* | 2002-09-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-03 | 2 | -86/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * base_mp now builds and can be considered a bit of an example for the other mptests. * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/base_mp/mptest.adb, samples/base_mp/mptest.ads, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am: Modified to make compile. * mptests/mp01/node1/mptest-per_node_configuration.adb, mptests/mp01/node2/mptest-per_node_configuration.adb, mptests/mp02/node1/mptest-per_node_configuration.adb, mptests/mp02/node2/mptest-per_node_configuration.adb, mptests/mp03/node1/mptest-per_node_configuration.adb, mptests/mp03/node2/mptest-per_node_configuration.adb, mptests/mp04/node1/mptest-per_node_configuration.adb, mptests/mp04/node2/mptest-per_node_configuration.adb, mptests/mp05/node1/mptest-per_node_configuration.adb, mptests/mp05/node2/mptest-per_node_configuration.adb, mptests/mp06/node1/mptest-per_node_configuration.adb, mptests/mp06/node2/mptest-per_node_configuration.adb, mptests/mp07/node1/mptest-per_node_configuration.adb, mptests/mp07/node2/mptest-per_node_configuration.adb, mptests/mp08/node1/mptest-per_node_configuration.adb, mptests/mp08/node2/mptest-per_node_configuration.adb, mptests/mp09/node1/mptest-per_node_configuration.adb, mptests/mp09/node2/mptest-per_node_configuration.adb, mptests/mp10/node1/mptest-per_node_configuration.adb, mptests/mp10/node2/mptest-per_node_configuration.adb, mptests/mp11/node1/mptest-per_node_configuration.adb, mptests/mp11/node2/mptest-per_node_configuration.adb, mptests/mp12/node1/mptest-per_node_configuration.adb, mptests/mp12/node2/mptest-per_node_configuration.adb, mptests/mp13/node1/mptest-per_node_configuration.adb, mptests/mp13/node2/mptest-per_node_configuration.adb, mptests/mp14/node1/mptest-per_node_configuration.adb, mptests/mp14/node2/mptest-per_node_configuration.adb, samples/base_mp/node1/mptest-per_node_configuration.adb, samples/base_mp/node2/mptest-per_node_configuration.adb: Removed as this information should come from config.h. | ||||
* | 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-09-02 | 2 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/.cvsignore: New. * mptests/mp01/node2/.cvsignore: New. * mptests/mp02/node1/.cvsignore: New. * mptests/mp02/node2/.cvsignore: New. * mptests/mp03/node1/.cvsignore: New. * mptests/mp03/node2/.cvsignore: New. * mptests/mp04/node1/.cvsignore: New. * mptests/mp04/node2/.cvsignore: New. * mptests/mp05/node1/.cvsignore: New. * mptests/mp05/node2/.cvsignore: New. * mptests/mp06/node1/.cvsignore: New. * mptests/mp06/node2/.cvsignore: New. * mptests/mp07/node1/.cvsignore: New. * mptests/mp07/node2/.cvsignore: New. * mptests/mp08/node1/.cvsignore: New. * mptests/mp08/node2/.cvsignore: New. * mptests/mp09/node1/.cvsignore: New. * mptests/mp09/node2/.cvsignore: New. * mptests/mp10/node1/.cvsignore: New. * mptests/mp10/node2/.cvsignore: New. * mptests/mp11/node1/.cvsignore: New. * mptests/mp11/node2/.cvsignore: New. * mptests/mp12/node1/.cvsignore: New. * mptests/mp12/node2/.cvsignore: New. * mptests/mp13/node1/.cvsignore: New. * mptests/mp13/node2/.cvsignore: New. * mptests/mp14/node1/.cvsignore: New. * mptests/mp14/node2/.cvsignore: New. * samples/base_mp/node1/.cvsignore: New. * samples/base_mp/node2/.cvsignore: New. | ||||
* | 2002-08-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-26 | 1 | -1/+0 |
| | | | | | | | | | | | | * mptests/mp01/mptest.ads, mptests/mp02/mptest.ads, mptests/mp03/mptest.ads, mptests/mp04/mptest.ads, mptests/mp05/mptest.ads, mptests/mp06/mptest.ads, mptests/mp07/mptest.ads, mptests/mp08/mptest.ads, mptests/mp09/mptest.ads, mptests/mp10/mptest.ads, mptests/mp11/mptest.ads, mptests/mp12/mptest.ads, mptests/mp13/mptest.ads, mptests/mp14/mptest.adb, mptests/mp14/mptest.ads: Per PR274, identify the need for the BSP_MPCI package. It was a trivial dependency and eliminated. | ||||
* | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-26 | 1 | -0/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ChangeLog: New. * .cvsignore: New. * mptests/.cvsignore: New. * mptests/mp01/.cvsignore: New. * mptests/mp02/.cvsignore: New. * mptests/mp03/.cvsignore: New. * mptests/mp04/.cvsignore: New. * mptests/mp05/.cvsignore: New. * mptests/mp06/.cvsignore: New. * mptests/mp07/.cvsignore: New. * mptests/mp08/.cvsignore: New. * mptests/mp09/.cvsignore: New. * mptests/mp10/.cvsignore: New. * mptests/mp11/.cvsignore: New. * mptests/mp12/.cvsignore: New. * mptests/mp13/.cvsignore: New. * mptests/mp14/.cvsignore: New. * samples/.cvsignore: New. * samples/base_sp/.cvsignore: New. * samples/hello/.cvsignore: New. * samples/ticker/.cvsignore: New. * sptests/.cvsignore: New. * sptests/sp01/.cvsignore: New. * sptests/sp02/.cvsignore: New. * sptests/sp03/.cvsignore: New. * sptests/sp04/.cvsignore: New. * sptests/sp05/.cvsignore: New. * sptests/sp06/.cvsignore: New. * sptests/sp07/.cvsignore: New. * sptests/sp08/.cvsignore: New. * sptests/sp09/.cvsignore: New. * sptests/sp11/.cvsignore: New. * sptests/sp12/.cvsignore: New. * sptests/sp13/.cvsignore: New. * sptests/sp14/.cvsignore: New. * sptests/sp15/.cvsignore: New. * sptests/sp16/.cvsignore: New. * sptests/sp17/.cvsignore: New. * sptests/sp19/.cvsignore: New. * sptests/sp20/.cvsignore: New. * sptests/sp21/.cvsignore: New. * sptests/sp22/.cvsignore: New. * sptests/sp23/.cvsignore: New. * sptests/sp24/.cvsignore: New. * sptests/sp25/.cvsignore: New. * sptests/spsize/.cvsignore: New. * support/.cvsignore: New. * tmtests/.cvsignore: New. * tmtests/tm01/.cvsignore: New. * tmtests/tm02/.cvsignore: New. * tmtests/tm03/.cvsignore: New. * tmtests/tm04/.cvsignore: New. * tmtests/tm05/.cvsignore: New. * tmtests/tm06/.cvsignore: New. * tmtests/tm07/.cvsignore: New. * tmtests/tm08/.cvsignore: New. * tmtests/tm09/.cvsignore: New. * tmtests/tm10/.cvsignore: New. * tmtests/tm11/.cvsignore: New. * tmtests/tm12/.cvsignore: New. * tmtests/tm13/.cvsignore: New. * tmtests/tm14/.cvsignore: New. * tmtests/tm15/.cvsignore: New. * tmtests/tm16/.cvsignore: New. * tmtests/tm17/.cvsignore: New. * tmtests/tm18/.cvsignore: New. * tmtests/tm19/.cvsignore: New. * tmtests/tm20/.cvsignore: New. * tmtests/tm21/.cvsignore: New. * tmtests/tm22/.cvsignore: New. * tmtests/tm23/.cvsignore: New. * tmtests/tm24/.cvsignore: New. * tmtests/tm25/.cvsignore: New. * tmtests/tm26/.cvsignore: New. * tmtests/tm27/.cvsignore: New. * tmtests/tm28/.cvsignore: New. * tmtests/tm29/.cvsignore: New. * tmtests/tmck/.cvsignore: New. * tmtests/tmoverhd/.cvsignore: New. | ||||
* | *** empty log message *** | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
* | added screen files from 3.2.1 | Joel Sherrill | 1997-06-02 | 2 | -0/+46 |
* | modified copyright notice to be the same as RTEMS 4.0.0. | Joel Sherrill | 1997-06-02 | 4 | -24/+24 |
| | | | | changed the CVS ID string to be a "development" version. | ||||
* | Initial revision | Joel Sherrill | 1997-06-02 | 4 | -0/+722 |
