2017-10-12 | ada-tests: Move to testsuites/ada | Sebastian Huber | 1 | -4/+0 | |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. | |||||
2017-10-12 | ada-tests: Use _SUBDIRS instead of SUBDIRS | Sebastian Huber | 1 | -1/+1 | |
Update #3079. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 1 | -0/+2 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 1 | -2/+0 | |
2005-11-20 | New. | Ralf Corsepius | 1 | -0/+0 | |
2005-11-20 | Cleanup. | Ralf Corsepius | 1 | -3/+0 | |
2003-12-05 | 2003-12-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* mptests/mp01/Makefile.am: Cosmetics. * samples/Makefile.am: Cosmetics. * samples/base_mp/Makefile.am: Cosmetics. * samples/base_sp/Makefile.am: Cosmetics. * samples/hello/Makefile.am: Cosmetics. * samples/ticker/Makefile.am: Cosmetics. * support/Makefile.am: Cosmetics. * tmtests/tmoverhd/Makefile.am: Cosmetics. | |||||
2003-11-11 | 2003-11-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -3/+3 | |
* Makefile.am: Reflect having moved tests/. * mptests/Makefile.am: Reflect having moved tests/. * mptests/mp01/Makefile.am: Reflect having moved tests/. * mptests/mp01/node1/Makefile.am: Reflect having moved tests/. * mptests/mp01/node2/Makefile.am: Reflect having moved tests/. * samples/Makefile.am: Reflect having moved tests/. * samples/base_mp/Makefile.am: Reflect having moved tests/. * samples/base_mp/node1/Makefile.am: Reflect having moved tests/. * samples/base_mp/node2/Makefile.am: Reflect having moved tests/. * samples/base_sp/Makefile.am: Reflect having moved tests/. * samples/hello/Makefile.am: Reflect having moved tests/. * samples/ticker/Makefile.am: Reflect having moved tests/. * sptests/Makefile.am: Reflect having moved tests/. * sptests/sp01/Makefile.am: Reflect having moved tests/. * sptests/sp02/Makefile.am: Reflect having moved tests/. * sptests/sp03/Makefile.am: Reflect having moved tests/. * sptests/sp04/Makefile.am: Reflect having moved tests/. * sptests/sp05/Makefile.am: Reflect having moved tests/. * sptests/sp06/Makefile.am: Reflect having moved tests/. * sptests/sp07/Makefile.am: Reflect having moved tests/. * sptests/sp08/Makefile.am: Reflect having moved tests/. * sptests/sp09/Makefile.am: Reflect having moved tests/. * sptests/sp11/Makefile.am: Reflect having moved tests/. * sptests/sp12/Makefile.am: Reflect having moved tests/. * sptests/sp13/Makefile.am: Reflect having moved tests/. * sptests/sp14/Makefile.am: Reflect having moved tests/. * sptests/sp15/Makefile.am: Reflect having moved tests/. * sptests/sp16/Makefile.am: Reflect having moved tests/. * sptests/sp17/Makefile.am: Reflect having moved tests/. * sptests/sp19/Makefile.am: Reflect having moved tests/. * sptests/sp20/Makefile.am: Reflect having moved tests/. * sptests/sp21/Makefile.am: Reflect having moved tests/. * sptests/sp22/Makefile.am: Reflect having moved tests/. * sptests/sp23/Makefile.am: Reflect having moved tests/. * sptests/sp24/Makefile.am: Reflect having moved tests/. * sptests/sp25/Makefile.am: Reflect having moved tests/. * sptests/spsize/Makefile.am: Reflect having moved tests/. * support/Makefile.am: Reflect having moved tests/. * tmtests/Makefile.am: Reflect having moved tests/. * tmtests/tm01/Makefile.am: Reflect having moved tests/. * tmtests/tm02/Makefile.am: Reflect having moved tests/. * tmtests/tm03/Makefile.am: Reflect having moved tests/. * tmtests/tm04/Makefile.am: Reflect having moved tests/. * tmtests/tm05/Makefile.am: Reflect having moved tests/. * tmtests/tm06/Makefile.am: Reflect having moved tests/. * tmtests/tm07/Makefile.am: Reflect having moved tests/. * tmtests/tm08/Makefile.am: Reflect having moved tests/. * tmtests/tm09/Makefile.am: Reflect having moved tests/. * tmtests/tm10/Makefile.am: Reflect having moved tests/. * tmtests/tm11/Makefile.am: Reflect having moved tests/. * tmtests/tm12/Makefile.am: Reflect having moved tests/. * tmtests/tm13/Makefile.am: Reflect having moved tests/. * tmtests/tm14/Makefile.am: Reflect having moved tests/. * tmtests/tm15/Makefile.am: Reflect having moved tests/. * tmtests/tm16/Makefile.am: Reflect having moved tests/. * tmtests/tm17/Makefile.am: Reflect having moved tests/. * tmtests/tm18/Makefile.am: Reflect having moved tests/. * tmtests/tm19/Makefile.am: Reflect having moved tests/. * tmtests/tm20/Makefile.am: Reflect having moved tests/. * tmtests/tm21/Makefile.am: Reflect having moved tests/. * tmtests/tm22/Makefile.am: Reflect having moved tests/. * tmtests/tm23/Makefile.am: Reflect having moved tests/. * tmtests/tm24/Makefile.am: Reflect having moved tests/. * tmtests/tm25/Makefile.am: Reflect having moved tests/. * tmtests/tm28/Makefile.am: Reflect having moved tests/. * tmtests/tm29/Makefile.am: Reflect having moved tests/. * tmtests/tmck/Makefile.am: Reflect having moved tests/. * tmtests/tmoverhd/Makefile.am: Reflect having moved tests/. | |||||
2003-08-20 | 2003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -3/+3 | |
* Makefile.am, mptests/Makefile.am, mptests/mp01/Makefile.am, mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/ticker/Makefile.am, sptests/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp21/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, sptests/spsize/Makefile.am, support/Makefile.am, tmtests/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Pick up am-fragments from ../tests/automake. | |||||
2002-09-02 | 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -8/+2 | |
* mptests/Makefile.am: New. * mptests/mp01/Makefile.am: New. * mptests/mp01/node1/Makefile.am: New. * mptests/mp01/node2/Makefile.am: New. * samples/base_mp/Makefile.am: Comment out building mptest$(EXEEXT). * samples/base_mp/node1/Makefile.am: New. * samples/base_mp/node2/Makefile.am: New. * configure.ac: Add mptests/mp01. Add samples/base_mp. | |||||
2002-08-26 | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
* Makefile.am: Activate tmtests. * configure.ac: Activate tmtests. * samples/base_mp/Makefile.am: Add nodeX subdirs. * sptests/sp01/Makefile.am: Add *.scn. * sptests/sp02/Makefile.am: Add *.scn. * sptests/sp03/Makefile.am: Add *.scn. * sptests/sp04/Makefile.am: Add *.scn. * sptests/sp05/Makefile.am: Add *.scn. * sptests/sp06/Makefile.am: Add *.scn. * sptests/sp07/Makefile.am: Add *.scn. * sptests/sp08/Makefile.am: Add *.scn. * sptests/sp09/Makefile.am: Add *.scn. * sptests/sp11/Makefile.am: Add *.scn. * sptests/sp12/Makefile.am: Add *.scn. * sptests/sp13/Makefile.am: Add *.scn. * sptests/sp14/Makefile.am: Add *.scn. * sptests/sp15/Makefile.am: Add *.scn. * sptests/sp16/Makefile.am: Add *.scn. * sptests/sp17/Makefile.am: Add *.scn. * sptests/sp19/Makefile.am: Add *.scn. * sptests/sp20/Makefile.am: Add *.scn. * sptests/sp21/Makefile.am: Add *.scn. * sptests/sp22/Makefile.am: Add *.scn. * sptests/sp23/Makefile.am: Add *.scn. * sptests/sp24/Makefile.am: Add *.scn. * sptests/sp25/Makefile.am: Add *.scn. | |||||
2002-08-26 | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -6/+6 | |
* Makefile.am: New. * configure.ac: New. * ada.am: New. * support/Makefile.am: New. * samples/Makefile.am: New. * samples/base_mp/Makefile.am: New. * samples/base_sp/Makefile.am: New. * samples/hello/Makefile.am: New. * samples/ticker/Makefile.am: New. | |||||
2002-08-26 | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+15 | |
* sptests/Makefile.am: New. * sptests/sp01/Makefile.am: New. * sptests/sp02/Makefile.am: New. * sptests/sp03/Makefile.am: New. * sptests/sp04/Makefile.am: New. * sptests/sp05/Makefile.am: New. * sptests/sp06/Makefile.am: New. * sptests/sp07/Makefile.am: New. * sptests/sp08/Makefile.am: New. * sptests/sp09/Makefile.am: New. * sptests/sp11/Makefile.am: New. * sptests/sp12/Makefile.am: New. * sptests/sp13/Makefile.am: New. * sptests/sp14/Makefile.am: New. * sptests/sp15/Makefile.am: New. * sptests/sp16/Makefile.am: New. * sptests/sp17/Makefile.am: New. * sptests/sp19/Makefile.am: New. * sptests/sp20/Makefile.am: New. * sptests/sp21/Makefile.am: New. * sptests/sp22/Makefile.am: New. * sptests/sp23/Makefile.am: New. * sptests/sp24/Makefile.am: New. * sptests/sp25/Makefile.am: New. * sptests/spsize/Makefile.am: New. |
