptest.ads, sptests/sp14/config.h, sptests/sp14/sp14.adb, sptests/sp14/sptest.adb, sptests/sp14/sptest.ads, sptests/sp15/config.h, sptests/sp15/sp15.adb, sptests/sp15/sptest.adb, sptests/sp15/sptest.ads, sptests/sp16/config.h, sptests/sp16/sp16.adb, sptests/sp16/sptest.adb, sptests/sp16/sptest.ads, sptests/sp17/config.h, sptests/sp17/sp17.adb, sptests/sp17/sptest.adb, sptests/sp17/sptest.ads, sptests/sp19/config.h, sptests/sp19/sp19.adb, sptests/sp19/sptest.ads, sptests/sp20/config.h, sptests/sp20/sp20.adb, sptests/sp20/sptest.adb, sptests/sp20/sptest.ads, sptests/sp21/config.h, sptests/sp21/sp21.adb, sptests/sp21/sptest.adb, sptests/sp21/sptest.ads, sptests/sp22/config.h, sptests/sp22/sp22.adb, sptests/sp22/sptest.adb, sptests/sp22/sptest.ads, sptests/sp23/config.h, sptests/sp23/sp23.adb, sptests/sp23/sptest.adb, sptests/sp23/sptest.ads, sptests/sp24/config.h, sptests/sp24/sp24.adb, sptests/sp24/sptest.adb, sptests/sp24/sptest.ads, sptests/sp25/config.h, sptests/sp25/sp25.adb, sptests/sp25/sptest.adb, sptests/sp25/sptest.ads, sptests/spsize/spsize.adb, sptests/spsize/sptest.adb, sptests/spsize/sptest.ads, support/address_io.adb, support/address_io.ads, support/float_io.ads, support/fp.inc, support/integer.inc, support/rtems_calling_overhead.ads, support/status_io.ads, support/test_support.adb, support/test_support.ads, support/time_test_support.adb, support/time_test_support.ads, support/timer_driver.adb, support/timer_driver.ads, support/unsigned32_io.ads, tmtests/tm01/config.h, tmtests/tm01/tm01.adb, tmtests/tm01/tmtest.adb, tmtests/tm01/tmtest.ads, tmtests/tm02/config.h, tmtests/tm02/tm02.adb, tmtests/tm02/tmtest.adb, tmtests/tm02/tmtest.ads, tmtests/tm03/config.h, tmtests/tm03/tm03.adb, tmtests/tm03/tmtest.adb, tmtests/tm03/tmtest.ads, tmtests/tm04/config.h, tmtests/tm04/tm04.adb, tmtests/tm04/tmtest.adb, tmtests/tm04/tmtest.ads, tmtests/tm05/config.h, tmtests/tm05/tm05.adb, tmtests/tm05/tmtest.adb, tmtests/tm05/tmtest.ads, tmtests/tm06/config.h, tmtests/tm06/tm06.adb, tmtests/tm06/tmtest.adb, tmtests/tm06/tmtest.ads, tmtests/tm07/config.h, tmtests/tm07/tm07.adb, tmtests/tm07/tmtest.adb, tmtests/tm07/tmtest.ads, tmtests/tm08/config.h, tmtests/tm08/tm08.adb, tmtests/tm08/tmtest.adb, tmtests/tm08/tmtest.ads, tmtests/tm09/config.h, tmtests/tm09/tm09.adb, tmtests/tm09/tmtest.adb, tmtests/tm09/tmtest.ads, tmtests/tm10/config.h, tmtests/tm10/tm10.adb, tmtests/tm10/tmtest.adb, tmtests/tm10/tmtest.ads, tmtests/tm11/config.h, tmtests/tm11/tm11.adb, tmtests/tm11/tmtest.adb, tmtests/tm11/tmtest.ads, tmtests/tm12/config.h, tmtests/tm12/tm12.adb, tmtests/tm12/tmtest.adb, tmtests/tm12/tmtest.ads, tmtests/tm13/config.h, tmtests/tm13/tm13.adb, tmtests/tm13/tmtest.adb, tmtests/tm13/tmtest.ads, tmtests/tm14/config.h, tmtests/tm14/tm14.adb, tmtests/tm14/tmtest.adb, tmtests/tm14/tmtest.ads, tmtests/tm15/config.h, tmtests/tm15/tm15.adb, tmtests/tm15/tmtest.adb, tmtests/tm15/tmtest.ads, tmtests/tm16/config.h, tmtests/tm16/tm16.adb, tmtests/tm16/tmtest.adb, tmtests/tm16/tmtest.ads, tmtests/tm17/config.h, tmtests/tm17/tm17.adb, tmtests/tm17/tmtest.adb, tmtests/tm17/tmtest.ads, tmtests/tm18/config.h, tmtests/tm18/tm18.adb, tmtests/tm18/tmtest.adb, tmtests/tm18/tmtest.ads, tmtests/tm19/config.h, tmtests/tm19/tm19.adb, tmtests/tm19/tmtest.adb, tmtests/tm19/tmtest.ads, tmtests/tm20/config.h, tmtests/tm20/tm20.adb, tmtests/tm20/tmtest.adb, tmtests/tm20/tmtest.ads, tmtests/tm21/config.h, tmtests/tm21/tm21.adb, tmtests/tm21/tmtest.adb, tmtests/tm21/tmtest.ads, tmtests/tm22/config.h, tmtests/tm22/tm22.adb, tmtests/tm22/tmtest.adb, tmtests/tm22/tmtest.ads, tmtests/tm23/config.h, tmtests/tm23/tm23.adb, tmtests/tm23/tmtest.adb, tmtests/tm23/tmtest.ads, tmtests/tm24/config.h, tmtests/tm24/tm24.adb, tmtests/tm24/tmtest.adb, tmtests/tm24/tmtest.ads, tmtests/tm25/config.h, tmtests/tm25/tm25.adb, tmtests/tm25/tmtest.adb, tmtests/tm25/tmtest.ads, tmtests/tm28/config.h, tmtests/tm28/tm28.adb, tmtests/tm28/tmtest.adb, tmtests/tm28/tmtest.ads, tmtests/tm29/config.h, tmtests/tm29/tm29.adb, tmtests/tm29/tmtest.adb, tmtests/tm29/tmtest.ads, tmtests/tmck/config.h, tmtests/tmck/tmck.adb, tmtests/tmck/tmtest.adb, tmtests/tmck/tmtest.ads, tmtests/tmoverhd/config.h, tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/dummy_rtems.ads, tmtests/tmoverhd/tmoverhd.adb, tmtests/tmoverhd/tmtest.adb, tmtests/tmoverhd/tmtest.ads: Correct copyright statements.
1997-06-04new fileJoel Sherrill1-1/+1
1997-06-03new fileJoel Sherrill1-0/+0
1997-06-02New file -- works in conjunction with support/init.c.Joel Sherrill1-25/+7
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1996-08-08added cases to increase coverage of pthread_create. cases added testedJoel Sherrill1-0/+5
error paths as well as inherit scheduling attributes.
1996-08-02removed unused prototypesJoel Sherrill1-9/+0
1996-08-01test successfully exercises all of pthread_attr_* set and get routinesJoel Sherrill1-0/+0
1996-06-13first successful run. Has test cases for a simple sigtimedwait() timeout,Mark Johannes1-1/+5
a sigtimewait() timeout because it was pthread_kill'ed with a blocked signal, and a sigtimedwait which is satisfied.
1996-06-12new filesJoel Sherrill1-0/+0
1996-06-10new files.Joel Sherrill1-1/+0
This test does a basic checkout of signals with a thread-directed signal (pthread_kill()) used to interrupt a nanosleep().
1996-06-10moved the time macros to pmacros.h.Joel Sherrill1-4/+1
1996-06-04added basic test cases for pthread_self and pthread_equalJoel Sherrill1-0/+9
1996-05-30added code to test clock and time related functionality.Joel Sherrill1-0/+1
1996-05-29tests now specify whether using posix initialization threads tableJoel Sherrill1-4/+2
1996-05-29simple version of test which shows pthread_create, pthread_exit, and exitJoel Sherrill1-2/+3
are basically working. This test will be enhanced further.
1996-05-29Gutted test of rtems api calls and added comments to indicate what the testJoel Sherrill1-9/+12
should do in their place. It now compiles and links.
1996-05-24new filesJoel Sherrill1-0/+0
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill1-5/+19
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-08-23Support for variable length names added to Object Handler. This supportsJoel Sherrill1-1/+1
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested.
1995-08-17maximum number of messages removed and include statement cleanupJoel Sherrill1-3/+2
